toby2tongues
- May 5, 2021
So I am new to Volvo's but not new to old cars with complicated electrical systems, I'm a big fan of Jaguar XJS's.
So I picked up a nice 92-240 wagon. Everything was going well and I was really only focused on cosmetics suspension and brakes given everything else was working nicely then I took it out for a drive and all the sudden I completely lost spark.
I fiddled with it for a while it finally started out of nowhere and was able to get it home. I started to look things over and I realized that the coil was on its last leg as per the specs from the Bentley manual and then it started to start again and then immediately die.
I unplugged the MAF sensor and it would run but poorly I cleaned the MAF sensor things got much better then it started to die again and not want to start... No spark
I started to delve into the ECU only to find out that it is a 25-pin ECU which to my knowledge means it's an LH 2.2 which is rather odd given that it's a 92. Also the MAF sensor is a Bosch 016 which is supposed to be for the 2.4, just an FYI there are six pens on my m a f sensor and five on the plug.
When the car will start I have 5 volts on pin 18 on my ECU FYI there is no wire going into that port. When the car does not want to start there is nothing there... As I'm typing this I just realized that when I tested the fuel relay it was working but the car would also start I have not tested the fuel relay while the car won't start maybe that's an issue, but I have typed so much here I will finish.
I can't read the serial number on the motor it's too worn but obviously (?) the ECU and wiring harness are not meant for this car as far as I can tell and the MAF sensor does not match the ECU.... So what would you all do?
I am thinking given the failures I may have a multitude of problems happening at the same time maybe a power issue from the ignition or maybe just a really bad ECU that's not even supposed to be in the car connected to a wiring harness that's not even supposed to be in the car. So should I just get the car running sell it and let somebody else deal with it or plug in a new ECU and MAF sensor?...I do not see alot af jankie butt splices and the like, so if this was a harness swap, it was done well(ish)...everything "looks" stock, I also have a ton of receipts...they paid >$450 on 3 separate occasions to replace the MAF sensor over 4 years...so money didn't seem like an issue and they were not doing it themselves.
I promised I looked before I asked...thank you in advance.
Toby
Toby
