Old 10-10-2019, 02:43 PM   #1
neildrake
Default B30 redblock Big Bore Head Gasket (2019-2021 bump)
A couple years ago I worked with Cometic to make a head gasket suitable for up to 93mm bore for my B30.
Finished the engine early this year and ended up with a 92mm bore and 6mm stroked motor which yielded approx 3.5l.
Cometic Part numbers are:
0.043" Thickness - PN H3270SP1043F
0.059" THickness - PN H3270SP1059F
Used an off the shelf Wiseco forged piston and Nascar Carrillo rods. Had to have crank welded, narrowed rod journals and reground to smaller diameter journal to accomplish but was happy with results.
https://www.youtube.com/watch?v=cV-Q1NaQOZk
Neil
neildrake is offline   Reply With Quote
Old 10-10-2019, 03:29 PM   #2
Sounds great! Looks like it's going to be a lot of fun in a car that barely weighs more than the engine.
Old 10-10-2019, 03:36 PM   #3
The Librarian
Sounds awesome! It revs quick for a B30. What's the compression ratio?
What kind of car is it in, a Marcos?
NVM, I just saw your user profile:
Your Ride
Marcos 3000GT - 1970
Old 10-10-2019, 06:53 PM   #4
oemoilleaks
oemoilleaks's Avatar
SOUNDS AMAZING!!! What is that gauge that's just floating there above the manifold?
oemoilleaks is offline   Reply With Quote
Old 10-10-2019, 07:28 PM   #5
Awesome!
Old 10-10-2019, 09:19 PM   #6
doucheNozzle
doucheNozzle's Avatar
That's pretty damn rowdy
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'11 XC90 V8 - Torque Monster
Old 10-10-2019, 09:27 PM   #7
oldschoolvolvo
oldschoolvolvo's Avatar
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 10-10-2019, 11:11 PM   #8
neildrake
Compression ratio is 11:1.
It picks up revs so quick mainly due to the lightweight flywheel and clutch. Turns out that a tilton 153T nascar flywheel for small ford will bolt to B30 with a few mods. Rods and pistons are a fair bit lighter than stock also.
The extra gauge was just oil pressure temporarily zip tied to intake during break in.
Old 10-11-2019, 10:17 AM   #9
brian smith
Awesome result, thanks for posting both the info and the video.
the howdeedoo:
http://forums.turbobricks.com/showthread.php?t=288872
brian smith is offline   Reply With Quote
Old 10-11-2019, 12:11 PM   #10
vwbusman66
Stößelstange über alles
vwbusman66's Avatar
Wow.
Just wow.
Old 10-11-2019, 12:12 PM   #11
Hopefully you dyno it at some point. It always seems like the B30 doesn't 'scale' as you'd expect from a B20, but then people rarely go all out on a B30 build.
Old 10-11-2019, 04:55 PM   #12
OttoB
I got something like 185 hp out from my B30E with K-cam style camshaft, but it is not fully sorted out. Max torque comes in quite high rpm, so I might be cam timing issue or exhaust tuning thingy. I got std B30 E moose horns as exhaust manifolds
Before dyno, GT power simulation was made, giving quite close same performance results as dyno.
Old 10-11-2019, 07:28 PM   #13
Tfrasca
Tfrasca's Avatar
That is bad ass. What kind of power does it make?
Old 10-11-2019, 07:36 PM   #14
neildrake
Default Dyno TBD
I’ll post after it runs on dyno. Right now I’m gettin break-in miles on it before putting the second valve spring in. Also working on an FI setup. Weber’s are great but think I can do better.
If someone can tell me how to post pics here I can show some more detail. Also running a quaife sequential gearbox that’s pretty fun.
Neil
Old 10-16-2019, 02:28 PM   #15
klr142
Turbo, what?
klr142's Avatar
Beautiful! Looking forward to hearing and seeing more.
Old 04-08-2021, 06:12 PM   #16
CDN1800ES
Neil Drake: New to me, I have your twin Marcos. Would like to discuss b30 if you have a chance.
Thanks
CDN1800ES is offline   Reply With Quote
Old 04-08-2021, 09:42 PM   #17
fatcatbestcat
Professional Hack
fatcatbestcat's Avatar
Makes me want to put a B30 in my 144.
Will you do $14.99 shipped?
-1967 144S (wasted)
fatcatbestcat is online now   Reply With Quote
