Old 11-20-2021, 09:43 PM   #1
dandeluca
Default Caping a mechanical speedo
Hello I am planning to swap in a m46 to my 91 245 auto. The manual transmission has a spot that I assume a speedometer cable once attached.
I believe I have to plug this spot since my car uses an electronic speedometer. Does anyone know the threading or what would make a good cap. I imagine I only have to cap the lower fitting that is pictured with the threads. Should I remove that stem? How does that come out?
dandeluca is offline   Reply With Quote
Old 11-20-2021, 09:50 PM   #2
Do you have an old speedo cable?
how psi stock cna sprout?
Old 11-20-2021, 09:52 PM   #3
dandeluca
No that did not come along with the various swap parts I collected.
Old 11-20-2021, 10:03 PM   #4
The Librarian
You can buy a plug to replace the speedo drive gear.
https://www.tascaparts.com/oem-parts/volvo-plug-1220200
Another option is to replace the tail housing with one that hasn't been machined for a speedo drive but that would require disassembling the OD. I have one if you're interested in going that route.
Old 11-20-2021, 10:05 PM   #5
I've used the speedometer end fitting as a cap with a round bit of rubber inner tube & a slightly filed down dime as a plug.
Of course you need to pull the carrier and remove the drive gear first.
Old 11-20-2021, 10:19 PM   #6
spock345
spock345's Avatar
I would imagine you should be able to find an M18x1.5mm end cap to thread on there.
1998 S70, grandma-mobile
Old 11-20-2021, 11:11 PM   #7
dandeluca
My local dealer will apparently sell me that cap for $13, so I’ll probably go that way. Does anyone know if I have to pull the housing to use it.
Old 11-20-2021, 11:28 PM   #8
The Librarian
No, you just need to remove the speedo gear and it's carrier.
You should get a new o-ring for the plug. It's part #380757. Reuse the screw and retaining washer.
Edit: the plug comes with a new o-ring.
