Old 11-22-2021, 01:25 PM   #1
Rasmusjornow
Exclamation Clutch not working properly
When I press my clutch all the way down and rev my car still moves a little, itís like itís not pressed all the way down. Iíve tried bleeding it but it doesnít seem to work. What can it be😁
Itís a 940 from 97
Rasmusjornow is offline   Reply With Quote
Old 11-22-2021, 02:26 PM   #2
shoestring
shoestring's Avatar
Does it work if you pump the pedal a few times?
shoestring is online now   Reply With Quote
Old 11-22-2021, 06:58 PM   #3
Fa182
Stage 1
Fa182's Avatar
A common problem is that the hole of the clutch fork where the pin of the slave cylinder goes into is worn out.
Check that and for obvious leaks at both cylinders and the lines.
