ImportTuning
- Jan 14, 2008
- Finland
Here is my first project topic ever.
I buy almost stock 740 turbo ic year is maybe 2004 or 2005. Many years it is only car and everyday use.
Little bit it comes more and more project car, there is b230 with spm rods/pistons 530 head with modifications oe size valves, holset hx40 super, megasquirt etc...
This engine broken and i want to move to 16v head and then it goes only project car.
Now there is only power steering pump and ac compressor which are used my old 8v engine, everything else had changed or modified.
Engine now B284FT
Engine specs:
B230 block with oil squirts and drilled to 96,5mm
Wiseco pistons 96,5mm drill, 30,6mm compression height with -31,8cc dome
KL-racing 154mm H-profile rods
94,5mm crankshaft
Head:
B234F oe head only little bit casting deburring? i don?t know is this right word to say that
OE size valves
OE b234f cams, maybe changed in future
New INA VW hydraulic lifters
KL-racing intake manifold
DIY exhaust manifold
2xTial copy wastegates
Holset Hx40 with LPS compressor blade 62,45mm. Turbine 67mm with #16 housing
MAC boost solenoid
Bosch EV14 1100cc injectors
Exhaust gas temperature control system for all 4 cylinders
Little bit of custom made parts here and there
Engine management:
Link G4+ RedXtreme
Gearbox:
Bmw ZF 6-spd Gs6-53dz
Blingfactory steel flywheel
Sachs SRE -618 with LPS sinter puck
Brakes:
4-Pot Brembo calipers from 2010 Camaro SS
Front brake disc Mercedes W203 C32AMG komp. 345mm
Rear brake disc Volvo S60R/V70R 330mm
Custom made brackets
Custom made steel braid brake hoses
Suspension:
Bc Racing coilovers
Polybushes front and rear
LSD Detroit locker torsen
Full interior
Recaro front seats (driver seat with electrically adjustable, seat heating and cooling)
BBS LM 19" 8,5 Front 10 Rear
More info/photos later today or tomorrow
https://drive.google.com/file/d/1T4VdFcS6EyjoOvCc4rDSYu6_P_w7Ht1x/view
https://drive.google.com/file/d/1SpAhH9iHmssamkSbAifFJgSNoD7bjvZy/view
https://drive.google.com/file/d/1SzT1aSshzHAW9zq4KITExY-CB-3tlLGT/view
https://drive.google.com/file/d/1Sl070HfQR99i4j-0DWVbyb_zX0Y9xfzw/view
https://drive.google.com/file/d/1TQAoOedz5yMKUYlYgdfSD0kf6XFdglg9/view?usp=sharing
Daily driver S60R
Original R now without engine because we are make some modifications.
B5234T Block and pistons
H-Profile rods 139,5mm
R Head
Upgraded kkk k24 with 11-Blade: 54.64mm/71.00mm compressor wheel and 9-Blade High Flow Turbine Wheel (49.5/59)
TME 3" full exhaust system
KW Variante 2 coilovers
KL Racing bolt-on cooler
I have very good friend Janne who is make everything to this car i only help and show light
We wait LPS to get that turbo back so after that we can put head and everything back, there is now block and gearbox back in car
Let?s see if this work someday again...hope it is soon because now i have to drive 1997 Nissan Primera Gt
Here is some pictures
https://lankku.kuvat.fi/kuvat/muut/S60R+laitot/
https://drive.google.com/file/d/1Ls07D0rjT6rOBRvYxC2AyEozQC8uHRcw/view?usp=sharing
https://drive.google.com/file/d/1MD1UV7692_C3oY_voCJ9m_WGh2kQNEK2/view?usp=sharing
https://drive.google.com/file/d/1MLAd-uXn1H7YSXMJxkrjMc0znDjmR6lj/view?usp=sharing
https://drive.google.com/file/d/1Lm3CmRo9QxAhHhV2hxxEAABN-xPh-73c/view?usp=sharing
Tell to dump how i can put images directly here...i?m not very good with these ?
Engine now B284FT
Engine specs:
94,5mm crankshaft
Head:
OE size valves
MAC boost solenoid
Engine management:
Link G4+ RedXtreme
Gearbox:
Brakes:
Suspension:
Bc Racing coilovers
Full interior
Daily driver S60R
R Head
