Old 07-17-2019, 11:47 AM   #1
740atl
potty mouth
740atl's Avatar
Default 240 sunroof weatherstripping.... OMG is there another source or another material?
I just had a round replacing the sunroof weatherstripping on my 242. I won’t say I did an abominable job but it won’t win any awards.
Does anyone have a different source for the material? Like bulk stock? Both the front and rear are exactly the same material. Possibly another material that would work?
This is what the material looks like btw...
Old 07-17-2019, 10:42 PM   #2
durk80
durk80's Avatar
I'd say that I would like to know as well because the material is pretty unique to say the least. Just make sure that your sunroof drains are completely free and clear of debris. Use an air compressor to blow out the two holes, one in each top corner to ensure that the water has a place to go instead of inside. While you are shooting air into the hole, plug the drain hole in your door with your finger to see how it flows. You can also blow air into the drain hoses in the trunk to allow for more efficient drainage.
durk80 is offline   Reply With Quote
Old 07-18-2019, 10:34 AM   #3
240-FAN
I would like to know as well as the seal has dry rotted on my 240.
OP, how did you go about replacing the seal?
I’m assuming when you say weatherstripping, it’s the black seal that’s sitting on the top periphery, inside the body side of the roof?
240-FAN is offline   Reply With Quote
Old 07-19-2019, 08:15 AM   #4
S70T5fivespeed
Its always 7:4O somewhere
S70T5fivespeed's Avatar
Not sure exactly what you’re looking for but skandix has some seals listed. That’s where I got my last 740 one.
99 S70T5M black on graphite
91 740SE white on black
90 740TI black on checkers
In the barn: 67 123GT
S70T5fivespeed is offline   Reply With Quote
Old 07-19-2019, 09:34 PM   #5
carver
Involvoed
carver's Avatar
Originally Posted by S70T5fivespeed View Post
Not sure exactly what youíre looking for but skandix has some seals listed. Thatís where I got my last 740 one.
This stuff perhaps?
carver is offline   Reply With Quote
Old 07-19-2019, 09:38 PM   #6
2turbotoys
Salaminizer
2turbotoys's Avatar
I know I saw that material on Skandix (as said above) and at VP...wish VP wasn't so hard to search
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 07-23-2019, 07:01 AM   #7
740atl
potty mouth
740atl's Avatar
Wow, I haven't checked this thread in a week, didn't realize anyone responded.
Iím assuming when you say weatherstripping, itís the black seal thatís sitting on the top periphery, inside the body side of the roof?
I used the information from this thread http://turbobricks.com/forums/showthread.php?t=144252.
My old seal was completely dry rotted as well. Ended up using 3M adhesive remover. It's a spray. Do it on a cool day. Spray the remaining seal and ended up using a series of plastic putty knives to remove the old seal. I unfortunately scraped off paint so before I put the new seal on I taped and painted the sunroof lip.
Using the 3M super weatherstripping adhesive(which must be made from boiled leeches), I lightly coated the sunroof w-strip as well as the lip where it was to go. I had to tape the w-strip to a board to apply the adhesive otherwise as soon as you apply the adhesive, it is stuck to your finger. Definitely use gloves. Once you start applying the w-strip you have very little time to make a correction. I mean, you have seconds to make a correction and then it's stuck forever.
In terms of order of operations, you need to
  1. remove the sunroof first (open the sunroof a bit, pry back the sunroof headliner and slide it all the way back. This gives you access to the 8 bolts... Take a picture so you remember how to get them back in. remove the 8 bolts, then gently slide the sunroof forward then up and out. You might want to tape the roof forward of the sunroof in case you scratch the paint).
  2. Remove the rear weatherstripping then glue new w-strip to the back first and let it cure a bit Remember to angle it down on the edges.
  3. Don't immediately do the front strip. I recommend reinstalling the sunroof and roll it all the way back... The reason is this... If you install the front seal (the sides and front) before you put the sunroof back in, the gap is a tiny bit smaller and you have to push the sunroof through your newly installed w-strip... very frustrating and messy. My w-strip actually came off in a few places when trying to cram the sunroof back in place... so note to self.
  4. install the sunroof, reattach the 8 bolts, using a finger, push the sunroof slider chain/rope all the way forward on each side and then roll or push the sunroof all they way back in the car.
  5. install the front w-strip. Be sure you're putting it where you want it. I started from the passenger side rear and put it in place with my left hand while dangling the rest up in the air with the right hand. Work your way across and to the other side. Frequently look or have a partner look to make sure it's not sticking up too far above the roofline.
BTW the 3M adhesive and adhesive remover are easily available at advance auto parts.
I was wondering if there is any other material to use besides the stock stuff? Does the w-strip have to be exactly what volvo used or is there another material that would be suitable?
Old 07-23-2019, 12:18 PM   #8
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Do you have access to the original stuff? Can you post pictures of the profile? I would love to help dig around and look for a suitable replacement as my sunroof no longer has any of the seals anymore.
1980 242 Turbo
2004 V70R
Old 07-23-2019, 04:57 PM   #9
740atl
potty mouth
740atl's Avatar
Only skandix has the original seals per the part numbers. iPd still sells the rear seal $45.
Old 07-23-2019, 11:04 PM   #10
2turbotoys
Salaminizer
2turbotoys's Avatar
I'm doing a Skandix order soon, check the group buys if you want in...
Old 07-23-2019, 11:20 PM   #11
240-FAN
Can’t the seals be special ordered from the dealerships?
OP, thank you for the detailed write up.
Old 07-24-2019, 04:18 PM   #12
240-FAN
Originally Posted by 740atl View Post
I just had a round replacing the sunroof weatherstripping on my 242. I wonít say I did an abominable job but it wonít win any awards.
Did you end up finding something stateside without having to order from Skandix?
Old 07-24-2019, 06:51 PM   #13
planetman
planetman's Avatar
The 2 seals that mount directly to the sunroof are available here in the US for $108.00 plus shipping.
There is an additional seal that mounts behind the sunroof opening for the rear unseen section of the sunroof and it costs an additional $18.00.
Eric
Torrance, CA 90502
Old 07-24-2019, 09:35 PM   #14
Mr. V
Mr. V's Avatar
Do you guys sell it?
The reason I ask is I checked your website and didn't see anything for 240's and beyond.
Old 07-24-2019, 09:43 PM   #15
planetman
planetman's Avatar
Yes, we do. I don't have them in stock right now. The last set went to Puerto Rico back in May and I forgot to reorder.
I can usually have them in a few days.
Old 07-24-2019, 09:45 PM   #16
boostdemon
creative mastermind
boostdemon's Avatar
I wonder if we could drum up enough interest to do a group buy for these sunroof seal sets. I'd be in for a couple for sure.
"the best way to get the right answer on the internet is not to ask a question; it's to post the wrong answer."
1983 242 TIC Flathood
1986 745 GLE
1988 Toyota Pickup 4x4
2001 V70 T5
2001 V70 XC
2004 V70 R Flash Green
2004 V70 R Grey
"Flathood" Owners | Motorcyclists | Guitarists
boostdemon is offline   Reply With Quote
Old 07-24-2019, 10:37 PM   #17
planetman
planetman's Avatar
At this point, the website is more focused on 1975 and earlier OHV Volvos and the majority of our inventory is focused on those years.
The website is no where near complete, so even though there were pre-1976 Volvos with sunroofs, those parts are not currently on the website.
Since we service all rear wheel drive Volvo cars, we can supply most of the available parts for the 200, 700 and 900 series Volvos.
Old 07-24-2019, 10:52 PM   #18
240-FAN
Iím down for a set as well. I need both the seals.
Just let me know when you have them in stock and I will be happy to pay for them.
Old 07-25-2019, 12:43 AM   #19
planetman
planetman's Avatar
PM sent.
Old 07-25-2019, 12:43 AM   #20
planetman
planetman's Avatar
I’m down for a set as well. I need both the seals.
I'll get back to you tomorrow.
Old 07-25-2019, 09:41 AM   #21
Mr. V
Mr. V's Avatar
Do you have access / have available the sunroof seal(s) for a 1986 740 Turbo sedan?
Is so, what cost, what availability, and what's the best way to order it?
Old 07-25-2019, 11:55 PM   #22
planetman
planetman's Avatar
Both 740 sedan sunroof seals appear to be available.
The front seat is $41.21 and the rear seal is $25.96 and are OE.
Let me know if you are interested and I will find out how long to get them. If they have to be ordered from Sweden, it will take about a month.
Old 08-22-2019, 07:24 AM   #23
240-FAN
Got this done yesterday. All my 3 seals were crusty.
Holy ****, is getting that sunroof back in a sh**show or what?
And then, PO has jacked up the sunroof mechanism. So the rear bracket on the driver’s side is off by 1/2 - 3/4 revolution.
Had to take the sunroof off a couple of times to get it close. In the process, the large seal (the one on the three sides on the sunroof hole) got ripped (velvet stuff separated from
The inner runner tube) in quite a few places.
1. Any ideas on how to align the sunroof correctly?
2. Is the seal ok or do I need to replace it?
