Old 02-18-2015, 02:39 PM   #1
REDBLOCK
REDBLOCK's Avatar
Default B230FK timing advance
What is the stock timing advance at full load on high rpm's?
REDBLOCK is offline   Reply With Quote
Old 02-18-2015, 06:09 PM   #2
turbotankshane
At WOT
15 deg @ 3k rpm
22deg @ 4k rpm
25 deg @ 5k rpm to redline
turbotankshane is offline   Reply With Quote
Old 02-18-2015, 06:18 PM   #3
eabras
http://forum.vccn.no/showthread.php?...l=1#post838273
eabras is offline   Reply With Quote
Old 02-23-2015, 04:25 AM   #4
ThomasJ
Is there any difference between stock B230FT timing at WOT? What is the timing using EZK chip? I'm using piggy back unit but its little more than regular piggy back because injectors are also control by the piggy back. You can call this micro standalone? I push 1,1 bar (16psi) from 19T turbo and above 4500rpm I can hear pinging. Now I know than stock timing cannot handle this. Its about 10deg to much advance.
ThomasJ is offline   Reply With Quote
