Heater pipe on my 93 940 sprung a leak so I had to pull the turbo and manifold. With all that out of the way, I noticed this empty bolt hole on the rear of the engine near the oil filter. Am i missing a block to transmission bolt, or something? Does a sensor bolt there on a different configuration?
You can see it here below that screw in coolant tube:
https://i.imgur.com/pGboCzK.jpg
