242 2.3L Ecoboost 6spd Swap **Picture Heavy**
I'm building it in Washington, PA, but I live in the Dormont/Brookline area.
I say I'm in Pittsburgh. Really, I'm like an hour NW of the city. About as close to the actual city as I might get with any regularity would be if I end up taking a job in Cranberry. I sometimes also go to Forest Hills to visit some of my wife's family. So while it seems unlikely, I'm going to press on with the positive feeling that there's still a chance. :rofl:
I have family in the Cranberry area. Hopefully we can link up this summer.
Time for a quick update...
Added 3M paint protection film (shiny part) to certain sections of the cage to to save the paint from entry and exit wear.
Washed junkyard carpet and sprayed and brushed in between coats of SEM color coat in Landau Black. It's even darker in person.
Wrapped the downpipe in PTP's Lava wrap
*DRUMROLLS* Final wiring started!!
Mounting plate for new fuse panel
Great accessibility here
Decided to get a grounding block to organize the grounds and not stack them all under 2 screws. The bottom lug was connected with 8GA to ground. This will be the ground for most things on the dash. Using a separate ground for the stereo and instrument cluster. Any issue with that??
Even re-taped the accessory connectors
Using this bluetooth, marine Kenwood unit for the stereo system. Mounting the amp under the passenger seat
Regarding the quality of your grounds...... simply measure resistance from those junction points back to the battery NEG terminal. If you've got marginal grounds, you will see it on your Ohmmeter.
Ok, makes sense. I'll verify and update.
All good! Thanks
So work/non-car life has been kicking my butt lately, but progress has been made.
I'm putting some things back together
Doubled up some black speaker felt to cover where the old reels went.
Looks like it'll do
Made some thumb nuts for my VDO external temp gauge.
GPS antenna for the RaceCapture/digital dash integration. It comes with one, but it sits on your dash or magnetized to the top of the car. Seeing as though this will be an important system, I decided for something permanent and nice.
The wire from which will run down the roof and to the dash behind the filler panel to the RaceCapture module.
Getting dangerously close to the final design of the touchscreen panel. That'll be the next big update. Looking like I may be good for inspection and tuning by mid May.
Instrument cluster
It's all based arounnd this Raspberry Pi 3 in an aluminum case with built-in fans.
This board from Mausberry that safely power on and shutdown when the car is turned on and off.
I also mounted the entire case to the screen.
I made a quick and dirty surround for some earlier testing, but I ended up scrapping that
So I designed something better...
This will eventually get printed in the black heat resistant filament.
Instrument cluster is done!
Dropped of the wheels to get refinished. Sticking with the stock color.
These just arrived too...
Where we are:
-Wiring is done!
-Dash reassembly up next
-Carpet, seats, and harnesses this weekend
Hope to be getting my windshield next week and the inspection soon after.
