Old 03-26-2021, 02:45 PM   #676
stick70
All the gauges
stick70's Avatar
I hear he looks at it and occasionally cries into the accumulated dust
Kyle and the "Projects" -- '84 242 TI -- '66 220 S -- '60 Coupe DeVille -- '84 Rabbit GTI
Old 03-27-2021, 06:21 AM   #677
Quin
ಠ_ಠ
more than occasionally
Old 03-27-2021, 09:23 AM   #678
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
F's in the chat for the unfinished everproject
Old 03-30-2021, 02:21 PM   #679
vwbusman66
Stößelstange über alles
vwbusman66's Avatar
bump
1971 142 beater
Originally Posted by propav8r
The incest is implied.
Old 04-06-2021, 09:47 AM   #680
vwbusman66
vwbusman66's Avatar
ttt
Old 04-06-2021, 09:55 AM   #681
doucheNozzle
doucheNozzle's Avatar
Dingle
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'11 XC90 V8 - Torque Monster
Old 04-11-2021, 08:01 PM   #682
Fast740fromSC
Fast740fromSC's Avatar
Fast740fromSC is offline   Reply With Quote
Old 04-11-2021, 08:13 PM   #683
AndrewNance
Amateur hour!
AndrewNance's Avatar
This car got crushed...
'67 122 - b230, t5, 8.8
Feedback
Old 04-15-2021, 02:34 PM   #684
Jared's asking about 240 ball joints and tie rod ends on FB.
I CALL SHENS!
Old 04-23-2021, 05:19 PM   #685
stick70
All the gauges
stick70's Avatar
It's a ruse
Old 04-23-2021, 11:19 PM   #686
DNAsEqUeNcE
†John3:16
F's in the chat
Old 05-02-2021, 09:19 PM   #687
propav8r
F*ck Edgar
propav8r's Avatar
Radiator, u-joint flange, ball joints, tie rods are ordered. Looks like the 15th is gonna be a workday to pull the old busted HVAC crap with a leaking heater core out of the dash and replace it with a non-leaking heater core and 90+ HVAC unit. I'd like for this car to have AC at some point, and the upgraded heater box will be nice in general.
Gonna get real likkered up on the 15th and just cut the lips off the rear fenders. I hate cutting sheet metal on this car. Idk why it's such a big deal to me. It's kinda dumb, not like it's in particularly good shape or anything.
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
Originally Posted by VB242 View Post
Space time farts
My Project
K-Jet to Megasquirt Article
Old 05-03-2021, 10:40 AM   #688
vwbusman66
vwbusman66's Avatar
"How to best make sure your trimmed lips don't come out straight"
Old 05-03-2021, 05:39 PM   #689
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
Pics or ban
94 944 + lots of stuff http://forums.turbobricks.com/showthread.php?t=354303
Old 05-04-2021, 09:48 PM   #690
propav8r
F*ck Edgar
propav8r's Avatar
So I about had a ragequit this evening. When I first put the slip yoke in ages ago, it was a super tight fit and I had to tap it home with a rubber mallet. Once it was in, it didn't really want to turn without a LOT of effort. Not good.
I had hoped it was due to the use of a yoke that was designed to be a snug fit from Midwest Chassis as a lot of GTO guys have driveline vibrations from the yoke having a sloppy fit.
I ordered a GM replacement yoke and it also didn't go in easily.
I was fighting mad that the output shaft was twisted or bent. Once I looked in with the flashlight, I realized that the spring in the seal had come apart and gotten jammed between the yoke and the bushing.
So the tailhousing has to come off and a replacement bushing pressed in. Not the end of the world. The fancy yoke has some light marking, but I think it's fine.
Old 05-04-2021, 10:01 PM   #691
KwikBrik245
KwikBrik245's Avatar
Sounds like you will be ok in the grand scheme of things. I'd have freaked out thinking I bent the output as well haha.
Daily: '91 245, B230F/M46 P-type, '93 Dana 30
'88 744, Twin Turbo LS1/T56, Grizzly locked Dana 30.
KwikBrik245 is offline   Reply With Quote
Old 05-04-2021, 10:42 PM   #692
propav8r
F*ck Edgar
propav8r's Avatar
I was mostly worried because the wagon this motor/trans came out of had a driveshaft failure at a high speed. I've been paranoid that it's got a damage trans or diff since I did the install.
Old 05-06-2021, 03:52 AM   #693
Quin
ಠ_ಠ
i completely forgot it actually got swapped.
Old 05-06-2021, 09:00 AM   #694
KwikBrik245
Reasonable concerns to have given the circumstances. Will you have the car ready for Mountain Meet?
Old 05-06-2021, 09:25 AM   #695
vwbusman66
vwbusman66's Avatar
I am wholeheartedly expecting a lineup of 3, if not 4 (Jared's, yours, JohnMC's, and Kenny's) LS powered cars doing some kind of in-unison burnout during the weekend.
Old 05-06-2021, 09:39 AM   #696
I'm thinking I might bring the turbo Miata down this time.
Old 05-06-2021, 09:58 AM   #697
AndrewNance
Amateur hour!
Probably the best choice for that part of the state. There’s hardly a straight enough road to let a turbo LS do it’s thing.
Old 05-06-2021, 10:03 AM   #698
KwikBrik245
Plenty of straight roads on the way from Cleveland
Old 05-06-2021, 04:21 PM   #699
MikeSr.
What, me worry?
MikeSr.'s Avatar
My LS swapped 242 will be there, as long as It can make it thru Franklin this time.
I coulda had a V8!
Old 05-06-2021, 04:28 PM   #700
Yeah, on the drives it was a matter of taking it easy around the corners, seeing a straight and vROOOm, OK, now we're at the end of the straight already.
I'd *just* gotten it together then. A couple of hundred miles of shakedown drives, then off to MM.
So yeah... if anyone wants to head to Deals Gap this year...
I'll probably go that way on the way home at the very least.
