Old 03-31-2006, 07:19 AM   #1
Bishop
Bored Member
Bishop's Avatar
Default Fitting a rear sway bar on a 700/900 series wagon...
As some might have realised, your average 700 wagon does not come with a rear bar, which is a serious oversight when it comes to good handling, the following is just a brief guide on what you need, and how to fit it...
Step Zero, find yourself some brackets to mount the rear bar, the wagons do not come with these brackets, the rear bars have two mounting points per side, the front point mounts to the lower shock mount, but the rear point is secured to this bracket.
This Vadis pic shows you what you need, basically just the brackets (2-1272960), the square neck screws (3-947292), and the flange nuts (4-971095).
Don't worry about the lower shock bolts or the trailing arm bolts, the existing ones should already be heaps long enough to accommodate the mounting of the bracket and bar.
As for where to get the brackets and bolts etc, you can get them as a kit from a Volvo dealer (new), or from your local wreckers (used), they should cost no more than around $25 used, and I think Volvo quoted me like $50 ages ago when I inquired.
Step One, raise the rear of your car, either on stands, or ramps, but also keep the jack handy, as ideally you want to keep some support under the trailing arm, as you are removing two of it's four supporting points when your fitting a bracket...
Tools for the job should include a Jack, Work Stands/Ramps, 19mm Socket/Spanner, 17mm Socket/Spanner, 15mm Socket/Spanner, and some loctite and spray lube if you have it.
Step Two, it never hurts to spray some penetrating lube on the nuts and bolts you want to remove, you can do that and go make a coffee if you like, or be a real man and rely on brute strength, and get stuck in right away...
As mentioned before, support the side you want to work on properly, maybe I'm just paranoid, but I don't want to create to much load on any point where it's not necessary.
Even with the support shown here, the trailing arm to axle brackets still separated a good 1/4 inch when the nuts were removed.
These nuts are 17mm, and covered with a lovely coating of under body sealant, so they could be fun to get a spanner around at first, they are also on quite tight.
Step Three, it helps to scrape your nuts clean before refitting them (lol), you can also scrape the area where the bracket will go up on to, you don't really want all that goop between the bracket and trailing arm...
Once clean enough for your own liking, put some loctite on the nuts and bolts, and your now ready to fit your brackets into place.
Step Four, fit your bracket into place, and torque your nuts up nice and tight, I'm not sure of the torque setting, I just did mine up FFT (fairly ****ing tight).
Sorry for the lack of pics here, I was far too dirty at this stage to pick up the camera again.
Now, go back to Step Two and repeat on the other side of the car.
Step Five, undo your lower shock mount, it should be 19mm for the nut, and 17mm for the bolt, depending on who has worked on your car, the bolt could be facing in or out, for ease of fitment of the bar, it's probably better facing in, as then you don't need to remove the bolt to fit the bar, just the nut.
If you have to remove the bolt, make sure to support the shock, so getting the bolt back in is easy.
Step Six, with the shock bolts exposed, raise the bar into place, and onto the lower shock bolts, it should not be real hard, you can push the bolts out a little, raise the bar and push the bolts back in and wind the nuts on to secure it in place.
Once the shock bolts are holding it, lift the bar up, and fit your square neck bracket bolts into the bar, and also just fit the nuts by hand, it should start looking like this...
Now you just have to torque up the bolts, the nuts for the bracket bolts should be 15mm, I have no idea of the torque needed, again for me it was just FFT, and I did not bother with loctite here, but you can if your worried about them coming loose.
And now congratulations, you have a wagon with a rear sway bar, and it should look something like this...
Things to look out for, my lower shock bolts were bloody tight, and remember you need a spanner on both sides once you crack them, the bracket to bar bolts are easy, the square neck means you just need the one spanner, as the bolt is always secured in place by design.
I found on my wagon now, stuff in the rear actually moves around less than without the bar, my shopping now stays where it's put on the trip home...
If a mod wrote this, it would be hell funny...
Bishop is offline   Reply With Quote
Old 03-31-2006, 12:12 PM   #2
Donny
Donny's Avatar
Nice write up, but maybe things are different in your market. I simply took a rear bar from a 700 wagon that cane with one and put it on my wagon. I didn't have to mess with finding brackets or anything. I simply took off the bolts and put the bar on and tightened the bolts. I didn't even use a jack if I remember correctly.
Donny is offline   Reply With Quote
Old 03-31-2006, 01:19 PM   #3
Bishop
Bored Member
Bishop's Avatar
So your wagon had the brackets but no bar?
I know other people have said wagons got rear bars where they are, but I know here, and a few other places, were the wagons mostly came without.
Generally it's the lack of brackets that confuse most people, when they are not there, it's hard to realise what's missing, so I figured it would be best to show people where they go and how to fit them.
Old 03-31-2006, 07:24 PM   #4
blarf
blarf's Avatar
None of the US spec 700 wagons came with rear bars. Some of the 900s did, I think. Certainly the easiest thing is to just grab the brackets and bar at the same time. That's what I did, and the junkyard didn't charge extra.
Manuals moved here: http://gaz.inferiorhumanorgans.com/greenbook/
blarf is offline   Reply With Quote
Old 04-18-2007, 08:52 AM   #5
Lockpixor
Lockpixor's Avatar
Would the rear swaybar from a 240 work?
I'm not a player, I just truck alot.
Lockpixor is offline   Reply With Quote
Old 04-18-2007, 09:32 PM   #6
TracksideTurbos
TracksideTurbos's Avatar
I don't think so but almost all 700 sedans(no irs)have a rear sway and most turbos have a thicker one. Found some today and put them on it's a breeze.Found a front ipd in a shmaaashed 91 bertone and the rear from a 85 740 turbo and yeah scraping the under coating off sucks!
TracksideTurbos is offline   Reply With Quote
Old 04-18-2007, 09:43 PM   #7
slowmotion
slowmotion's Avatar
I put one on my 940 wagon last weekend, easy as.. Just a little one from a 740 turbo sedan, but it makes a big difference... I don't think I'd go thicker though personally. Broke my cheap ratchet in the process, so I get to buy a new one. All good.
240 ones won't fit but *maybe* you could make them fit. I'd just grab a 740 and the brackets.
slowmotion is offline   Reply With Quote
Old 04-27-2007, 12:47 AM   #8
V-Jet
V-Jet's Avatar
Nice, is that the swaybar from my white 740 that I gave you ages ago?
Current Volvos- 1998 S90 Executive (B6304S), 1998 S90 3.0 (B6304S), 1996 965 (B6254S)
Previous Volvos - 1991 964 (B280F), 1990 764 GLE (B280F), 1990 764 GLE (B280E), 1990 744 GLT (B234F), 1990 744 GL (B230F converted to B230FB), 1973 164E (B30E)
V-Jet is offline   Reply With Quote
Old 07-25-2007, 11:52 AM   #9
Chris_R
Kickin' rocks in sandals
Chris_R's Avatar
Are there different brackets for sedan and wagon? I picked up a set of IPD sways at the junkyard the other day from a 90 744 and grabbed the brackets as well...
Maybe, just maybe I did the right thing? Either way, the set of sways was 25 bucks.
Ermergherd!! Erm gernner kerhm!!
1995 964 (Silver)
1992 944Ti (White)
1996 965 (Burgundy) - Scrap
1994 945 Ti (Black) - Sirius Black Scrap
1992 944 GL (Black) - Killed by drunk driver
1988 745Ti (Silver) - Sold
Originally Posted by TurboBrickMan View Post
Long story short I found out she's a squirter.
Chris_R is offline   Reply With Quote
Old 07-25-2007, 12:38 PM   #10
dalek
Benchracer Tribe
dalek's Avatar
AFAIK the 700 sedans and wagons can use the same rear sway bars down to the brackets. So, all you have to do is go bracket shopping. :D
Feedback!
Old 07-25-2007, 12:50 PM   #11
Chris_R
Chris_R's Avatar
I'm all set!
Old 07-25-2007, 09:49 PM   #12
mikes02ls1
Stolz, deutsch zu sein!
mikes02ls1's Avatar
So can you get the brackets from Volvo?
Desert Detail & More LLC
89 Toyota Cressida
Uncle Ben's Powered..
Old car 2002 Z28
http://lsx.streetfire.net/video/610d...73014ac34d.htm
mikes02ls1 is offline   Reply With Quote
Old 07-26-2007, 01:47 AM   #13
Bishop
Bored Member
Bishop's Avatar
Yep, I got sick of all the rear body roll, and it turned out that I prefur the 16mm rear bar.
You can, but used will be a lot cheaper.
In terms of what has what, most 700 sedans will probably have 19mm front and 16mm rear bars, turbo models should have 21mm front and 19mm rear.
As to what works, I fitted a 16mm bar because I had one laying around, it was going to be temporary until I picked up a 19mm, but I quickly found out bigger is not always better.
Wagons already have thicker/harder rear springs than a sedan, combine that with a bar on something that came without, and you suddenly find you have reduced traction is all sorts of conditions.
On my ride I also have a stiff 24mm Whiteline front bar, so I could probably get away with a 19mm rear, but I actually prefer the extra traction from staying with the 16, it still kills the god awful tipping over feeling from the back end, but leaves you with reasonable wet weather handling and general all around good traction.
If you like flat and stiff, then sure go nuts on bar size, but after having lived with this upgrade for some time, I still recommend putting a rear bar on a wagon, but now would only recommend trying a 16mm bar first.
Old 07-26-2007, 11:26 AM   #14
stylngle2003
stylngle2003's Avatar
do you want an ipd rear bar and brackets? PM me if you do
-Billy
1990 Mazda Miata (track toy)
Old 07-27-2007, 09:44 PM   #15
mikes02ls1
mikes02ls1's Avatar
Set ya PM...
Old 09-22-2007, 01:40 PM   #16
WAGONRACER
WAGONRACER's Avatar
Just fitted a rear bar to the back of my waggon this afternoon, what a difference. Anyone thinking about doing this DO IT NOW. This is the best value for money suspension upgrade you can get.
945 se b200ft
944 wentworth b200ft
944 TURBO b230ft
945 se b200ft
744 gl b23* carb
964 executive b6303
945 sports edition b230ft
744 gl b200e
S60 se b5204t5
945 2.3t b230fk
V70 awd R b5234
764 turbo intercooler b230ft
945 b230fk
945 celebration r reg b230fk
745 gl b200e
244 gl b21
945 wentworth b200ft
S80 b5244s m56
944 h reg gl b230fb
WAGONRACER is offline   Reply With Quote
Old 09-25-2007, 05:26 PM   #17
Hagar17
Hagar17's Avatar
yeah mine just went on - brackets not needed - 25mm IPD sways - one of the best upgrades to the car handling.
(oh if I don't strap things down in the back they go for a tumble! but I like to corner quick...)
Keeping late 80's Swedish metal alive!
Hagar17 is offline   Reply With Quote
Old 09-26-2007, 05:16 AM   #18
MikeHardy
The Sirius/Nova Police
MikeHardy's Avatar
getting the front bar from an 88+ 760 turbo (23.5mm) is a nice match to the rear 19mm bar
MikeHardy is offline   Reply With Quote
Old 09-26-2007, 05:19 AM   #19
blarf
blarf's Avatar
88+ 760 sedan anyhow.
Old 03-08-2008, 01:25 AM   #20
lummert
lummert's Avatar
I looked those part numbers for the brackets and they are less than $5.00 each at dealer. two brackets, two square-head screws and two nuts was less than $15.00.
