Old 11-23-2019, 11:43 AM   #1
Default 300 Badge Time?
Final numbers were 280hp at 6700 RPM and 240 lbs ft at 5200 at the wheels. 10 PSI (gate pressure) Fuel pressure was dropping after that. Has another 1000 rpm, more boost, and more timing in it.
Tuner suspects a fuel pump issue (AEM 320). I'll be swapping in a Walbro 450 with some bulkhead fittings and go from there.
[IMG]
Old 11-23-2019, 12:14 PM   #2
Mbeas96
Mbeas96's Avatar
For everyone asking what it takes to make 300hp.
What is your setup?
Old 11-23-2019, 12:51 PM   #3
thelostartof
unbalanced chemical
thelostartof's Avatar
Looks like 16vT
https://forums.turbobricks.com/showt...304080/jlWoqte
Nice numbers at such low boost.
thelostartof is offline   Reply With Quote
Old 11-23-2019, 04:58 PM   #4
DurableSwedish
Hunting for a turbo
DurableSwedish's Avatar
Weird, I wonder why mine made so much more torque? like like double at 3k lol
One Volvo left.
1982 244ti (313chp), 2020 Nissan Leaf daily driver, 86 Yugo GV junk pile/gambler car
DurableSwedish is offline   Reply With Quote
Old 11-23-2019, 05:37 PM   #5
ermit71
ermit71's Avatar
Sounds nice.
Congrats Harold!
Feedback
ermit71 is offline   Reply With Quote
Old 11-23-2019, 05:48 PM   #6
Vol242vo
Keep it clean...
Vol242vo's Avatar
So awesome, congrats! That’s some decent power!
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 11-23-2019, 06:16 PM   #7
Broke4speed
Broke4speed's Avatar
A 320 isn't enough pump for 280whp? Is it just really old? How's the wiring?
1984 244/ AQ140A / M46
Old 11-23-2019, 06:21 PM   #8
DurableSwedish
Hunting for a turbo
I'm just using the stock 80s k-jet fuel pumps on mine, they said the 650 injectors in mine has plenty of breathing room. I'm at 23psi too, I wonder how your fancy performance one is out of flow at much lower boost and not much more hp...
Old 11-23-2019, 06:50 PM   #9
Either the pump crapped out or there was an external draw from something else I had wired in that was getting in the way. Both the fuel pressure and flex fuel sensors were going to zero at the same time.
It also has less torque because the turbo is barely doing anything. Yours on the other hand is working very hard. Your engine is out of puff before 5000 whereas mine would be making power to past 7500. It should make past 400 on e85 as is.
Old 11-23-2019, 06:54 PM   #10
DurableSwedish
Hunting for a turbo
Where do you buy e85? Whats the sweet spot for boost for your turbo?
Old 11-23-2019, 07:13 PM   #11
Downtown and **** if I know, that's why it's getting tuned on a dyno.
Old 11-23-2019, 09:39 PM   #12
2turbotoys
Salaminizer
2turbotoys's Avatar
Very nice! Congrats and look forward to seeing a new dyno with the the Walbro installed.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 11-23-2019, 09:54 PM   #13
Thanks! The powerband is awesome except when lugging it from idle in 1st gear, lol
Old 11-23-2019, 10:14 PM   #14
2turbotoys
Salaminizer
2turbotoys's Avatar
High ratio rear?
Old 11-23-2019, 10:59 PM   #15
It is slightly tall and there is very little torque below 2000. It's happy being lugged but doesn't have much torque. I'll post some specs soon.
Old 11-24-2019, 12:54 PM   #16
Here ya go ...
how psi stock cna sprout?
Old 11-25-2019, 01:48 PM   #17
Well done!
Old 11-25-2019, 02:24 PM   #18
Be careful with the timing. I was running more advance on my 16VT, because it felt freaking awesome (and I was using E85), but it kept blowing Cometic HG's with some sad degree of regularity. With a flat block/head, installed with copper spray/hylomar/dry, ARP head studs cranked modestly tighter than spec.
At some point, you are getting more power, and not hearing detonation, but it's putting a lot of stress on the motor. Leave some timing on the table, and drive the car longer in between HG's is my advice.
Old 11-25-2019, 06:50 PM   #19
Good to know. I'm going to be doing all of the timing advance tuning on the rollers as I have come to find out that the 16v stuff is knock resistant enough to be sneaky about causing trouble.
As promised to some folks wondering about the setup, here it is:
1989 16v cylinder head, some cleanup on intake ports
Reground stock B234F cams, to match the Techtonics 276* mild race 16v grind
VW ABA lifters
lash caps
Some aftermarket valve spring setup (I forgot which)
Modified Yoshifab intake manifold setup with 960 throttle body
Yoshifab 8v adapter plate with 90+ exhaust manifold
eBay "GT3071" mistery turbo
TiAL MVS 38mm with 8 PSI spring
Stock B230FT pistons, flycut
SPM 152mm rods
MS3X
LS2 coils
ID1300x injectors
KL Racing intercooler
Forge 007 bypass valve
3" JT Tuning exhaust
Old 11-26-2019, 10:44 AM   #20
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
smoothing 5? afraid to show how choppy the timing map is?
Megasquirt Tuning!
Old 11-26-2019, 01:40 PM   #21
I didn't touch the dyno, dude. It feels smooth by the seat of the pants, but that is entirely subjective.
Old 11-26-2019, 04:56 PM   #22
oldschoolvolvo
oldschoolvolvo's Avatar
Nice work sir.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 11-26-2019, 07:00 PM   #23
ermit71
ermit71's Avatar
I didn't touch the dyno dude
Was he disappointed?
Old 11-27-2019, 11:06 AM   #24
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
May have made 300 if Harald wasn't such a prude
1980 242 Turbo
2004 V70R
Old 11-27-2019, 11:30 AM   #25
linuxman51
linuxman51's Avatar
