Old 07-16-2021, 04:39 PM   #1
OldCarNewTricks
OldCarNewTricks's Avatar
Default Middle Ground Suspension
Hello,
At some point soon, I will be replacing all the bushings on my Volvo 242. I live in Oregon, in an area that has plenty of potholes and cracked roads. I would like to have a fun but not to the point of shaking myself to death on these roads sort of suspension.
I have old Bilstein HD shocks on the rear that seem to be just fine, and stock springs. The front sway is an 18mm, the rear is 19mm. I have Virgos wrapped in 205/60r15.
The front struts are worn, and should be replaced, I think. I have the upper and lower chassis braces to go on, as well.
I am wondering what suspension set up would get me to that goal?
OldCarNewTricks is offline   Reply With Quote
Old 07-16-2021, 04:54 PM   #2
23mm Turbo front bar, billies, and IDK what to do for strut bearings anymore.
OG Volvo used to be good but at $100 a pop TBers wimped out, bought the 15A plates and lived with the whipped out originals.
how psi stock cna sprout?
Old 07-16-2021, 04:58 PM   #3
culberro
culberro's Avatar
Basically this. 15a plates and new strut mounts, or BNE Select top mounts.
Fresh rubber in the axle, torque rods, and rear front control arm. Leave everything else alone because it's probably just fine.
My last DD 240 was setup like that, and I'm kicking myself for getting rid of it. The new DD is full IPD suspension and it's not nearly as good for 90% of the driving I do.
Old 07-16-2021, 05:08 PM   #4
OldCarNewTricks
Sweet! I forgot to mention I do have 15A plates to install, as well. My strut mounts are cracked and really need replacement. I was going to do aftermarket with the plates and call it good.
Would Bilstein HD be a good setup for the front to match the rear (as opposed to the B4 struts). I don't find the rears to be super harsh anymore, but with how destroyed all the rubber is back there, it's hard to tell.
Is the best way to find a 23mm bar to post a wanted ad?
Thank you
Old 07-16-2021, 05:11 PM   #5
culberro
culberro's Avatar
I like stock HDs in the front, if you have an ABS car they can be a pain/compromise to install.
I'd just keep the stock bars on for now, and then add a bigger bar up front if you think you still need it after all the bushing and strut changes.
Lower crossmember supports and a strut bar are probably going to yield better handling and performance than a larger front bar.
Old 07-16-2021, 05:14 PM   #6
Thank you
Carl might have one unless he sent it away to the crusher.
Old 07-16-2021, 05:22 PM   #7
OldCarNewTricks
Okay, B6 HD struts will be what I go with. My car is an 83, so no ABS to deal with here!
My front sway bushings are destroyed, or perhaps too large. I would probably be fine with some bushings for now, but I'm not sure where to find 18mm replacement bushings.
Old 07-16-2021, 05:23 PM   #8
OldCarNewTricks
RIP
Old 07-16-2021, 05:30 PM   #9
culberro
culberro's Avatar
That car has been picked clean by the vultures, and the man himself
He trolled everyone with that "euro" grill though, I wonder how many people went to go pull it only to realize how TB'd it was.
Old 07-16-2021, 07:01 PM   #10
Bet none of you buzzards would even give him JY price for a stock sway bar so he should still have it.
Old 07-16-2021, 08:19 PM   #11
culberro
culberro's Avatar
Don't lump me in with the birds. I actually pay real money for parts when needed
Old 07-16-2021, 08:24 PM   #12
shoestring
shoestring's Avatar
Amen. I might be on Turbobricks, but not on a Turbobricks budget.
Mostly.
Old 07-16-2021, 08:26 PM   #13
OldCarNewTricks
I've put far more money towards this 242 than it probably deserves, but it's more than "just a car" to me! I'm doing my best to "refurbish" it before driving it often.
Old 07-16-2021, 08:29 PM   #14
2manyturbos
That’s the same Volvo story for any old RWD Volvo. Welcome to the club.
Old 07-17-2021, 12:29 AM   #15
The Librarian
Are you sure it's 18mm? It's not a size that was used in '83.
VP offers aftermarket and OEM but the OEM aren't in stock.
https://vp-autoparts.com/en/artiklar...78-rubber.html
https://vp-autoparts.com/en/artiklar...-rubber-2.html
https://www.tascaparts.com/oem-parts...ushing-1205697
Old 07-17-2021, 12:46 AM   #16
OldCarNewTricks
Yes, I measured it with my digital caliper multiple times as I was very confused. Many parts of this car have been swapped over time, as it was originally an M46, 1030 axle car, and was swapped over to AW71, 1031 axle later on. I wouldn't be surprised if some other parts moved in from another car.
I'll check once again before ordering bushings, thank you for the links!!
Old 07-17-2021, 01:04 AM   #17
2manyturbos
The 23/21 Turbo bars make for a nice handling daily driver. Also, a set of the GT spec front springs. Supposedly you can still buy those aftermarket new. Do not use any poly bushings. You will regret it.
Old 07-17-2021, 09:43 AM   #18
OldCarNewTricks
That setup sounds spectacular. I started a wanted thread, fingers crossed. I'll take a look around for those GT springs. As for poly bushings, I've decided against using them on this car, although my Camaro has full poly all around. I may actually undo some of the front end poly stuff on my Camaro.
Old 07-17-2021, 01:43 PM   #19
OldCarNewTricks
https://www.fcpeuro.com/products/vol...jofors-1229337
These look to be the HD equivalent to the GT springs, is that correct? Looks like they are 13.50mm instead of the 14.20 or 14.80mm the GT cars came with.
How are they in comparison to OE springs? https://www.volvopartswebstore.com/p...9/1229337.html
Old 07-17-2021, 03:38 PM   #20
My car is fun hp club
The FCOEuro 1229337 springs were about 14.2mm when I measured mine. I've been using a set on the front of my wagon for over 200k miles. They work great and provide a firm controlled ride that is still comfortable.
Old 07-17-2021, 03:42 PM   #21
OldCarNewTricks
Excellent. And just to make sure, they are the same ones I have linked, the Lesjofors 4095801?
Old 07-18-2021, 10:10 PM   #22
Unless the lesjofors spring is made of some type of better spring steel. The 13.5mm spring is not the same as what I have. I have what is in the link to the Volvo web store spring. Mine were 14.2 mm like that listing.
Old 07-18-2021, 10:38 PM   #23
1979 GT is the ONE year only 240 model with the 4 cylinder stock ride height 14.2mm Ø front springs.
It's also the only 240 that came with a larger [23mm] rear bar than the front.
Edit;
And strut tower reinforcing plates for the thicker springs.
Old 07-18-2021, 10:53 PM   #24
mikep
The MP
mikep's Avatar
Not me, i know what you/yinz/y’all have.
Steel is steel is steel.
For torsional modulus.
Sway bar spring haiku.
Old 07-18-2021, 11:12 PM   #25
OldCarNewTricks
I figured they were the thicker ones. I don't know if FCP offers the 79 GT springs anymore.
