Old 11-19-2020, 10:45 PM   #1
Moyni
Moyni's Avatar
Default 780 Bertone (PRV) Idling issue and some engine issues.
Car is running super rich (see sparkplug image), has a funky idle where it seems fine in drive but when its in neutral / park it will surge the RPMs. Doesnt want to rev over 2500 without shaking like the space shuttle Columbia. I just did new spark plugs, wires, rotor and cap.
Thinking try a new MAF and a fuel pressure regulator possibly. I also havent ruled out a vacuum leak.
Classic Vehicle & Marketing Manager @ Hailey Import Service
2017 Alfa Romeo Giulia
1997 Volvo 960 Wagon
1987 Volvo 780 Bertone
https://nordcarolina.com/
Moyni is offline   Reply With Quote
Old 11-22-2020, 12:42 PM   #2
JohnLane
Pull the vacuum signal off of the fuel pressure regulator.... Fuel in that one? It may drip out or you may just smell it in the hose... Happens.
Coolant temp sensor and/or wiring to it. Ohm meter across the CTS... Open = pig rich.
Air mass meter much less likely; though everything about it is pretty old.
Give her a set of fresh plugs too. I'm fond of Bosch H6DC.
Check for vacuum leaks as doing so is good practice...Though a vacuum leak won't make her rich like this.
Old 11-23-2020, 12:35 AM   #3
84B23F
84B23F's Avatar
As John noted, Coolant temp sensor...ohm spec it...in vintage GM vehicles, they go rich when they start failing..
Old 11-24-2020, 05:07 PM   #4
Moyni
Moyni's Avatar
Ill give these a look, plugs are fresh too, should have mentioned that. Luckily we still have a few scattered NOS B280 parts laying around in the deep dark corners of the shop I can throw at it.
Old 12-01-2020, 01:03 PM   #5
Moyni
Moyni's Avatar
Anyone have a diagram of where the CTS would be? I have the Haynes manual as well as the Volvo Green manuals but still cant find it based off the online part numbers.
This is the only sensor I have seen and I dont believe this is it
Old 12-01-2020, 03:41 PM   #6
84B23F
84B23F's Avatar
Looks like a similar location for a 85-88 Pontiac Fiero...below the thermostat...either for the dash gauge, or for the ECU.
Google for ECU sensor...and compare:=_
Old 12-01-2020, 03:51 PM   #7
84B23F
84B23F's Avatar
Footnote - If your thermostat is open, it should be replaced...this could skew temp readings by ECU.
Also, you most likely found the ECU's temp sensor...
Old 12-01-2020, 04:20 PM   #8
dalek
Benchracer Tribe
dalek's Avatar
Nice, for a while I wanted a B280. So I am glad someone is keeping the flame
Feedback!
Old 12-01-2020, 04:51 PM   #9
Moyni
Moyni's Avatar
So after talking with the bossman here in the shop, and doing some of our own research on the ol VIDA, it does seem like that is the sensor I need to replace. I am sort of firing the parts cannon at this motor in hopes of resolving this, however I still need to pull it back inside the shop on a slower day and take my time testing all the electrical components.
Old 12-01-2020, 06:06 PM   #10
84B23F
84B23F's Avatar
RE: firing the parts cannon
Replace coolant thermostat and coolant temperature sensor...Current CTS has been in there for "ages."
Old 12-01-2020, 09:21 PM   #11
84B23F
84B23F's Avatar
Bosch LH-Jetronic 2.2 fuel injection....most likely then CTS
Old 12-01-2020, 09:44 PM   #12
84B23F
84B23F's Avatar
Footnote - If there is a cold start injector, then that circuit/injector needs to be evaluated.
Old 12-02-2020, 05:07 AM   #13
tomasss
former PRVert
tomasss's Avatar
Yes, that is the CTS
Volvo 740 Turbo B204GT 1991 >project thread<
It's the oversteer that scares passengers. It's the understeer that scares the driver.
I would rather push a 240 than drive a V70.
lazy PRV engine? Check >this< out
tomasss is offline   Reply With Quote
Old 12-02-2020, 05:51 AM   #14
84B23F
84B23F's Avatar
Not quite...that CTS has not been evaluated in years/years....nor has its terminals been cleaned up with spray contact cleaner.
OP: With LH 2.2, there should be new CTSs available
Old 12-02-2020, 09:24 AM   #15
tomasss
former PRVert
tomasss's Avatar
One way or another, THAT is the CTS. It's condition is another thing, but the part has been identified correctly.
Old 12-02-2020, 12:32 PM   #16
84B23F
84B23F's Avatar
On a CIS DeLorean, that would be a THERMOTIME switch...iitem #24.
Old 12-02-2020, 04:43 PM   #17
tomasss
former PRVert
tomasss's Avatar
...are we discussing 780 or DeLerean here?
I've replaced this temperature sensor on my PRV too so I remember it quite well.
Old 12-02-2020, 05:35 PM   #18
84B23F
84B23F's Avatar
Potential parts for the V6 PRV Parts' Cannon...
Old 12-07-2020, 04:03 PM   #19
Moyni
Moyni's Avatar
Yeah the book calls it a thermotimer, but I was able to get a new Bosch one for about $20. Seems to have fixed the terrible rev issues it had, however it still has a seeking idle. I can unplug the MAF and the idle stays the same so I have a buddy sending me a new (used) MAF to test with. If that works, I should be able to take it out on the street for the first time since I bought it.
Old 12-07-2020, 05:04 PM   #20
tomasss
former PRVert
tomasss's Avatar
Weird...that part has nothing to do with time except it's a timebomb what is the part #?
Old 02-09-2021, 05:22 PM   #21
Moyni
Moyni's Avatar
So its been a few months, still tinkering around with the running conditions on this damn thing. Got everything else dialed in, got a new MAF as the old one actually had melted plastic inside of it from the air filter housing being on fire (?!?!?!?) at some point.
Still has a misfire / doesnt want to rev above 2500 for a bit unless you really punch it and its still running rich as heck. Ordered an adjustable fuel pressure regulator off Summit Racing which I plan on installing as original B280 FPRs are hard to get these days.
Any idea of what the PSI of the fuel pressure regulator should be set at? I already know my current one is completely shot. Will most likely drop a new Lambda sensor in it as well.
Old 02-09-2021, 10:11 PM   #22
2 old for this
Nice color on your 780. Brown guts? Can’t really tell from the pic.
Old 02-10-2021, 09:02 AM   #23
Moyni
Moyni's Avatar
Gold with tan interior. Interior though is pretty rough.
Old 02-10-2021, 01:25 PM   #24
84B23F
84B23F's Avatar
Got a pic of FPR?
36psi to 40psi without vacuum is a ballpark pressure, if LH 2.2 or higher
Old 02-10-2021, 09:03 PM   #25
2 old for this
Throw in the towel !! I bid $19.95 delivered to Texas.��
