Old 04-23-2021, 04:23 AM   #1
pigdog
Default Daves never ending volvo saga
Hey guys long time listener first time caller .
figured its about time i started a thread on here .
Firstly as the title suggests I'm Dave , I'm from the land of vegemite sandwiches and drop bears.
I fell into the world of Volvos a few years back and its been a downward spiral ever since.
Ill give a brief rundown of what i have done over the years but if you want to know more head over to ozvolvo and read my thread : https://ozvolvo.org/discussion/9946/...volving-volvos.
ok brief run down:
bought $50 mint 1990 240, converted to manual, k cam, exhaust, lowered etc etc
Swapped that 240 for a 1987 360GLT and 1992 240 GLE wagon.
b230f swapped 360, lowered ,exhaust etc etc sold 360
converted 240GLE wagon to B230FK,16T, 3" Turbo back, big Ic ,531 head, ipd cam etc etc
bought 1979 264GlE with B21e.
Ok now you're all caught up .
Heres how my 2 volvos sit now
So the turbo wagon is done for now, well kinda there always seems to be something that needs to be done to it , its never ending in the future there will be T5 trans swap and more powerrr.
my main plans are for the 264 atm.
im currently doing all the suspension , new poly bushes everywhere , classicswede 60/40 springs , gaz front struts , B6 rear shocks , ipd torque rods, dvs adjustable panhard .
very soon i will be embarking on quite the mission.
firstly i will be converting it from kjet to lh2.2 i have everything ready to go just need to find the time .
but the big and terrifying part is the motor and trans. both were said to be good but unknown how true that is .
trans is an m47 and the motor is something a little special .
Its a B23e thats been massively overbored to take chev 283 pistons bringing the displacement up around 2.5l .
the motor was built in a shop that builds race engines and the bottom end was meticulously balanced .
it was said to be the smoothest redblock the bloke has ever had and was torquey as all hell it was built to tow a caravan behind his 240 he needed more torque to get up the mountain haha the motor has only ever ran on LPG .
It was in the car for 7 years and did 300.000ks before being pulled out to swap in a v8 .
i grabbed it off him for dirt cheap as abit of a gamble , it could be interesting ,it could blow up time will tell haha
it was running an A cam which i have swapped out for a H cam im just cleaning it all up doing new gaskets n seals etc then i guess its time to drop it in.
a couple questions for anybody still reading that understands lh2.2
2.2 doesnt get much love here so finding proper information is abit of a thing .
ive been told 2.2 doesnt like cam changes , how do you think it will like the H cam?
i have a mate with a 2.2 car running a H cam no issues but a few guys have told me conflicting things .
ive also been told 2.2 doesn't like injector changes . trying to figure out what injectors to run with the big bore motor , i was given some 16v injectors to compensate for the increased displacement, i also have stock 240 ones if need be .
i think thats about it for now any help with those 2 things would be awesome , ill try to keep this thread updated but if youre interested in following along more check the ozvolvo thread or follow me on insta :pigdog85
pigdog is offline   Reply With Quote
Old 04-25-2021, 02:09 PM   #2
JerryJS8
der Junge
JerryJS8's Avatar
Greetings down under and glad to have you here on your first call!
Projects look good, but I neeeeeeed moooooaaarrr pics!!!
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 04-26-2021, 05:12 AM   #3
pigdog
Originally Posted by JerryJS8 View Post
Greetings down under and glad to have you hear on your first call!
go check my instagram out man :pigdog85
heaps of pics on there
Old 04-27-2021, 12:57 PM   #4
As far as injector changes. LH2.2 can use a chipped ecu that will let you run larger injectors. Some of the ecus need the eprom desoldered and a socket added to put the performance chip in. We put one in a friends 87 740 turbo and it ran great. The cam is a type that is expecting high compression and an ignition curve tuned to the cam. Since you are gong to the LH2.2 are you going to use the 117EZK or the chrysler ignition box? Neither will have an optimized curve for your cam but if you use the chrysler box from a high compression flat top piston B23F you may have a ignition curve that works well. You'll be able to adjust your base timing, so playing with the idle advance may help, too.
Old 04-28-2021, 08:20 AM   #5
pigdog
Hey mate cheers for the reply , ill look into the ecu chip that could be an option , is it right that 2.2 doesnt adjust at all like 2.4? the stock injectors very well may be fine its just an unknown with the motor being 2.5l displacement, ill be installing a wideband and run factory injectors first see how it all goes then i have some b234 injectors they are 243cc i think from memory .
ill be running the Chrysler ignition box , it came from a b230 240 im sure i could find another Chrysler box more suitable though , im not set on it having to run the H cam, just i have it here and it would be nice especially with the manual box i also have an A cam if 2.2 is unhappy with the H .
a mate suggested i get a 123 distributor as its adjustable and has all different ignition curves , i havent looked into that much yet to see if its a viable option .
Old 04-29-2021, 01:12 PM   #6
bobxyz
bobxyz's Avatar
Why LH2.2 and not LH2.4?
LH2.4/EZ116K has much better tuning and chipping support, which will help with your non-factory setup. [The 123 distributors do give you ignition tuning capability, but they're not cheap -- maybe $400-$500 range?]
Old 04-29-2021, 07:44 PM   #7
pigdog
Simplicity and I have a complete 2.2 conversion here .
I'm not chasing power or anything crazy just making a comfortable daily driver.
I did consider going 2.4 but honestly I don't think it's needed and I literally have everything on hand to go 2.2.
if I went 2.4 I would need to stuff around with speed signal, changing flywheels etc etc it's not a massive thing but I also don't have those parts on hand.
if I didn't have the overbored 2.5l motor I would just be dropping a stock b230f in with the m47 and calling it a day. the car is my gfs daily driver so just keeping it simple.
originally I was just going to go twin Webber's, I thought that would be a nice little combo but I have a whole 2.2 conversion so why not use it I won't be asking much of it so it should cope well, if the H cam is abit aggressive for it I'll swap it out for an A cam.
although as said previously a mate is running a H in his 2.2 car and it runs flawlessly.
