Old 11-22-2021, 12:48 AM   #1
8587turbo
Default M46 Overdrive question
The overdrive clutch return springs all measure slightly less than the recommended OAL, about .015" . All 4 springs look good & test equal on scale. Bentley Service Manual is giving a figure of 55.5mm +- 1.5mm. If a shim same size as spring is used to correct OAL will it do harm? I searched & cannot from new springs. Thanks
8587turbo is offline   Reply With Quote
Old 11-22-2021, 01:01 AM   #2
The Librarian
I wouldn't worry about them being .015" short but if it bothers you here's a source for the springs.
https://vp-autoparts.com/en/artiklar...it-j-type.html
Old 11-22-2021, 04:48 PM   #3
8587turbo
Thanks, think I'm fine with the springs, did not consider heat (less than 40F) in shop when measured , sure that coil spring will expand a fair bit at room temp.
