olov
doing something stupid
- Aug 11, 2003
- warrenton, nc 27589
so my 93 940, been driving it for months and haven't touched the brake system other than general inspection. the other day i was on the highway, and when i got off on my exit the brake pedal went 4-5 inches lower than usual, after my heart stopped the brakes started to grab and they worked fine other than the low pedal. go down a few stoplights and sometimes the pedal would be high, sometimes it would drop to the low position. i checked the fluid - full but old, and the vacuum line looks fine but old, didn't see any leaks or obvious brake line issues under the car.
i am going to do the quick booster check i've found in searching, but this is a new problem for me, no idea what it could be. and i really don't like a low pedal, don't want to mess up the master cylinder if it's not broken
*update
ok, bleed the brakes a little bit(old school pump pedal and open bleeder way), found some air in the right rear line, all the others looked good, just did the bleeders on the calipers. pedal is still soft, but so far it hasn't dropped(will not know till i drive it more really)
priced a new master cyl at napa, $100 but it'll take a day to get it from another store. now i'm looking on ebay and some of the new ones listed look really odd. should i get a certain brand or should it be ok to go for the one from napa/etc?
update 2
master cyl at napa wasn't even close to the same, just bought some new fluid, pulled off the reservoir and emptied it, filled it with new fluid, slowly mounted it on the master cyl to keep air out, then gravity bleed from the furthest away to the closest till new fluid came out, took forever but pedal is consistent and doesn't drop anymore. still spongy before it engages but that might just be an abs 940 thing
*update
update 2
