Old 08-11-2022, 04:54 PM   #1
940 16 valve
940 16 valve's Avatar
Default 89 760 windshield compatible with 960?
Anybody fit a 1995+ 960 windshield to a 760? Looks like the original one for the 760 is NLA through OEM and aftermarket.
I want to say the 960 windshield looks the same, but perhaps there is a slight difference I will learn when I try to install. Anybody done it?
1991 940 - stock b234+t -retired http://forums.turbobricks.com/showthread.php?t=243308
1989 760 - T5 (B5254T2 with a 6 speed!) http://forums.turbobricks.com/showthread.php?t=341191
940 16 valve is offline   Reply With Quote
Old 08-11-2022, 05:20 PM   #2
2manyturbos
The body shape is identical in that area. The 960 windshield should fit the 760. A decent glass shop should be able to answer your question.
Old 08-11-2022, 07:25 PM   #3
940 16 valve
Maybe I don't have any decent glass shops in my area, lol. So far no luck. My feeling is the same though, from what I can see the sheet metal is the same in that part of the car, but I hate assuming.
Old 08-11-2022, 07:50 PM   #4
The Librarian
According to the parts catalog the 760 windshield (part #6846175) updates to the 960/S90 windshield (part #9159510). Unfortunately it looks like it's discontinued. If you can get one for a 960/S90 from the aftermarket it should work.
https://www.volvopartswebstore.com/p...5/9159510.html
Old 08-13-2022, 11:02 AM   #5
Kjets On a Plane
Kjets On a Plane's Avatar
Should work fine? Just different trim & glue was all I remembered installing a junkyard S90 windshield I cut out for an ‘88 760…
I think I needed a couple trim clips and to carefully re-use the trim…doable but mild PITA?
Like so many things with these…
How PSI a stock can support?
Always Be Crushing!
Old 08-15-2022, 01:43 PM   #6
940 16 valve
Thanks for confirming team, new windshield is ordered. Talked to a different dealership and they said the old number supersedes to 9447618, but either way sounds like they didn't change them between any of the long hood cars.
