Old 04-22-2021, 06:55 AM   #1
Volvo740brick
Exclamation Manual Swap t5 1989 Volvo 740 gle
Hey guys, new to this site and wanted to know what’s involved and what’s need to swap a t5 onto the b230f engine and if it can be done. Also what t5 trans should I use? Do I need the Volvo manual pedal box? Does a t56 trans fit?
Volvo740brick is offline   Reply With Quote
Old 04-24-2021, 01:57 PM   #2
DavePolyakov
I recently did the t5 swap in my 1990 740t. You will need to buy a 740/940 manual pedal box, it's up to you to source a cable clutch system or hydraulic pedal box. I don't believe there are any t56 to redblock adapter plates that anybody makes, I could be mistaken.
The biggest issue with the swap is the shifter relocation. With the mustang tail housing on the t5 (probably most common) the shifter is several inches too far forward. I had to modify my shifter with some quarter-inch steel to move it back. When the transmission is removed and there is room underneath the car you should hammer out the shifter opening as well. I believe if you find a t5 with a camaro tailhousing then the shifter position won't be an issue in a 740/940. Here is a photo of what I did
Lastly, the t5 really messes up your driveshaft angles, I had to raise my transmission 3/4inches upward from the max height using the Yoshifab 740 t5 transmission cross-member. So at maximum height using the adjustability within the cross-member, I had to shim it up an additional 3/4inch. You will need to buy adjustable torque rods or make your own to raise the pinion angles as well.
DavePolyakov is offline   Reply With Quote
Old 04-26-2021, 07:12 PM   #3
Volvo740brick
Are you located in Australia? If so can I give you a call or message and talk about some other questions I had? Also I can’t seem to find a pedal box anywhere do you know where I can get one?
Old 04-30-2021, 06:50 PM   #4
Fast740fromSC
Fast740fromSC's Avatar
If you plan on making anything north of 300whp spend the money on a cd009.
Fast740fromSC is offline   Reply With Quote
Old 05-05-2021, 12:38 PM   #5
DavePolyakov
I used to live in Brisbane from 2006-2008! I found my pedal box on the forums, the cable one seems to pop up more than the hydraulic system pedal box. I'm still dialing in driveshaft angles which have been the largest annoyance of the project. Message me, maybe we can have a quick phone chat, or I can send you a parts list!
Originally Posted by Volvo740brick View Post
Are you located in Australia? If so can I give you a call or message and talk about some other questions I had? Also, I can’t seem to find a pedal box anywhere do you know where I can get one?
Old 05-07-2021, 02:27 AM   #6
hk 40
hk 40's Avatar
In times of repair I think u'd like the non hydraulic unit better. The more fancy **** you put on the cars the more work it is to fix it when it fails. Man get an old one and the master cylinder on it goes u gotta deal with a kit and fluid etc right? If a cable snaps u just replace it. Maybe I'm wrong but I've had a similar setup in a 84 nissan/datsun 200sx turbo and had to replace the hydraulic unit when the master failed. Id rather install a cable.
Regards,
Hubert
Original Join date 5-21-2003
assuming we have an electrical circuit containing a power source and a solenoid of inductance L , we can write the equation of magnetic energy, E , stored in the inductor as: E = 1/2 * L * I² , where I is the current flowing through the wire
I have an ecu which has 8 channels of full sequential fuel and ignition control .
hk 40 is offline   Reply With Quote
Old 05-07-2021, 11:41 AM   #7
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
This writeup has a good parts list.
You only need the clutch pedal, you can cut down the width of your brake pedal if need be
https://www.volvoclub.org.uk/faq/Vol...Conversion.htm
