Old 06-07-2011, 01:07 PM   #1
Roy 940
Default IPD Turbo cam vs. V cam
Hi all,
as said in the title, what can I expected about torque and power gain with the IPD Turbo cam vs. the Volvo V cam?
My complete setup is in my sig...
Thanks for the comments and reply!
Alex.
project Blue is Better
http://forums.turbobricks.com/showthread.php?t=247082
Roy 940 is offline   Reply With Quote
Old 06-07-2011, 02:45 PM   #2
doucheNozzle
doucheNozzle's Avatar
Do you already have the Turbo cam?
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'11 XC90 V8 - Torque Monster
Old 06-07-2011, 03:08 PM   #3
7mgtesup
He already has the V cam. I think he is asking what gain will I see with IPD turbo cam over V cam? Is it worth the money as an upgrade?
Roy940: how is the V cam compared to the T cam? I have just put a V cam in mine but can't drive it yet as have loads of stuff to do first. Does it pull harder up top? How much is lost on the bottom?
Cheers
Paul
Turbo lag is the moment the car next to you thinks he's going to win.
7mgtesup is offline   Reply With Quote
Old 06-07-2011, 03:12 PM   #4
Roy 940
Sorry, I forget to say that:
I run now the "V" cam, and I feel it run very well past 3800 RPM, but it's sluggish below
this point...
The IPD will correct it?
Old 06-07-2011, 03:12 PM   #5
doucheNozzle
You have an adjustable cam. Try advancing it 4 degrees.
Old 06-07-2011, 03:15 PM   #6
Roy 940
Cheers
Paul
In my car, it loose a lot of very low-end torque, a little bit at mid range, but from 3800 to 6500 RPM, it pulls very hard!
The V is a very good cam, but not enough at low end for me...
Old 06-07-2011, 03:40 PM   #7
Canuckvolvo
Drunk as ****
Canuckvolvo's Avatar
As someone already asked, did you advance the V at all?
I was using the V when I swapped heads, but took it out to put the T back in when I was trying to solve some compression issues. I don't think I will put it back, with the automatic it was just too gutless in the low end for me. I didn't try advancing it, but I still think it wouldn't be enough. In a lighter car with manual transmission it would be alot better.
Currently Volvo-less
Canuckvolvo is offline   Reply With Quote
Old 06-07-2011, 03:44 PM   #8
professor245
professor245's Avatar
With V I didn't loose much bottom end power, but gained a lot torque in mid range, I have a lot of torque from 1k to 4,5k but it's n/a and carbed and overbore....soooo...
''I was so ugly the doctor slapped my momma when i was born!
Then he took out his pocket knife and cut off my horns...''
WAYLON
My seller/buyer feedback
professor245 is offline   Reply With Quote
Old 06-07-2011, 03:51 PM   #9
Roy 940
Yes, I've advanced it up to 2 deg, but I don't notice a gain at low-end...but I notice a loss at hi-revs...
That's why I think about the IPD cam...
Old 06-07-2011, 03:52 PM   #10
doucheNozzle
Yea I would try the IPD then if you have it.
Old 06-07-2011, 03:57 PM   #11
JW240
All idiot, no savant
If you think the V cam is sluggish below 3800 rpm, get someone to make a custom ignition chip. Without any changes in ignition timing the IPD turbo cam wont make a world of difference and you'll bne leaving a lot of potential on the table imho. the v cam in my car works good from 1500 rpm and really wakes up at 2500+ but thats also due to the bigger turbo.
v cam vs IPD-t, my car is faster at the same boost than another 240 that I know of. But then again, not all cars are the same so it is hard to compare.
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a few months)
dd: 940 | 1992 | B230FB
Old 06-07-2011, 03:58 PM   #12
Roy 940
I don't have it now, but I'm ready to order one...
But nobody can answer my question? The IPD is what I search, compared to the "V"?
Old 06-07-2011, 04:00 PM   #13
Roy 940
I've both Mike's chips ( ECU and EZK ), so it's not right about ignition?
Old 06-07-2011, 04:10 PM   #14
doucheNozzle
If you didn't buy one yet I wouldn't. I think people are finding better luck with the RSI cams.
Old 06-07-2011, 04:14 PM   #15
JW240
well I dont know what has been done with those chips so i cant comment on those. It can be good, but if you complain about very little torque below 3000 rpm it could be from sub-optimal ignition timing.
but ignition maps aren't a 'one size fits all' affair. With a more aggressive/hi-rpm cam for example you can use more advance down low (to get some torque back) and you need less up top where the VE has increased. Lots of other variables too.
Old 06-07-2011, 05:32 PM   #16
professor245
+1
This can be right, since when I installed my V cam I advanced the timing, searchin to catch the best optimum advance for V cam, and it was considerable more advance needed than on A cam, but bottom torque is there, until I did that car was lazy till 2k...
Old 06-07-2011, 06:12 PM   #17
Canuckvolvo
Drunk as ****
I know 2.4 learns, but will it learn a new cam profile, or does it just make adjustments from the base maps based on knock sensor feedback (or lack thereof)? I guess those are the same thing, but how much will it advance timing if it "thinks" it can add more?
Old 06-07-2011, 09:08 PM   #18
dalek
Benchracer Tribe
dalek's Avatar
Roy 940, do you want to borrow my IPD cam? Just be nice to it and let us know how it goes
Feedback!
dalek is online now   Reply With Quote
Old 06-07-2011, 09:32 PM   #19
stealthfti
What altitudes do you normally drive at? 1000 ft? 2000 ft? higher than that?
....the ambient altitude that you drive at IS a very important 'factor'.
TF
stealthfti is offline   Reply With Quote
Old 06-08-2011, 01:13 AM   #20
Roy 940
If I remember right, Mike developp his chips in his car, with an Enem V15 cam inside ( similar to the IPD cam ), so I think my loss of torque is not from the igniton...
My car was better ( at low-end ) with the "A" cam, or it's maybe because the feeling of the "V" is different...?
Old 06-08-2011, 09:19 AM   #21
Roy 940
Thanks, you're very friendly!!!
But the problem is : I'm located far from the USA, so it'll take some time to send it and cost a lot of money...! But once again, thank you very much for the proposition!!!
Old 06-08-2011, 09:21 AM   #22
Roy 940
TF
For sure, but I'm driving my car always in the same area, so 454m altitude... Not so high...
Old 06-08-2011, 03:02 PM   #23
HansW
HansW's Avatar
Hi Roy
I tried around with ECU's and found a huge difference in low end power with the V-cam
Best of all came the 984, then 962, then 932. 977 is said to be even better and 937 the best, -- I don't have the last two, so i can't say from my own experience.
Its also that: the higher the V-cam is boosted, the more it needs to be advanced to keep low-end drive-ability.
TLAO's chips are running far too rich for my set-up, -- exhaust black and turbo red and petrol consumption sky high -- that's not my idea of performance.
I ordered a chip from Stoni, -- he has all the other ones for comparison, and will see how that works.
940 classic Cd 1997
B230FT / M90L
530 head planed, KG 2T cam
Head gasket: Elring standard (Mls 0.35 was too tight, -- piston- head contact),
1041 axle 3.74, M90
15G at 0,85 bar
3" turbo back JT-superflow
3" Amm. + 42lbs injectors
STONI chips in 984 ecu and 167 EZK
Bosch WR5 DC+ (+15)
HansW is offline   Reply With Quote
Old 06-08-2011, 03:06 PM   #24
MrBill
fige=500Dollar Mistake
MrBill's Avatar
The EZK won't learn anything.
Someone say crazy rays?
Old 06-08-2011, 03:12 PM   #25
Canuckvolvo
Drunk as ****
Ah, interesting Hans, I wondered about this as well. I'm not sure what ICU I have, but I know I also have a spare, which may be a different #. I may try swapping and see if there is a difference...
