Old 01-28-2021, 01:00 PM   #1
esmth
Default IPD Stainless NA 240 header pipe
Has anyone gotten one of these:
https://www.ipdusa.com/products/1654...171285-1346768
I am curious about the tube diameter at the end. I have a 2.25 universal aftermarket cat i'd like to use and plan to replace the flange on the pipe with a v band.
Also I am curious about the quality/welds. Any additional info would be appreciated. Thanks!
1991 244 LH2.4 M46 352k miles
Old 01-28-2021, 01:20 PM   #2
volvowagoon
volvowagoon's Avatar
I was kinda curious about getting one simply for the cockroach survivability. My original one started leaking right at the merge. IPD isn't shy about telling you that this is Chinese, so I'll bet that the welds are not back purged. I've seen some very expensive Chinese stainless headers with terrible sugaring and blockages. I'm not betting that any of the mild steel ones are made better, but for the added cost of this particular part I'd be disappointed to find flaws like that. Hopefully somebody will share some actual experience with this particular part.
1986 Buick Grand National - Restoring to stock™
2010 C30 T5 - The boring but trusty daily - 192k
1989 245 DL - The boring but not trusty daily - 226k
IG: @v6buick
Old 01-28-2021, 03:07 PM   #3
shoestring
shoestring's Avatar
I wouldn't spend the money on a V band for that. Cut the flange off, get a Torca clamp that's the right size and rip it.
Old 01-28-2021, 03:34 PM   #4
Cwazywazy
Single jingle
Cwazywazy's Avatar
V bands make you go faster.
I don't know what I have
Old 01-29-2021, 10:21 AM   #5
esmth
Well, I bought it. If I remember, I'll update this thread with pix. I hope the 2-1 merge isn't bad like most of the aftermarket pipes look to be.
Old 01-29-2021, 10:33 AM   #6
white855T
V- bands are cheap. Why wouldn't he do it? It will make removal easy.
Old 01-29-2021, 12:23 PM   #7
shoestring
shoestring's Avatar
Not as cheap as a reuseable $7 clamp that needs no welding and causes no pipe damage.
Old 01-29-2021, 12:54 PM   #8
Stock pipe size for the n/a cars is 2". I use one of the lap joint sleeve clamps on the join between the front muffer and the pipe out of the cat. Works great and they are cheap at summit racing.
Old 01-29-2021, 12:56 PM   #9
volvowagoon
I've actually had terrible issues removing the V-bands in my Camaro. If you don't line your pipes up perfectly when you're fabbing the exhaust, any sort of bind you put that joint will make removal a bear. I have to pry my clamps off with screw drivers sometimes. Plus, you don't have to cut or reweld anything when road debris gets knocked up and damages a torca clamp.
Old 01-29-2021, 12:59 PM   #10
volvowagoon
Regardless, I look forward to pictures of the part and and how well it fits!
Old 01-29-2021, 01:03 PM   #11
white855T
Pipe damage from what? Small price to pay to make to header pipe easy to remove.
Old 01-29-2021, 01:16 PM   #12
esmth
I have had stainless V band clamps and flanges on my current exhaust for 2-3 years now and they come apart and re seal effortlessly every time. I personally think the slightly higher price is worth it.
Old 01-29-2021, 02:23 PM   #13
shoestring
shoestring's Avatar
From a clamp that would crush the outer pipe to form a seal. We (and so do many manufacturers) use a sleeve-type exhaust clamp that butts 2 pipes of the same diameter together. They are durable, long lasting, and very easy to use. I only recommended it because the OP expressed some concerns about the quality of the pipe he's buying. I am not implying that V bands are inferior, and if that's your preference, that's what you should do.
Old 02-01-2021, 01:53 PM   #14
go240go
I've had one for about a year. Decent quality, good fit, nice that it's stainless, no leaks at the welds, appears to be holding up well. Diameter at the flange is 2", designed for the stock cat size. Prob would make most sense by adapting 2.25" starting at the 2-1 collector.
go240go is offline   Reply With Quote
Old 02-01-2021, 03:30 PM   #15
cmsuter
I bought one and have yet to install it. Really looking forward to it.
cmsuter is offline   Reply With Quote
Old 02-11-2021, 09:59 AM   #16
esmth
I got it the other day. Here are measurements:
The big pipe is not a perfect circle it seems, sort of oval that changes diameter during the bends near the exit. it ranges from 2.325" OD at the collector to 2.2" at the straight and 2.175" at the bend. The ID of the pipe at the exit is 2.1". The pipe is 0.050"-ish thick.
The small pipes are 1.675" OD and 1.575" ID.
Length from entrance flange to merge is 24" and from merge to exit flange is 22".
Exit flange itself is 2.25" ID and distance from hole to hole is 2.75". It is 0.375" thick. The fastener holes are 0.425" diameter.
Considering typical IPD markup it is pretty okay quality but it does have some considerable flaws. The major being not much of it is square to itself. The entrance flange isn't square to the dual pipes, the big pipe is not square to the dual pipes/merge (is this normal for 240 header pipe?) The bellhousing mounting bracket plate thing is not square to the pipes, the nuts on said plate aren't directly under the holes etc etc etc but I am being nit-picky.
(click to embiggen)
Old 02-11-2021, 10:24 AM   #17
volvowagoon
I dunno man. That looks atrocious even for China standards. Is that dual pipe flange tacked with a MIG welder? So much for stainless! All that junk inside is not something I'd want to be running through my catalytic converter either. I have some drier vent clearing brushes that I use for exactly that. I'm glad I didn't waste the money on these pipes though. I've had really good luck with cheap Walker brand pipes anyway.
Old 02-11-2021, 11:06 AM   #18
esmth
it is par for the course compared with the other IPD exhaust stuff
if it bolts up i'll be satisfied
Old 02-12-2021, 12:12 AM   #19
wolf_walker
I guess for the money this isn't bad, what would a nice one done right cost, $500? $700?
I'm sure IPD or a few others could make it happen but nobody would buy it.
One more Radar Lover gone..
82 VW Caddy AAZ, 400K
wolf_walker is offline   Reply With Quote
Old 02-12-2021, 08:57 AM   #20
Broke4speed
Broke4speed's Avatar
Agreed. I'm pretty sure the added cost here is just for the longetivity factor. NOBODY would buy a header pipe that was non-china stainless, with absolutely perfect TIG welds because it would be ridiculously expensive. ESPECIALLY considering it's for a non-turbo car. That'd be flushing money down the toilet.
1984 244/ AQ140A / M46
Old 02-12-2021, 10:19 AM   #21
esmth
Some additional things I have noticed staring at it for another evening:
* the smaller plug has no stop/backing so if can screw all the way through the threaded boss. There is no way to secure it the way it is. (what is this even for? back-pressure gauge?)
* where the merge is, there is like an inch of extra pipe not trimmed internally that I cannot get a good picture of. I'm not a flow guy but it doesn't look like it helps.
Before I decided on getting a cat I bought this: https://www.summitracing.com/parts/big-95000flt
I plan to have it welded in the collector anyway and just have it plugged for now. While i'm in there i'll try to clean up the extra untrimmed pipe with a burr. It might not help/do anything but it'll keep me occupied at least.
Old 02-12-2021, 10:27 AM   #22
shoestring
shoestring's Avatar
My factory downpipe has this port but it's got a flanged screw to plug it. I'd imagine there's a gasket there too. I imagine it is a cat failure test port leftover from bygone days.
