Old 10-13-2020, 03:11 AM   #1
will740turbo
Default Stock squirters - official torque spec?
I'm assembling a rebuilt engine, and the squirterizational thread doesn't have an official torque spec for the squirters. They were very tight (like 50ft-lbs to remove), and had no thread lock.
The greenbook for b230 rebuilds tp30871/1 doesn't list a torque spec for it. Anybody know what it is beyond a reasonable guess?
will740turbo is offline   Reply With Quote
Old 10-13-2020, 10:50 AM   #2
rb92673
I was not able to find a spec either, I used the recommendation from Stealthfti in this old thread.
http://forums.turbobricks.com/showthread.php?t=27317
~18 lb/ft with red locktite.
I haven't finished the build.
Old 10-13-2020, 12:46 PM   #3
culberro
culberro's Avatar
Adding some data points to this.
I'm not sure what size squirters you are using, but VW engines use them in a few different sizes.
M6 threaded oil squirters 7 to 8 lb-ft or torque.
M10 thread ones are 20lb-ft
Old 10-13-2020, 03:40 PM   #4
will740turbo
Thanks, man. I'm using stock squirters that came in the block. Much obliged! Owe you a beer.
