Lulz m46 is rare after ?86 & pre ?85 cars are few & far between.
The 3 speed does suck but 3 to 4 speed auto is a pretty easy conversion (even easier than full on manual swap & nicer in traffic) & can return decent economy & go down the highway plenty quiet in OD too? People give those away known good the failure rate is so low on AWs If well maintained in cool /Mild weather & not abused?
Stock skinny tires & AW-71L 4.10 gears like the last or the 940 n/a cars got stateside sip fuel & go down the highway quietly.
The shift points kinda suck for ?spirited? driving & are more economy/emissions oriented on those.
No easy way for mech speedo drive on 87+ m47s or 1993+ AWs?if you care about that. Electric speedometer conversion isn?t all that hard depending how you do it/recombine the junkpile? One less thing to leak?
AW-72L used in 16v models has more k-cam B23E appropriate shift points & OD ratio.
Don?t even have to mess around with the pedal box!
And the trans is Aisin/Toyota not some Volvo obscure bad joke with NLA & $$$ parts new if you have to rebuild it.
That said, the m46 works fine to go to the grocery store if cared for & driven gently for the long haul (as much as anything on a car that?s 40+ years old with the ford ?king of NLA? & China crap in the pipeline
The constant contact release hearing lasts longer in my experience actually keeping these things going with tons of miles no fuss for myself and others & i prefer the late pedal box & spring, but use whatever.
I wanna say return spring in the clutch fork/x-member stops 1981+ On most models ??? I forget.
Diesels are a little different (different clutch cable & pedal box) & reinforced trans x-member (grabs 3 holes per side instead of 2 in the diesel position/heavier motor).
Can?t argue on the better Bakelite style -80 shift knob or possible -?79 pre-screwup no-rot wiring (unlike much of the ?80-?87 cheap rot prone wiring), but the slider switch is less seamless/intuitive to use if you loan the car to someone than the ?81+ momentary (if anyone/average joe non car dork/?enthusiast? can/wants to/even remembers or is in practice even drive a manual trans car, regardless of how it?s configured, anymore hahahaha
I?m a lazy American & like the monetary & tolerate it?s?mostly (seldom foibles & failures for me?granted some versions are more reliable than others; the 1990 & 1991 700T M46 cars I had the wiring didn?t rot & was routed better and all that stuff on the momentary setup seemed to behave itself no-fuss) , but there are trade-offs for sure or slight additional complexity.
Usually you want grandmas known history qualified properly serviced pampered 60-150k mile gutless ?79-?82 B21F 244 for an M46 donor.
Don?t come in much like that anymore as a fresh kill T-boned or something good, but nice otherwise?
I swap the firewall panel for the clutch cable with the pedal box, but most people just drill a hole & use a washer or whatever?
Unless it?s a turbo model?then you Shoukd be good to go/already have the manual trans compatible firewall panel?idk about that in Canadian GLT.
You can just open/adjust the idle slide (Aux air valve rather) wider or less that?s of no worthwhile significance auto or manual. They just didn?t want the auto cars to stall coming to a stop in warm weather heat soaked is all, same as how the B20 carbed cars had a delay contraption for the charcoal can line with a vac tank so it wouldn?t quit closing the throttle facing uphill while braking?
I don?t remember EGR on all B23E models?
Pulse air air injection on all Canadian B23E 405 head/k-cam cars is all I remember?
I remember making threaded brass plugs for that & polishing them down in the exhaust ports is all?
Mechanical egr & pulse air of that era & the Canadian basic resonator oxidation catalyst vs. USA market honey comb catalyst & milder cams & Compression is common between USA & Canadian cars those years regardless of brand. I don?t remember the mechanical/vacuum controlled EGR doing much either but OR & WA never had CA NOX requirements or tested for NOX that I remember, regardless, which is mostly what EGR is (was) used for in those days ..
