Old 04-13-2020, 12:52 PM   #101
James M
Probably colorblind
James M's Avatar
Originally Posted by J ripper View Post
The fella I got it from said he had some paint “matched up” and painted the cowl vent and I believe the A pillars were done too.
That seems about right, it matches up the A pillar pretty well but the cowl is flaking off and it's noticeably different
Old 04-19-2020, 09:50 PM   #102
James M
Probably colorblind
James M's Avatar
Drove the 242 to sac, open downpipe is a little much after a week.
Got a shifter from a SN95 GT, had to trim the front of the hole a little with an angle grinder supplied by the mustang guys I got the shifter from
20200419-140210
Also picked up a foxbody swaybar, about 6 inches in diameter based off my measurment. Someone about a decade ago here said it would work so naturally I took that information without any salt grains and bought one
20200419-140232
To quite down the open downpipe I grabbed a mangaflow somthing or other off a mustang at the Pnp, came with an over axle section I may try to use. No pictures but it's about as sketchy as it sounds.
At this point the car is about 50% 240, 30% 850r and 20% mustang
After driving the car for a week and a half I missed the wagon so I put the driveshaft back in that. Should have all the parts for the Colman shaft soon enough and get that balanced soon
Old 04-27-2020, 04:41 PM   #103
James M
Probably colorblind
James M's Avatar
Finally put the 242 back together again, now with its own driveshaft and intercooler bits.
Seems like the driveshaft I got was from a SN95 V8? Had to throw a different front slip yoke on it. Still waiting for the right flandge to make the Colman shaft
20200426-155720
Also finally put in a muffler, no more deafening open downpipe. Accidentally got a flowmaster from the junkyard , it will work for now.
****ty axle dump because I had 30 minutes to make it:
20200426-175717
Driveshaft angle isn't the best, I probably need the Crossmember spacers from an automatic and to adjust the mount some more, I used a IPD adjustable panhard bar to get it to stop rubbing but the diff side isn't the issue
20200426-225753
On a side note anyone else notice the adjustible panhard bar doesn't get all that much shorter? I could make it 2 inches longer but no more then 1/4 inch shorter. Maybe a thinner locking nut when I swap it into my wagon
20200426-224417
Old 04-29-2020, 04:26 PM   #104
James M
Probably colorblind
James M's Avatar
Added a lip to some charged air pipes and installed a BCV, still trying to get that to work but when it does I hope to not blow my intake pipes off
20200428-183505
20200428-183520
Also had the fan turn on so I'm less spooked of a missing temp gauge, surprised it takes until 205f to get the low speed to trigger
Old 04-29-2020, 06:00 PM   #105
honeylake
Did I miss the video of that sweet 5 pot singing it's song?
honeylake is offline   Reply With Quote
Old 05-01-2020, 12:09 AM   #106
James M
Probably colorblind
James M's Avatar
Didn't miss it, I got around to taking some today, not very good videos, then ****ed up more by email compression but the sound is alright
Also set up Datalogging with the ECU, I guess I technically have a tach now?
20200430-175815
After messing with the ECU some more and doing a few runs I got it to make 5-6psi, then discovered my issue is the throttle bracket is very poorly adjusted, only allowing ~52 percent throttle opening. Gotta tighten the cable and adjust the bracket a little. I'll probably make a new one down the line as I don't think this one will open all the way
Old 05-10-2020, 08:52 PM   #107
James M
Probably colorblind
James M's Avatar
Did some towing with my wagon this week, blew a tire on my tow dolly on the way up, and an oil seal in the turbo on the way back, but It made it both ways
20200505-140408-0
20200507-182216-1
Dropped another car over the front of my dolly, might be a little design flaw
20200505-170847
Also finally got a nice ratchet, cost nearly as much as the E30 I was towing, but its nice and smooth
20200424-075655
I'll be dailying the 242 now, with the throttle adjusted I get ~66% open, better and able to make maybe 8/9 psi, but not ideal or permanent. I need a longer rod linkage and a new cable, then maybe I'll get close to WOT. I've seen some spools that look like they go between the intake runners? Anyone have any close ups on their setups to share?
Both cars tucked into my gf's driveway, just to show the 242 since this is it's thread
20200430-171859
Old 05-12-2020, 08:58 AM   #108
The Full Banana
not yet good enough
The Full Banana's Avatar
This throttle setup works great, but will require some welding:
IIRC, it’s brackets, spool and cable from a b230 equipped 240, and a 850 or 960 linkage rod. The arm that the linkage attaches to on the throttle body also had to be cobbled together out of two arms, but it was too long ago to recall what they were from.
-Tom 1980 242 T5
Old 05-12-2020, 09:23 PM   #109
James M
Probably colorblind
James M's Avatar
Looks much cleaner then mine, the deeworks TB adapter unfortunately puts the TB at a slight angle, I also using the same cable and spool but without welding on the manifold. Seems more and more like I need some 100% argon
Old 05-17-2020, 02:42 AM   #110
James M
Probably colorblind
James M's Avatar
Finally did some general cleanup on the car, Installed taillight cover and spare tire carpet, took my **** out of the trunk and put the interior back together.
20200516-185131
20200516-185428
20200516-190003
Shift boot wants to pull the transmission out of 1st 3rd and 5th, I'll have to get one that's not the rubber accordion style but still looks pretty natural in the car.
Anyone have the brown radio face-plate I'm missing in the third picture?
Old 06-30-2020, 10:58 PM   #111
James M
Probably colorblind
James M's Avatar
Got back to the car, remade the throttle bracket, now goes WOT and feels like a whole different car. Looks really ****ty so I'll probably get some 100% argon and try MIG welding aluminum. Have a spare intake manifold and 960 throttle body I may use.
Also fixed a misfire, dead coil on cylinder 2, had an issue with it before because of my ECU soldering so maybe that wore out the used coil.
Installed a triple gauge pod, looks good but only have the boost gauge working. Now to get a 5Bar oil pressure sender (VDO-360-002) and wire it up.
20200629-184033
Old 07-01-2020, 02:30 PM   #112
Stiggy Pop
Stiggy Pop's Avatar
20200516-185131
20200516-185428
20200516-190003
This used to happen to me, would slowly pull it out of 5th. I had an aftermarket accordion booty that was pretty new. I picked up a used OE boot at a swap meet and it was much thinner and more flexible, haven't had the problem since swapping them out.
'79 242
943 pickup
Old 07-01-2020, 10:01 PM   #113
James M
Probably colorblind
James M's Avatar
It's got the original one, the issue is more with the adapter depth and my mounts. My redblock powered car has the same OE accordian style one but doesn't pull the T5 shifter at all as it sits much more centered in the shifter hole.
20200628-181148
With the 242 going again it's taking over DD duty, wagon smokes a ton on hot starts and stalls when going from load to idle, don't need a cloud of smoke at every light.
Old Yesterday, 01:11 AM   #114
James M
Probably colorblind
James M's Avatar
Gauges all wired in, Voltage reads well but I bought the wrong size oil pressure sender, 2010 Volvospeed lied to me listing it as m12x1.5, popped the oil dummy light twitch out to find it's m14x1.5
20200703-191043
20200703-191705
Also wired in the tach, reads a little off but I may correct it with a faceplate down the line, assuming there is a faceplate to match the reading of a I5
Next up in the gauge department is to fix all the lights, currently only two LED ones come on, going to replace them all with normal bulbs that arn't blown. Then figure out why the gas gauge reads about half all the time and get a Me7 thermostate housing for it's second port, install a b23 Coolant temp sending unit. Then maybe if I want this to be my one car with a working spedo get an adapter build for T5 transmission to 240 spedo cable
