Old 04-21-2021, 03:51 PM   #101
holtzboy
Still have my first car
holtzboy's Avatar
Looks like fun! I am looking into Delrin bushings for the Vette, it doesn't seem too terribly difficult to pop off the 8 A-arms and press out old then press in new. I will see if it's still difficult to shift 1st to 2nd and look into engine/tranny/diff mounts at that point.
1. '86 244DL- 1st car & owned for 18 years, 500k miles, 94 B230FT mild build in the works
2. '93 244DL - Daughter's DD, mostly stock with Hydras
3. '07 Vette Z06 - Early mid-life crisis vehicle
4. '17 CRV - Boring DD
My feedback thread
holtzboy is offline   Reply With Quote
Old 04-21-2021, 04:03 PM   #102
You should bring it out to one of the upcoming events. Either SCCA Oregon Region or when WMC runs at the Evergreen Space Museum. It will give you a chance to drive it like it was intended to be driven without getting arrested.
Old 04-21-2021, 05:00 PM   #103
R32RennSport
Outlaw Amazonian
R32RennSport's Avatar
I was invited back to drive my buddies 1970 911 RS clone for the 2021 PCA season. We took it to a shake down event over the weekend and boy was it a kick in the pants. I hadn't driven the car since 2019 and I forgot how brutally quick the car is and being analog everything it is quite involving to operate. He has the car setup beautifully though, it's one of the easiest cars I've driven at speed, it does everything you want it to do. For those interested it's a 3.2 twin plug, 11 to 1, roughly 300hp to the wheels and tips the scales just under 2100lbs. We were running on DOT 200 treadwear tires for the shake down and I walked away from the field of 60+ cars including some great drivers I know in newer cars with stickier rubber! Taking TTOD was a pretty sweet result to say the least!
The course workers loved watching the car! I would go from slip angle counter steer to lift oversteer and then the car had so much grip when it would hook up at corner exit it would lift the front outside tire a few inches off the ground! Such a blast and an intoxicating intake/exhaust note!
Steven
1966 Outlaw Volvo Amazon, 2004 VW R32 Golf
Old 04-21-2021, 05:34 PM   #104
That's awesome. Those aren't easy cars to drive near their limit.
Old 04-21-2021, 06:04 PM   #105
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
https://youtu.be/jS6SarW07u8
Went last weekend. Was wet for the first half of the day and I did well. Ended up some 26th of 47 before it dried up, then fell about 10 spots in the dry. I suspect my car is set up better for bad weather than a typical autocross car as I saw many spins and didn't seem to have much issue controlling slides/determining when I was going to lose the front or rear.
In the dry weather the usual lack of roll stiffness and easily overwhelmed front tires returned. The car was still easy to drive but I had to remind myself to be patient and only do one thing at a time.
I sell chips for LH 2.4!
Old 04-21-2021, 08:19 PM   #106
R32RennSport
Outlaw Amazonian
I forgot to post this in here, maybe I only posted it in my build thread but I did take out my Amazon out last year for just fun runs. I have since added a limited slip to the rear end so I'm looking forward to taking it out for fun again at some point this year when I'm not driving the Porsche 911.
https://youtu.be/Laa6aBF4hLw
Old 04-21-2021, 09:56 PM   #107
People love seeing vintage iron out racing. That's cool. We used to have a club member that ran a 122 and his friend ran a 444. The 444 had a suicide knob on the steering wheel so he could attempt to turn it fast enough to keep up with the course.
Old 04-21-2021, 09:58 PM   #108
You have the correct pedal down. Wait until you get some real tires. Then, things will change dramatically.
Old 04-26-2021, 05:07 PM   #109
Another weekend, another "Autocross". A friend of mine coined the event the Trackcross. Our club came up with an idea of combining a road race course with an Autocross. The first one was last year. I didn't go because the date was moved so many times due to Covid restrictions and it ended up on the same weekend as a points event for another club I race with. I registered for both days. It was a combined event with the club I am a member of running clockwise on Saturday and another club I race with running counterclockwise on Sunday. Normally, that would make no difference. At ORP, it is night and day. This track is 2.3 miles long and deliberately has major elevation changes and countless blind corners. It also was designed with very well thought out run off areas to keep damage minimized if and when a driver makes a mistake. I have run one track day there and have the counterclockwise direction pretty well memorized. I got there Friday night and stayed in my camper so I would be all rested and on site for the 7:00 AM start of activities. It's over 4 hours from my home to ORP. I woke up Saturday with a heck of a head cold. Headache, running nose, aches and pains and no memory. I had a heck of a time trying to memorize the track. My 6th run I was finally confident enough to push the car a bit and dropped 7 seconds. My 7th and final run I dropped another 2 thousandths of a second. I placed OK overall, yet, was way off my game. It was cold, rainy and very windy Saturday. By 10:00 that evening I came to the conclusion I would not be a good idea to run Sunday. Driving on the edge at this track is begging for an off if you aren't thinking clearly. At least 10 cars each day went off the track into the weeds. Some sustained minor damage. Nobody was hurt. I didn't want to be the guy that ran at his limit and rolled my car because I was driving impaired. I also didn't want to have to work the course in 36 degree weather with high winds and possible rain. I let the club president know I was wanting to give up my space for Sunday so someone on the wait list could run. It was a good choice. My car is still in one piece and I'm feeling quite a bit better today. I stuck around for part of Sunday so I could take pictures of all the club members making their runs. We even had a guy with a S60 R wagon running with us. Anyway, here is one of my fastest runs from Saturday. And, the top PAX run of a friend of mine that runs a 2015 Mustang GT in CAM C and is one of the top drivers in the NW. He has been a National Champion Solo driver and it shows. He is almost always top time of day and if not, top PAX of the day. On a good day at a typical Autocross, I can usually get within 1-2 seconds of his time. At ORP, he is right at home, I don't have an ice cube's chance in hell of coming close to his time. The other video is another friend of mine that runs another 2015 Mustang and won top honors last year in the Optima Battery Street car challenge. His GT makes something like 650 HP and is a hoot to watch run. The only problem is it is a money pit to maintain. I like running my F-Street Mustang because it costs me about $2000 per season to keep it in top shape.
My best run Saturday.
Steve Wynn's top PAX run. He had just been to an all day track day at ORP the previous weekend. He usually instructs at those events.
Dennis Healy at the Optima Battery street car challenge last month. This is Autocross on steroids.
Old 04-27-2021, 09:37 AM   #110
mr brick driver
Wow. Looks intense. Not for a first timer.
1992 745 TI+ anti slip differential, 1983 242 DL, 1990 780 Bertone, 1983 242 Group A X 2
mr brick driver is offline   Reply With Quote
Old 05-02-2021, 06:32 PM   #111
Beep beep zip tang
Run 1 today
My fastest time:
Last run, loosey goosev around Gilligan's Island:
t
Old 05-02-2021, 09:13 PM   #112
Run 1 was Gymkhana, right? You were supposed to back into that element. It sounds like your tires are rock hard now. Not a lot of grip.
Old 05-02-2021, 10:14 PM   #113
Beep beep zip tang
They are, I was playing around with tire pressures, it seemed so crisp on the road at 40psi, I started there and dropped them every run. Fastest time was 35psi, I used to start at 26.
