Timmermans
- Nov 10, 2017
I keep getting a 144 code on my ignition: Load signal missing. Car runs pretty good. only a slight hesitation when accelerating. Idles good and never stalls.
Specs:
1992 volvo 240
B230FK
Wasted spark with Miata power stage and Bosch 2x2 coil
Can this have something to do with the wasted spark?
From what I read the load signal is produced by the ECU. It's output is port 25
it comes in on the EZK on port 8. How does the ECU produce this signal? what sensors does the ECU use to produce this signal. Maybe then I can trace back the issue.
Specs:
1992 volvo 240
B230FK
