Old 05-02-2021, 03:09 PM   #1
sheepbleat
Default Plug for O2 Sensor Hole in Manifold
Car: ‘91 244 w/ B230F, NA
Replacing my exhaust manifold with one from the junkyard. New one’s got a hole for an O2 sensor, but I was planning on running the sensor down by the cat.
What should I plug the hole in the manifold with? Is a regular bung plug capable of withstanding that heat, or should I be buying a bolt that matches the thread pitch?
Thanks as always!
Greg
My Feedback Thread
Old 05-02-2021, 03:15 PM   #2
Fa182
Stage 1
Fa182's Avatar
Old 05-02-2021, 03:50 PM   #3
The Librarian
According to Skandix that plug is M16 x 1.5. I believe it's for the EGR fitting, not the O2 sensor although now that I think about it that's probably what he needs.
O2 sensors are M18 x 1.5.
http://www.siliconeintakes.com/dsm-i...xoCkbAQAvD_BwE
Old 05-02-2021, 04:40 PM   #4
sheepbleat
Thanks both! There was an old O2 sensor in there originally, so it’s probably M18 x 1.5. I’ll pull the trigger on that bolt.
Old 05-02-2021, 04:59 PM   #5
Fa182
Stage 1
Fa182's Avatar
Sorry, I did indeed confuse it with the EGR plug.
Old 05-02-2021, 07:52 PM   #6
apachechef
Burnt Sierra Madre
spark plug
Dammit, Lummert.
Old 05-05-2021, 04:17 PM   #7
joel142
I plugged that with a cheap O2 sensor cap off Amazon and an oil drain washer - worked great.
http://forums.turbobricks.com/showpo...5&postcount=57
'71 142E, M41, Corbeau GT seats, iPd bars and springs, Nardi wheel, GT gauges, overmatched KYB Gas-A-Justs, Canisto wheels, 7" and Series 175 Cibies
'95 T5-R, yellow, M56H swap
joel142 is offline   Reply With Quote
Old 05-05-2021, 11:46 PM   #8
James M
Bored member
James M's Avatar
I've had manifolds with both EGR and O2 sensors, EGR from just two exhaust ports while obviously the O2 sensor overlaps both 1-2&3-4. Wanna say they where different sizes aswell, but problem solved anyways
Old 05-06-2021, 06:11 AM   #9
shoestring
shoestring's Avatar
GM makes an O2 sensor hole plug, 10017198, that's cheap and does not require a gasket.
Old 05-06-2021, 11:22 AM   #10
gsellstr
Vintage anti-ricer
gsellstr's Avatar
I used an M18x1.5 oil drain plug on my 90+ EGR port, easy to find off the rack at the chain stores usually. Can't comment on the NA thread size, but you may be able to get a plug for it from the chain stores as well. Just don't use the plastic/rubber gasket. lol
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 05-06-2021, 07:05 PM   #11
lummert
lummert's Avatar
M18x1.5 oil drain plug?
Old 05-06-2021, 07:07 PM   #12
James M
Bored member
James M's Avatar
You'd be surprised the number of nylon lock nuts people use for exhaust hardware
Old 05-06-2021, 07:24 PM   #13
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Sadly, yeah, I'd believe it Jimmy. lol
Yeah lummert...oil drain plug...just not a redblock one. No idea what it fits, found it hanging on the 'Help!' section at one of the chain stores in town.
Old 05-07-2021, 01:19 AM   #14
spock345
spock345's Avatar
I made that mistake once. The exhaust leak and burning plastic smell informed me that it was a bad idea. It pays to check if the nut you grabbed from your of assorted hardware is a nylon lock nut.
1967 122s, B20F, M40
