Old 04-30-2021, 12:18 AM   #1
BeaverMeat
BeaverMeat's Avatar
Default Charging failure idiot lights
The list goes on with my freshly rebuilt 5.0L swap.
No temp gauge. Fixed
No cooling fans. Fixed
Starter electrical (ground). Fixed
Now there is a host of idiot lights on the dash. Charge light. Brake failure, E-brake, and lamp failure lights are all on. The new Napa alternator isn’t charging. So I get the Charge light.
Are all the others supposed to come on when there is an alternator failure? Or is the wiring just half-assed. surprised the previous owner had zero troubles with it.
She’s built like a steakhouse but, she handles like a bistro.
Old 04-30-2021, 02:35 AM   #2
2manyturbos
Those are always on with the key in the run position until you start the car and the alternator starts charging. Totally normal. Is the alternator properly grounded?
Old 04-30-2021, 03:53 AM   #3
Jack
junkman
Jack's Avatar
Rebuild the engine again
I love you even more Jack.
Old 04-30-2021, 10:26 AM   #4
BeaverMeat
BeaverMeat's Avatar
Last time I checked. All the lights remain on whole wile running. May have to check the connections. Could have wiggled out.
Will have to rework the wiring...
Old 04-30-2021, 01:43 PM   #5
lummert
lummert's Avatar
Make sure the alternator is properly grounded to the block.
Old 05-01-2021, 02:12 AM   #6
BeaverMeat
BeaverMeat's Avatar
The Napa reman failed after 30min... they refunded my money. Going with an ACDelco.
So... during a charge failure. Why are the brake/light failure idiot lights being engaged?
Is there some wiring I need to refurbish?
Old 05-01-2021, 11:04 AM   #7
bobxyz
bobxyz's Avatar
It's completely normal on any car of that era for lots of the dashboard lights to turn on when the alternator isn't working. This is used as a bulb check before starting the car. If the alternator goes slightly bad, the Alt light will come on by itself while running. If the alternator goes completely bad, or the belt breaks, you get a light show.
Old 05-01-2021, 12:20 PM   #8
BeaverMeat
BeaverMeat's Avatar
Makes sense. Haven’t driven a car this old since high school... I haven’t drove this car for 6 months
