Old 05-05-2021, 12:38 AM   #1
BeaverMeat
BeaverMeat's Avatar
Default 5.0L intake
The intake and MAF have been just laying there unsupported for about 19 years now... well, the MAF is supported by the wiring harness and coolant reservoir. The alternator supports the filter... it’s sh!t anyways. I think it’s about time to fix this sloppy intake scenario.
I dislike these “hot air” intakes... Not going to “upgrade” to a metal heat-soaker.
Been thinking of jamming an OE fox body air box in there... have the air suckulate from the bottom front corner under the washer tank. IDK.
Any suggestions?
What are the good high pressure zones under that 240 hood?
She’s built like a steakhouse but, she handles like a bistro.
BeaverMeat is offline   Reply With Quote
Old 05-05-2021, 02:03 AM   #2
K9 240
K9 240's Avatar
Hi
I moved the washer bottle to the rear (butt cheek) and drilled a 3 inch hole where it was to the space in front of the front wheel. There's enough room there to get a properly sized air filter in. Even used a grill to make a cover underneath it.
Tim
Old 05-05-2021, 12:48 PM   #3
kyote
Living The Dream
kyote's Avatar
Look at my project thread, you can maybe use a KJET Turbo Airbox and make a custom top plate. Would require relocating washer bottle.
Old 05-05-2021, 01:39 PM   #4
BeaverMeat
BeaverMeat's Avatar
Or just a smaller bottle...
Was thinking of relocating the batt the the butt and moving the washer tank where the battery was.
Old 05-05-2021, 01:59 PM   #5
I made a simple aluminum bracket that bolts under the washer bottle and connects to the mounting brackets on the MAF.
And my simple bracket, I mean some 1" wide flat aluminum bar that I bent in the vice.
Old 05-05-2021, 04:08 PM   #6
BeaverMeat
BeaverMeat's Avatar
That’s my style.
Thinking about getting one of these “bucket” style intake boxes and drilling a hole in the fender well... or just have the filter in the fender well if it’s accessible.
Staying away from a K&N as the oil is messing with my MAF. Plus I don’t like the bolt-on cover. There is a brand that makes one with clamps but I can’t recall who made them. They were popular with the Aussie Miata crowed.
Old 05-05-2021, 05:17 PM   #7
Those just look like a fancy tractor air filter....
There are some large paper element filters, as well as a bunch of washable non-KN filters out there.
Old 05-05-2021, 05:58 PM   #8
BeaverMeat
BeaverMeat's Avatar
Always been a fan of the HKS Superfilter design. Compact and effective. Easy to clean/change.
Old 05-05-2021, 06:07 PM   #9
There's also:
https://greenfilter.com/universal-cylinder
https://www.aemintakes.com/search/universal
Old 05-09-2021, 08:44 PM   #10
BeaverMeat
BeaverMeat's Avatar
I think I have it cased. Go with a 240 Turbo coolant reservoir (if it’s compatible with the bigger diesel rad) and washer tank. Possibly an airbox too.
Old 05-10-2021, 09:41 PM   #11
mikep
The MP
mikep's Avatar
Came for the tunnel ram, was disappointed.
Fun fact - bats having an extraordinary appreciation for sound and frequency are well known fans of Bose 901s and I have a feeling that's why it came into the house to begin with, it definitely stayed in the "sweet spot" throughout the visit...
Old 05-10-2021, 11:02 PM   #12
Holley does have a few versions for the 5.slow now. I may need to investigate
Old 05-10-2021, 11:04 PM   #13
BeaverMeat
BeaverMeat's Avatar
lol.
I’m going to the “looks factory”... look.
The K-Jet will work nicely. Larger than the stock Fox box. Will have to upgrade to a 70mm Ford MAF to match the 70 BBK throttle body. Then ad hoc some pipes with an adapter to the airbox. Slap on a cone filter and I’m done.
The only problem is the pipe to the airbox from the behind the grill is a tad too small for the five-oh flow.
I believe for the box to work properly all the air has to be fed from original location. I suppose I could enlarge the port and make a larger oval hole beside the rad and cram as much pipe as I can in there... or. I could enlarge the port and run a splitter to run second pipe to the fender well that is an equal length and diameter to the OE one.
Old 05-11-2021, 07:44 AM   #14
740atl
rb67 life
740atl's Avatar
I'm not really sure what you're after here. Your current intake is working yes? You don't like it because it's plastic and sagging, but you don't want a metal pipe. If you're looking for more power, the only place you're going to get that is with lift or boost.. If the intake is functional then your 'problem' is solved. Move on to something else. If you just want to make it look prettyerer, and talk a lot about it without actually doing anything, then by all means, continue.
Old 05-11-2021, 12:25 PM   #15
BeaverMeat
BeaverMeat's Avatar
Improve the intake. Yes, it works. Just not optimum.
