Old 01-25-2021, 11:28 PM   #1
mschultz373
mschultz373's Avatar
Default strut rod nut and sway bar bolt
does anyone have the measurements for the 940 strut rod nut AND the bolt for the sway bar end line that bolts into the knuckle?
thanks.
strut-rod-bolt
sway-bar
mschultz373 is offline   Reply With Quote
Old 01-26-2021, 03:25 AM   #2
Fa182
Stage 1
Fa182's Avatar
I believe the nut is a standard M14 and the bolt is a M12x45mm
p/n's below:
https://www.tascaparts.com/oem-parts...ock-nut-985660
https://www.tascaparts.com/oem-parts...e-screw-982842
Old 03-30-2021, 07:25 PM   #3
mschultz373
what's correct installation for the strut rod bolt? Lost my driver side bolt on a turn yesterday. I was using a hardware store locknut, tried to get it as tight as I could. Locktite??
Old 04-01-2021, 02:34 PM   #4
That hardware strore locknut may not be the higher grade of steel needed for the application. I'd suggest buying the genuine part if you don't have a local supplier that can sell you grade 8 metric hardware. It may even be a grade 10 piece of hardware. The bolt and nut should be torqued to spec with the weight of the car on the suspension. Probably something like 65-70ftlbs.
