Old 11-17-2011, 04:58 PM   #1
REDBLOCK
REDBLOCK's Avatar
Default 17x8 wheels on 945 with 225/45 tires ???
Hi. I would like to have 17x8 wheels on my 945.The ET is 35 and i plan to use 25mm spacers.The tires I want to use are 225/45. Calculations says that these rimms will go from outer side 30mm more.I have lowering springs -40mm.Does anybody have done it before? Is it work?
REDBLOCK is offline   Reply With Quote
Old 11-17-2011, 07:59 PM   #2
Corey
Corey's Avatar
Ive got 17x8, I believe with a 40mm offset and with 25mm spacers in the front, 32mm rear. 215/45 tires. Like 2.5 coils cut all around. Rubs a bit at full lock only, no other problems.
sig pic
'81 242 turbo
Corey is offline   Reply With Quote
Old 11-17-2011, 10:26 PM   #3
gsellstr
gsellstr's Avatar
TME springs, 17x8 et53 with 35mm front spacers, 40mm rear, and 225/45 Conti DW's or Potenza 070's fit just fine with no scrubbing.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 11-18-2011, 03:43 PM   #4
PEGASUS 6
PEGASUS 6's Avatar
I hate it when you post corey. Stance envy on the brick pic
PEGASUS 6 is offline   Reply With Quote
Old 11-20-2011, 08:39 AM   #5
Aussie Volvo
Hi
I had 17by7.5 wheels with 25 et. No spacers I was running 235/45 17 with no problems On my 89 740t
Same outer diameter as the 205/65 15 factory tyres
George
Daily driver
15 Mitsubishi triton
Gone but not forgotten personal import 98 S70 T5
My Old car Soon to be restored and Modified again see link below
http://www.cardomain.com/ride/2151948
Aussie Volvo is offline   Reply With Quote
Old 11-21-2011, 04:12 AM   #6
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
I have 8X17 ET18 with 235/45.. rubs hard without adj. panhard on the right...
Old 01-08-2012, 10:36 AM   #7
Koston740
Koston740's Avatar
did you do any modifications to the front lower spring seat to keep them seated? how loose are your springs fully decompressed like while jacked up?
90 745 w/ b230ft- Holset He351cw, TLAO chips, eBay ic, Delphi 65's, bmw oil squirters, spec stage 2+ clutch, t5 WC E85
Feedback thread:
http://forums.turbobricks.com/showthread.php?t=236339
Koston740 is offline   Reply With Quote
Old 01-08-2012, 10:36 AM   #8
Koston740
Koston740's Avatar
bump from the dead
