Old 11-06-2014, 01:27 PM   #1
manback
manback's Avatar
Default DIY adjustable torque rods and pahard?
I'm about to make my own adjustable rod and bars with so e threaded bar.
Has anyone done this? Can someone point me to a decent thread. I'm interested to see if either of them are hollow?
If they are what's the id? Cheers!
855 2.0 10v
854 T5 CD
S70R
'91 245 SE
manback is offline   Reply With Quote
Old 11-06-2014, 03:29 PM   #2
gsellstr
gsellstr's Avatar
Both are hollow, don't remember the ID. Recommendation though...look for implement pins from a tractor supply place. They will be grade 8 usually, come with hardware, and are likely much cheaper than some other options.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 11-06-2014, 03:52 PM   #3
propav8r
F*ck Edgar
propav8r's Avatar
That's EXACTLY what I did with my panhard bar. Works like a champ.
Draw Pin is what you're looking for. Tractor supply/Northern tool, places like that normally stock them.
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
Originally Posted by VB242 View Post
Space time farts
My Project
K-Jet to Megasquirt Article
Old 11-06-2014, 03:55 PM   #4
AndrewNance
Amateur hour!
AndrewNance's Avatar
I had a member here make mine. They are adjustable without removing them from the car which makes it so much nicer. I think the parts are available from McMaster-Carr.
'67 122 - b230, t5, 8.8
Feedback
Old 11-06-2014, 04:13 PM   #5
http://forums.turbobricks.com/showthread.php?t=45651
how psi stock cna sprout?
Old 11-06-2014, 05:45 PM   #6
mopar318
mopar318's Avatar
Swedge tube and rod ends. Its not hard to make your own. Some assembly required.
I got my parts from a local shop that makes them call UB machine.
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline   Reply With Quote
Old 11-11-2014, 09:20 PM   #7
Homer
OEMplus++
Homer's Avatar
www.midwestcontrol.com has all the jack screws and threaded ferrules you'll need. I did the panhard and torque rods this way.
-Jacob:
2017 allroad - Comfy DD
Old 11-12-2014, 01:39 PM   #8
odinthewanderer
just to leave here as a note from my personal experience, on my 245 (that stiggy pop stripped for his 242) i had tried a lot of different combos in regard to torque rods. stock, then the ipd adjustable, then i cut up the ipd adjustable and modified them to take hiem joints. bought threaded furrels and rod ends off ebay.
solid poly bushings made the car nice and flat, but in my opinion the amount of traction loss i suffered was not worth it, maybe for a drift car. the solid axle needs as much articulation as it can get in my opinion.
especially with an open dif. i actually went poly on the rear trailing arm/axle bushings, and then later took them out and put stock lemforder ones back in, improved traction greatly. i had a g80 in there at the time.
in the end the car had poly everywhere but the torque rods and the rear trailing arm/axle bushing, much better traction than with full poly.
this time i just bought the aluminum ones josh sells as i did not have the time to make anything as there are too many other projects going on at the moment.
ask me what kind of stupid i am today?
92 240 wagon, aw70, (tool box, prepping to be driver) new mexico clean!
92 745tic mild stuff done(7s and 9s are not 240s, pulling engine to build for the 77, ask for parts, body is clean) for sale?
92 245 modified (sold)
77 244 dl (almost done with resto... SOOON)
91 245 m47, rust bucket winter beater (driver, now parts)
90 234 aw70, side swiped winter beater (driver)
72 ford highboy, farm rig
95 chevy g20, family pet pig.
odinthewanderer is offline   Reply With Quote
Old 11-12-2014, 02:31 PM   #9
mopar318
mopar318's Avatar
You can sort of see my torque rods in this photo.
