Old 06-12-2022, 09:49 AM   #1
Swedbrick
Swedbrick's Avatar
Default Sliced 530 head - pictures & scans
Hi all, given I got access to these by I thought I'd open source them. STL files from skanect and original pictures are in the zip files
530-exhaust:
530-intake:
Volvo 745 - Turbo, LH2.4, M90 swap, IPD springs, 25mm/19mm swaybars, 3.54 \w racingdiff lsd, track/daily
Volvo 363 - N/A, Speeduino, GSXR ITB's, half-cage, work in progress
Old 06-12-2022, 10:39 AM   #2
culberro
culberro's Avatar
Awesome, thanks!
Head work: https://forums.turbobricks.com/showthread.php?t=349975
Temp Sender Adapters: https://forums.turbobricks.com/showthread.php?t=348169
Old 06-12-2022, 11:12 AM   #3
122power
dude
122power's Avatar
That exh port hurts my eyes.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 06-12-2022, 12:38 PM   #4
Truebeliever
These are great, now if only someone would ms paint a head porting for dummies.
Truebeliever is online now   Reply With Quote
Old 06-12-2022, 10:41 PM   #5
shoestring
shoestring's Avatar
These are labeled in reverse. The tipoff is how much the exhaust is shrouded.
Old 06-13-2022, 11:07 AM   #6
Swedbrick
Swedbrick's Avatar
Whoops, fixed
Old 06-13-2022, 12:53 PM   #7
culberro
culberro's Avatar
Google image search for the pic, and look here (use google translate for the page)
http://www.topplocksverkstan.se/omforetaget.html
There are "standard" porting practices that you can use, and see large improvements in performance. A lot of people port at the gasket areas, don't do that as a beginner.
~70% of porting gains will be ~1.5" into the port from the valve seat, and then chamber profile.
Porting at the gasket areas is pretty much pointless on the exhaust unless you're doing big changes near the valve. And I mean BIG changes.
Porting at the gasket area at the intake is OK, but you need to calculate the cross section areas (CSA) throughout the port to know what you need and where. Otherwise you'll end up with a port that slows down, and speeds up, and slows down, and speeds up as the air goes through the port.
In all honesty, for the majority (and I mean like 90%) of redblock builds, a simple bowl blend and a good valve job + increased CR will be all they'll ever need/want.
Old 06-13-2022, 05:39 PM   #8
mikep
The MP
mikep's Avatar
It hurts my fingers and my soul every time i port one. It’s why i wish i hadn’t “traded” (give away) my two 16 valve heads.
I was just thinking about doing that.
Originally Posted by megulon-7 View Post
You Oregon beavers keep your hands off our sweet Cali redwood and we won’t touch your Portland $8 doughnuts.
Old 06-13-2022, 05:41 PM   #9
mikep
The MP
mikep's Avatar
All of that.
I worry more about the top of exhaust, and both of the inside radii. And all heinous sharp spots and boogers.
The chamber work all depends on the application.
Old 06-16-2022, 08:09 PM   #10
project volvo
spoolakowski
project volvo's Avatar
So these were already ported correct?
Anyone happen to have the head that was like two heads combined for better flow. Can't seem to find it anywhere but swore it was a Volvo guy and it was a significant mod.
SIG
project slowski (old project now gone)^^^
New Project Slug Works
my feedback thread here > FEEEEDBACK!!!!
project volvo is offline   Reply With Quote
Old 06-16-2022, 08:14 PM   #11
redblockpowered
mails files to people
redblockpowered's Avatar
If there's port work I don't see it. And I don't know what you're talking about but it does sound fun.
I sell chips for LH 2.4!
If you live in the Northeast US, I'll drive to you and tune your LH 2.4 car!
redblockpowered is online now   Reply With Quote
Old 06-17-2022, 08:49 AM   #12
Swedbrick
Swedbrick's Avatar
No these are completely untouched;)
Old 06-17-2022, 09:29 AM   #13
mikep
The MP
mikep's Avatar
From what i remember, all the 8v aluminum volvo heads share the same exhaust ports.
The early and late style improved intake ports are close the identical from pics i have seen, but i only remember working on a few 531 heads, so i can’t be sure.
I can’t remember any chamber variations, but the B21s had a chamber that was wider than the cylinder by a small amount.
I don’t have a pic of a 398 on a B21, but here is a 530 on a B21.
Old 06-18-2022, 10:34 PM   #14
hessam69
The differences are small coolant passage and large coolant passage also
