Go Back   Turbobricks Forums > General > events
Old 09-25-2019, 07:39 AM   #301
propav8r
F*ck Edgar
propav8r's Avatar
I gotta put the R on the lift tomorrow after work and check out the rear suspension sensors, and do a check on the a/c charge level.
Mixed up the rub, making bbq sauce right now.
I already changed my oil, checked tire pressures and all that. gotta run thro a car wash and vacuum out the interior, but most of that will take place on the way home tomorrow.
I have a couple quarts of Hilldales sauce too
Originally Posted by Hockey930
Jb welding tiny pieces of a fuse to the injectors seems to have worked perfectly
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
My Project
K-Jet to Megasquirt Article
Old 09-25-2019, 07:43 AM   #302
doucheNozzle
doucheNozzle's Avatar
Yup, just have to pick up the rental car.
Last minute thrash.
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 09-25-2019, 09:38 AM   #303
kyote
Living The Dream
kyote's Avatar
Dad shoved off this morning in the Jeep, he is taking back roads and is anticipating a Friday AM Arrival (Retiree's Time Frame).
All glory to my esteemed colleague Brett Willettrun for a radical remote tune on the Jeep!
I still have to swap the steelies back on to my 244 because the ****in Hockenheims I have turned out to have a bendy bend and much vibration on the freeway. Also need to sand the brake rotors out front and do a little washing. Other wise GTG.
We are planning on leaving in the AM and arriving Friday morning.
Old 09-25-2019, 01:06 PM   #304
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
counting down the remainder of the day..
Megasquirt Tuning!
Old 09-25-2019, 01:15 PM   #305
Swapped some upper control arms with shot bushings and slightly ovalized shells. And put on the IPD adjustables I took off when the 16V/T5 combo made horrible vibrations. Drove it around a bit, no issues with the LS/CD009 drivetrain.
Old 09-25-2019, 01:16 PM   #306
propav8r
F*ck Edgar
propav8r's Avatar
We're almost out of cell service. If you need to get in touch, call the lodge landline. (828) 293-9922
Y'all travel safe.
Old 09-25-2019, 03:13 PM   #307
towerymt
the real Towery
towerymt's Avatar
Originally Posted by stick70 View Post
Crunch time. I'm seeing several questionable cars successfully making final preparations. Who's not ready?
I thought about doing a few things, but didn't. So I guess my car is ready. Might check the trans fluid and top up, I've been known to destroy one M47 with no fluid remaining.
Last week my e-fan didn't shut off...flicked the relay and it went off. Then it decided to not switch on a few times, and I boiled off some water a couple of times. So I swapped in a 240 fuel pump relay in place of the 30a cube and the fan is back in business. Hopefully no trouble this year from the '92 240, now at 244,600 miles.
Departing Thursday (late) for ~10am Friday morning arrival. bout 9 hours from up north here.
1987 244 | Project Thread | The 87 | Now with 74 mods and counting
1992 244 | The 92
Originally Posted by Poik View Post
244s are drop dead ugly and suck.
Old 09-25-2019, 05:01 PM   #308
This should be grand
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 09-25-2019, 05:34 PM   #309
Fixed a leaky injector (ill-fitting o-rings on the Deka's - plus a somewhat hamhanded install on my part). And fixed another burnt plug wire. And that's it. Should be good to go.
Old 09-25-2019, 09:22 PM   #310
Fast740fromSC
Fast740fromSC's Avatar
Tomorrow is gonna be long af. I did a once over on the 940. Hopefully it’s more reliable than last year.
Fast740fromSC is offline   Reply With Quote
Old 09-25-2019, 09:51 PM   #311
stick70
All the gauges
stick70's Avatar
Looked under the Amazon again and didn't find the rattle in the rear suspension again. The trans is leaking again through the crack in the tailhousing I jb welded, I guess we're just going to cross fingers on those two items. Aimed the headlights not high enough, got home and now the reverse lights don't work.
Good enough, we're out 6-7 am
Old 09-25-2019, 09:55 PM   #312
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
Goodnight ladies and gentlemen.
I will see y'all around 1:30 god willing tomorrow afternoon.
1971 142 beater/fake racecar
Originally Posted by propav8r
The incest is implied.
Old 09-25-2019, 09:56 PM   #313
vwbusman66
vwbusman66's Avatar
Should I jerk the T5 out of the 142 tonight?
Old 09-25-2019, 10:26 PM   #314
stick70
All the gauges
stick70's Avatar
Nahhhh
Old 09-26-2019, 09:29 PM   #315
Manbeard
OG
Manbeard's Avatar
I'm leaving tomorrow after work. I'll be clacking down the road to the lodge in the tdi around 11pm
2006 Tundra
Manbeard is offline   Reply With Quote
Old 09-26-2019, 11:17 PM   #316
doucheNozzle
Half way there in Princeton, WV
See y’all tomorrow morning
Old 09-30-2019, 04:49 AM   #317
kyote
Living The Dream
kyote's Avatar
Happy to be home
Old 09-30-2019, 07:40 AM   #318
tequila_gundam_no_chaser
tequila_gundam_hug_the_toilet
tequila_gundam_no_chaser's Avatar
Anybody leave a set Subaru keys in my car? (Fiesta ST) https://mega.nz/#!jHIWEKJC!HoTtTKWKP...DWpwl_wL7cN4tI
1999 S70t5m. Volvospeed Car
2005 s60. Bucket of bolts
1996 850t Daily Beater
1992 742j ugly speed
2000 Audi A6 5spd conversion (grown man swagg)
tequila_gundam_no_chaser is offline   Reply With Quote
Old 09-30-2019, 10:56 AM   #319
Manbeard
OG
Manbeard's Avatar
Cant wait till next year. Same as last year, it's always so cool putting a face to the name of people that I have been talking **** to for the past 13 years
Old 09-30-2019, 12:30 PM   #320
doucheNozzle
Better not tell your lady you love kids
Old 09-30-2019, 09:05 PM   #321
Manbeard
OG
Manbeard's Avatar
Haha she knows! We are trying to make one!
Old 10-02-2019, 07:05 PM   #322
Turbo3er
Had a great time at Mountain Meet 5.0, first time attending and looking forward to attending next year's event. It was great to see some people I haven't seen in a few years. I now look forward to spring and the upcoming SE meet. I hope to see a bunch of you there for that.
2016 Dodge Challenger R/T Scatpack
2006 Chrysler 300C
1999 Dodge Ram 2500 Cummins
1987 BMW 325 PnP MSnS w/HEEBSPEED Tune
2008 H-D VRSCDX V-Rod 11.867 @ 113.86
The Departed
2009 Dodge Ram 3500
Turbo3er is offline   Reply With Quote
Old 10-02-2019, 10:15 PM   #323
Wren
Porkchop Sandwiches
Wren's Avatar
Thanks for all of the help with the fryer, Tom. Looking forward to hanging out with you again at SE.
Old 10-03-2019, 12:09 AM   #324
vwbusman66
vwbusman66's Avatar
HOLY ****
Now I see why you almost took the tree out!!!
Old 10-03-2019, 09:27 AM   #325
linuxman51
linuxman51's Avatar
HOLY ****
that wasn't him
