Old 02-24-2021, 06:03 PM   #1
olov
doing something stupid
Default 93 940 aw71L - can you make it lockup?
my 940's overdrive is 99% gone, it will shift into it coasting, but any throttle it'll slip and downshift. I swear it burnt up after sitting in traffic double pedaling it one day(idle was too low). anyway, I got it to go into lockup last week, and it was great, rpm's were good, mpg's were good, and I could change speed easily. now I can't seem to get it to drop into lockup, I've ran it up to 90mph and lightly brought the throttle down and it just won't shift. I've tried a loose kickdown cable, and a tight one, it doesn't seem to do much other than make od slip more when loose. any trick to get lockup 100%?
just trying to get through the rainy winter to rebuild/swap it, and driving at 4500rpm on the highway is not my preference
Old 02-25-2021, 04:06 PM   #2
Khrrck
Professional Amateur
how's your trans fluid look? not low? pink and not burnt smelling?
gears 1 through 3 working OK - just 4th/OD and lockup not happy?
'87 240 budget wagon.
Old 02-26-2021, 01:25 AM   #3
olov
I did a change after that day in traffic, wasn't burnt but had disc material in it
like I said, if I get it into lockup, it's fine, OD is gone though. just trying to baby it till spring, would be nice if I could get it into lockup on the highway
Old 02-26-2021, 12:04 PM   #4
gsellstr
gsellstr's Avatar
OD is more vehicle speed related from what I've seen. You mention really light throttle and the OD will disengage...sounds more like the throttle cable isn't adjusted correctly or has snapped.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
