everyhumanvovo
- May 4, 2009
Seeking best suggestions for smoke coming from oil cap in valve cover. Engine starts and seems to run relatively fine - do need to sync and tune SU carbs. Just replaced older PCV system as the car is a 64 with transplant B20. Replaced PCV system as a result of last fall engine suddenly coming to semi-abrupt poor running condition. First I thought it was starved for fuel from clogged fuel filter. Then found there was oil pushing out from many places and a leak. Replaced about a quart over a month and attempted drives and fixes. Thought issue was clogged PCV system which looked good overall - hoses, etc. not clogged, but could not see in slim sandwich adaptor used between front carb and manifold, so thought this may be issue. Now thinking it may not have been clogged at all. Now think I may have caused carbon breakup using some modern semi-synthetic oil since last spring, which has caused a stuck piston ring or other. Last week, it started and ran for a 10 minute drive, but then smoke coming from oil cap filter. Reverted last fall back to natural 10w-30, still looks golden brown without sign of metal. Was told it may be gas getting into oil from flooding with out of tune carbs (choke open and pumping or holding to start when cold - ambient 50 F.). Or, if stuck piston ring may be able to drain some oil and add quart of Marvel Mystery OIl or a decarboniszer to loosen the piston ring. Have to do compression test, but still cold outside. Any insights greatly appreciated!!
