Old 04-25-2021, 01:22 PM   #1
Johnnya101
Default Help with underwood light (Need photo)
I have a 1991 245 that has the factory hood and factory mercury hood light, however there is no wire going to it. I am quite puzzled. There is no green wire floating around the engine either. Would anyone with a late 240 be able to post photos or at least describe where the wire starts so I can see where it is or where it was cut?
Side question: what is this red wire for? It is very short.
HAVE
1991 245SE here
SOLD
1988 240DL Sedan
Johnnya101 is offline   Reply With Quote
Old 04-25-2021, 01:39 PM   #2
whatshouldido
The red wire is a jumper location to trigger your starter motor for diagnostic purposes,
Plug in a wire and tap to +12v on the battery and itll kick over the motor, ignition on the car will start
Good luck with your light
---1991 volvo 745 turbo wagon
**m47 swap incoming !
--1977 244 360k+ miles all original
** drive till wheels fall off
whatshouldido is offline   Reply With Quote
Old 04-25-2021, 01:46 PM   #3
Johnnya101
Interesting feature, thanks for answering that.
Old 04-25-2021, 04:39 PM   #4
MasterBlaster
MasterBlaster's Avatar
A quick Google search shows the wire's protective sleeve sneaking out of the hood,
and being strapped to the left hinge. It then hides behind the left shock tower.
Where it goes from there is a mystery that has stumped scholars and "experts" for thousands of years.
1990 740GL
515,000 km so far...
Old 04-25-2021, 05:04 PM   #5
The Librarian
The starter test lead wire is either blue (early) or pink (late). The red thing is a sleeve on the wire with the part number for the harness.
On pre '90 models the wire for the under hood light breaks out of the harness near the brake booster. The light was eliminated '91- according the the parts catalog. There is no wire in the harness for the light. I checked a '91 244 and it's not there.
All you need to do is run a wire to the fuse box and connect it to fuse 8.
Old 04-25-2021, 05:12 PM   #6
Johnnya101
Very helpful, thank you! Strange there is a light that clearly was used, yet no wire! Did the 240 you check have the light yet no wire?
Such a small detail, just bugs me though.
Old 04-25-2021, 05:24 PM   #7
The Librarian
The car has a replacement hood so I can't say for sure.
Are you sure your hood is original?
Old 04-25-2021, 05:49 PM   #8
Johnnya101
Positive. No accidents, hood paint matches wear pattern on the rest of the body, no marks on hinges or bolts.
Old 04-25-2021, 06:06 PM   #9
Johnnya101
I see what happened now. Looking at ebay photos, 1991 on they left out the light and wire, however they kept the rectangular cutout and screw hole. Someone threw a light in and didn't know they never had it factory. Figured they would at least remove the rectangle cutout or put a plate there.
hyperfauto, thank you for the info regarding wire location.
