Jack
junkman
- Jul 7, 2011
- The Ass Cheek Of History
I love them but
$200 for a set of 4 black
Or ~$200 each for actual white walls
Vitor galaxy V1 is like $64 each in 195/60r15
Absolutely, the way that thing sits is motivating me to get an amazon.
When you get the tires you mentioned in the first post consider some whitewalls, they look great on Jack's car if you've seen his thread
Well if you want your car to handle you should go with wider wheels
Stock pizza cutters even in 4.5 make the car a handful (something I enjoy)
Add that to non performing whitewalls ...
Man this looks like a pretty nice car! I vote for whitewalls or something a little more classic.
Yeah I agree, I have the 5.5 wide steels right now, would love to maybe widen these wheels to fit a 205 tire on for a little better handling. Definitely don?t mind the ride right now but would love to fill out the wheel well a little more
5.5 on in these pictures ?
They look to be 4 or maybe 4.5
Nice progress on the interior!
I like how the 100mm spring look when the car is not moving but real world use is not pleasant at that height. I even went from 60mm lowered back to 40mm on mine because I like to take my car on gravel roads every so often. Also, suspension geometry starts to get a little wacky at that height, but for cruising 100mm looks sweet!
I have no issues with the same springs and Bilstein shocks. put about 15k miles on it last year. I even take on dirt roads
with the lower balljoint flip alignment comes in perfect and CAs sit nice and level.
is the ride a little firm - sure but not slammed ricebowl car stiff
Just look at my 66 build thread
Just looked at your thread, very impressive. Would love to tackle some body work like you did eventually.
When you lowered the car did you just get some bolts at a hardware store for the sway bar endlinks?
Thank you. Amazons are a great classroom for bodywork. Hard to mess it up
Not sure anymore... I have a ton of this stuff, I think I had an installation kit from ipd in one of my stashes otherwise I would have just used the old stuff
I have the whole qt panel of you ended up needing it. No coupe doors right now
I didn?t see a need for a shorter bolt, just go to fastenall and they?ll have it in stock
