thebornotaku
( ͡° ͜ʖ ͡°)
- Nov 21, 2008
- Rohnert Park, CA
Use the sensor from the radiator, not the T fitting going to the thermostart
my radiator doesn't have a port for a thermal switch.
Use a Saab thingy. Works well. Reasons I can see for not wanting it to run anytime the car is running is 1 noise, 2 Life of the fan, 3 draw on alt (which is probably 70 amp in your car), 4 might keep the car from warming up as quickly
I was going to run a saab dealio.
Noise I'm not so worried about, and I'm not planning on running it like this for long. I just need to get my old rad out (well, it's out now actually) and I figured while it's apart, I could install the fan.
I also don't mind it taking a bit longer to warm up, as it's gonna be summer soon and I intend to have it wired properly within the next month or two.
any suggestions as to where I can get a saab sensor with a reasonable temperature range, like 95-90 or something instead of the 115-110 one I have?
Amazon has them, I posted a link for one but i think you could go up to the next step in temp
Well Your engine is going to spew out hot water out of the thermostat (assuming you have one) at its rated temp that your thermostat opens (again assuming that you have a thermostat that opens at a certain temp say 190') If your thermostat switch is placed before it goes to the radiator, hot water would continue to come out of the engine thermostat via the vent orifice causing the sender/switch to trigger the fan for a period of possibly 30 min or longer and cause a flat battery. (the fan can cause a drain of 15-25 amps. while in operation)
After the radiator is the best place for a fan switch.
After the engine is the best place for a Temp Gauge.
BECK/ARNLEY Part # 2010809 More Info
2 Prong Switch 92 Degrees, Standard Climates
BECK/ARNLEY Part # 2011545
2 Prong Switch 82 Degrees, Warmer Climates
Odd, it should still warm up fine as the temp switch should control the fan operation and that should matter little based on if it's wired as hot all the time or not.
This. I will be switching mine soon enough, I don't like it running all the time.Use a Saab thingy. Works well. Reasons I can see for not wanting it to run anytime the car is running is 1 noise, 2 Life of the fan, 3 draw on alt (which is probably 70 amp in your car), 4 might keep the car from warming up as quickly
I also wanted to add that if you get low on coolant, You could face a thermal runaway if water is not transferring enough heat to activate the sensor. Especially of your sensor is mounted on top and then the only medium of heat transfer to activate the switch would be steam. (or air at that point.)
Summery, and words of wisdom. Place it on the bottom of the radiator, with the switch being placed upside down ONLY IF YOU HAVE CLEARANCE TO DO SO.
Otherwise place the sensor according to the manufactures instructions. Oddly, I have came across a few that say that they work best being placed on top. Weird if you know how these devices work. Orientation IMO should not effect function.
Yea I've been happy with the way Alden and I have the system setup on our cars.
Ground through the SAAB thingy, sender in the lower hose and power to the relay.
I apologize for the basic question, but when using a 940 relay and the Saab sensor in the T-fitting will the temp sensor essentially be functioning where the ECU was before and sending the signal to ground? Am I getting this at all?
My conception is that there is one power to the relay, the harness from relay to motor can remain unchanged, and the Saab sensor will be wired from the yellow/brown wire to ground for high speed or from the green/orange wire to ground for low speed...
Are there any tradeoffs between running high or low speed?
If I am confused in my thinking, could anyone explain it to me in extremely simple terms?
Here you go:
When using the relay and the saab temp sender, ground one terminal to the chasis and the other terminal goes to the Green/ Orange wire on the relay. That is if you want the saab sender to run the low speed.
I keep my high speed on a toggle switch in the dash on my 240 incase I see high temps in Dallas here. The low speed has kept up with 103? here. I am using the radiator temp sender on the top of the radiator which is a little to warm for me. I will be changing that soon.
