Old 11-24-2021, 02:36 PM   #1
QueenTheCar
Default Bleeding brake system without opening FR caliper valves?
The valves on my front right caliper (a brand new "Cardone" knockoff) are wayy to tight to open, even after trying heat and penetrating oil. There is hella air in the system from replacing all four calipers and the soft lines in the front. Is there a way to get enough air out through the other calipers for the system to be functional?
QueenTheCar is offline   Reply With Quote
Old 11-24-2021, 02:50 PM   #2
- Stock PSI Or Bust -
No.
how psi stock cna sprout?
Old 11-24-2021, 02:59 PM   #3
You have to cool the brass fitting with an ice cube after heating since non ferrous expands at twice the rate of ferrous.
Old 11-24-2021, 03:33 PM   #4
Mr. V
Mr. V's Avatar
I'd remove the caliper from the car and put it in a vise to try and work the stuck fitting off as stated above.
If it breaks you can either drill it out, re-tap it and put in and oversize fitting or simply toss it and buy a new one.
Old 11-24-2021, 03:55 PM   #5
cleanflametrap
cleanflametrap's Avatar
Isn't this about bleeder valves?
Originally Posted by QueenTheCar View Post
The valves on my front right caliper (a brand new "Cardone" knockoff) are wayy to tight to open, even after trying heat and penetrating oil. ...
Being hollow, I'm always afraid to put any slow brute force on these, so I will (in the case of the original 8mm bleeders) put the box end of an 8mm combo wrench on the bleeder valve and knock at the the wrench with a small ballpein hammer. Haven't broken one this way ... yet. Surely have the other way.
-Art
Old 11-24-2021, 10:46 PM   #6
Same principle but better odds with like materials.
Old 11-24-2021, 11:20 PM   #7
2turbotoys
Salaminizer
2turbotoys's Avatar
Return/replace the caliper as defective, Cardone will do that.
Edit: A Cardone knock off? How about buying a better brand? A Cardone knockoff is like buying the generic version of a generic version of something, don't do that
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 11-25-2021, 12:24 PM   #8
QueenTheCar
Makes sense! Made some ice cubes overnight and will try this after turkey.
Old 11-25-2021, 12:37 PM   #9
QueenTheCar
Is Cardone a reputable caliper brand? Pretty sure its the actual Cardone brand, which as it is is a knockoff of the Volvo ones.
I suspect they cast their own calipers instead of rebuilding original Volvo ones cuz the casting quality was hella blobby. Not only that but the bleeder valves use an odd size wrench somewhere in between 1/4 and 7/32. AND they make them too damn tight to open without destroying.
Don't buy Cardone calipers!!
Old 11-25-2021, 12:48 PM   #10
Default n00b
Furthermore you should have thouroughly & completely bled each corner after replacing components, otherwise you may get air stuck in the rear proportioning valves.
Bad juju very bad juju.
Old 11-25-2021, 12:54 PM   #11
And don't forget the cleanflametrap brake stick™ when you do have the system open.
Old 11-26-2021, 02:07 AM   #12
MasterBlaster
MasterBlaster's Avatar
Not only that but the bleeder valves use an odd size wrench somewhere in between 11/16 and 5/8.
Um... 11/16? 5/8? That seems awfully huge for a bleeder.
You sure you're trying to unscrew the right part?
Here's a Rockauto Cardone Reman RF caliper for a 1979 245 with vented rotors.
The center bleeder seems to be screwed into an adapter of some kind, possibly to repair previously stripped bleeder threads. If that's what it is, you do NOT want to unscrew it.
1990 740GL
536,000 km so far...
Old 11-26-2021, 03:44 AM   #13
QueenTheCar
My bad i misremembered the sizes
The size of the bleeder valves was actually somewhere between 1/4 and 7/32, without any adapter fitting.
I appreciate the research tho man!
After spending hours trying the ice cube trick to no avail I ended up bleeding the RF from the flare nut fittings where the mini hard lines go into the caliper: Open flare nut, press pedal, cleanflametrap brake stick™, close flare nut, release pedal, repeat. Now both front calipers seem to clamp down equally strong. (although the rears aren't great it should be enough to stop the car)
Mega pissed at Cardone for making their bleeder valves so stupidly tight that unscrewing rusted 43 year old ones seemed like a walk in the park.
Old 11-27-2021, 02:10 PM   #14
Radtap
Radtap's Avatar
Sure it isn’t 8mm?
Feedback
Radtap is online now   Reply With Quote
Old 11-27-2021, 03:32 PM   #15
Originally Posted by Radtap View Post
Sure it isn’t 8mm?
On OE brakes it is.
Old 11-30-2021, 06:45 PM   #16
MarioDrivesaBrick
At what point is this done when opening a brake system?
MarioDrivesaBrick is offline   Reply With Quote
Old 11-30-2021, 07:13 PM   #17
Before opening the system to prevent flow from the MC.
