Old 04-22-2021, 12:37 PM   #1
OldCarNewTricks
OldCarNewTricks's Avatar
Default New Valve Springs?
I plan to replace the intake stems seals on the b23f in my 83 242 soon. I get a bit of blue smoke upon start up, and since I'm already going to be swapping in the A cam, it will work out perfectly.
With valve springs, I'm most familiar with the LS motors, and how age and mileage effects those. An LS motor with a good amount of mileage can really benefit from some new valve springs. My b23f has well north of 250k miles, and I'm wondering if new valve springs are ever really needed on these motors if they aren't broken?
OldCarNewTricks is offline   Reply With Quote
Old 04-22-2021, 02:00 PM   #2
shoestring
shoestring's Avatar
Valvetrain is valvetrain. When I refresh a head, I put springs in it. Also, I use beehive springs, because they offer superior performance.
Old 04-22-2021, 02:41 PM   #3
OldCarNewTricks
Makes sense. What brand of springs do you use, and where do you get them? That would also require different retainers, correct?
Old 04-22-2021, 08:25 PM   #4
OldCarNewTricks
I found that ITM VS1275 is supposed to fit the 240s. Only $51 shipped through RockAuto, so not bad. Anyone have experience with those?
Old 04-23-2021, 04:45 PM   #5
We did a group buy with Yoshifab and bought a kit with all the parts needed for beehive spring installation.
Old 04-23-2021, 05:01 PM   #6
OldCarNewTricks
I see. Thanks for the info. Yoshifab has the kit for $285, but that's pretty expensive for no gain in my case. I'm running an A cam to start, so I'll likely stick with an OE replacement.
I found a NOS set of Volvo valve springs for $65. All the aftermarket OE springs require different seats and retainers, so I think those Volvo ones may be my best bet.
Old 04-23-2021, 05:06 PM   #7
The Librarian
Volvo used 2 different size valve springs, 29mm and 33mm. According to the parts catalog B23F engine got the smaller 29mm springs and it looks like that's what the VS1275's are.
If you get 33mm springs you'll also need the spring seats and retainers for them.
Whats the part number on the NOS Volvo springs?
Old 04-23-2021, 05:21 PM   #8
OldCarNewTricks
Interesting. Do you happen to know why they had the two different sizes?
The P/N is 473739.
VS1275's *may* be the way to go, since they are a tad cheaper.
Old 04-23-2021, 05:24 PM   #9
The Librarian
463739 are the larger springs.
https://www.skandix.de/en/spare-part...pring/1000449/
Old 04-23-2021, 05:32 PM   #10
OldCarNewTricks
Hmm. Perhaps the ad is misprinted. Sounds like the VS1275's are the replacement of choice. Thank you for the help!
Old 04-23-2021, 08:07 PM   #11
Those are the ones I have in my 405 head. They are a great product. Just as an trivia nugget Stealthfti actually found three types of valve springs. https://pbase.com/stealthfti/headwork
Scroll down to the valve spring gallery.
Old 04-23-2021, 08:29 PM   #12
The Librarian
That would explain the 26mm spring mentioned in the greenbook.
Old 04-23-2021, 08:33 PM   #13
OldCarNewTricks
I have the eBay ad for the NOS springs (URL) here: https://www.ebay.com/itm/8pcs-Volvo-....m46890.l49286
The Volvo tag has 473739 on it, but the ad says they've been sitting around for 30+ years, so I'm not sure. OEM would be nice.
Is there any true advantage to the different sizes?
Old 04-23-2021, 08:51 PM   #14
The Librarian
You're not lying. No wonder they haven't been able to sell them, there's a typo in the part number. 473739 doesn't come up in Volvo's system.
The larger springs are a little stiffer so they're better suited to a cam with higher lift.
Old 04-23-2021, 09:37 PM   #15
OldCarNewTricks
I need to measure mine to see what I actually have. Looks like they could either be the larger on the left, or the small ones in the middle...
I'm thinking that either the 29mm or 33mm would be the best suited to the A cam over the M cam.
Old 04-23-2021, 10:18 PM   #16
OldCarNewTricks
According to https://people.physics.anu.edu.au/~a...ad_531_530.htm it seems that my head (1000 398) likely came with the 33mm springs. Well, under the photo it says the B21/B23 would come with the 33mm and the 26mm was used on the low friction models in '85 on. 29mm was used to upgrade the weak 26mm springs.
Edit: so I think that means the NOS springs would be the ones that would work?
Old 04-23-2021, 11:28 PM   #17
The Librarian
The parts catalog (which isn't always correct) specifically calls for the 9135130 spring for B23F engines. This tidbit from the greenbook says B23F used 26mm springs. I know I said it should have 29mm springs but it's hard to tell whether the spring is 26mm or 29mm since the part number didn't change. You'll need to measure to be sure.
Old 04-23-2021, 11:55 PM   #18
OldCarNewTricks
I'll have to measure my springs during my next weekend. If I have 26mm springs, I'll likely end up using Volvo's service kit p/n 271793, which includes the 29mm spring, and both of the required retainers. At least, I think it does..
Old 04-24-2021, 01:01 AM   #19
The Librarian
It looks like the 29mm springs, seats and retainers did have different part numbers, 1332136, 1332137 and 1332138 respectively. The part numbers only appear in the '85-'87 240-260 catalog and the 780 catalog. The later catalogs use the part numbers for the smaller springs in the '79-'84 parts catalog, 9135130, 9135132 and 9135131 respectively. As you said, the 3 pieces are available as a service kit.
Old 04-24-2021, 08:10 AM   #20
shoestring
shoestring's Avatar
I use Ford Mustang 4.6 32v springs (I think it's from an early 2000's Cobra or something like that) and 6.2 Ford F150 Raptor retainers. I open up the top of the spring with a Dremel tool to fit the retainer, some guys turn the retainer down to fit the spring. It's not much, like 0.020", and I haven't found that it compromises the spring at all. About 8000 race miles at up to 6840 rpm on the same set.
Old 04-24-2021, 11:32 AM   #21
OldCarNewTricks
Excellent. I really appreciate you looking everything up. I have a cheap-o OHC spring tool kit on the way for next Thursday, so I'll have to get it done then.
If they're the 26mm they will *have* to go
Old 04-24-2021, 11:36 AM   #22
OldCarNewTricks
Now that's super creative. What camshaft are you running on top of those?
Woah, those 4.6 springs are cheap! Would there be any issue with using them on my stock A cam? I mean, it shouldn't wipe the cam lobes being that they're Ford OEM replacement springs, right?
Edit: nevermind, I think I was looking at the 4.6 SOHC springs.
Old 04-24-2021, 06:56 PM   #23
shoestring
shoestring's Avatar
Seat pressure is almost exactly the same as the stock Volvo springs, the rate is also very much in the ballpark. Beehive shape makes the spring control difference, plus the ability to run a smaller (lighter) retainer. I use that retainer because it uses exactly the same lock the stock Volvo does and I didn't want to run into some funny shenanigans with that. Also, they're drop in, but you won't be able to use hushers.
They ARE cheap. It's what happens when you're on a shoestring budget.
Old 04-24-2021, 07:17 PM   #24
OldCarNewTricks
Super cool! Do you happen to have part numbers for the springs? My hushers have been dead for ages. This car is a "fun commuter" so nothing there bothers me.
Only information I can find is for 16v heads. Is yours an 8v or 16v?
Old 04-25-2021, 10:17 AM   #25
shoestring
shoestring's Avatar
8V.
Springs are F6LZ-6513-AB. Retainers AL3Z-6514-A. If you do this, you do have to be cautious to not nick any part of the spring that moves. Also make sure to remove the sharp edge that you'll create when you open it up. Just open it until the retainer sits flush on top of the spring.
Seat pressure on the Ford spring is listed at 65 lbs installed at 1.440", which I think is just a hair shorter than what it ends up installed at in the 530 head. Ford rate is 250lbs/in, just a tick up from the Volvo 230lbs/in. This is all based on the 26mm spring.
Come to think of it, we have a few engines running around with this setup. My daily has been running around with these for probably 75 or 80 thousand miles.
