Old 03-02-2021, 04:14 PM   #126
R-Pow3R3d
Master of Disaster
R-Pow3R3d's Avatar
Originally Posted by jstblz View Post
I have family in the Cranberry area. Hopefully we can link up this summer.
That would be awesome. I better get the 740 cleaned up. lol
1990 745 Turbo Intercooler
2007 XC90 V8 Sport
2007 XC70
R-Pow3R3d
R-Pow3R3d is offline   Reply With Quote
Old 03-15-2021, 02:30 AM   #127
jstblz
jstblz's Avatar
Time for a quick update...
Added 3M paint protection film (shiny part) to certain sections of the cage to to save the paint from entry and exit wear.
Washed junkyard carpet and sprayed and brushed in between coats of SEM color coat in Landau Black. It's even darker in person.
Wrapped the downpipe in PTP's Lava wrap
*DRUMROLLS* Final wiring started!!
Mounting plate for new fuse panel
Great accessibility here
Decided to get a grounding block to organize the grounds and not stack them all under 2 screws. The bottom lug was connected with 8GA to ground. This will be the ground for most things on the dash. Using a separate ground for the stereo and instrument cluster. Any issue with that??
Even re-taped the accessory connectors
Using this bluetooth, marine Kenwood unit for the stereo system. Mounting the amp under the passenger seat
84 242 TIC
jstblz is offline   Reply With Quote
Old 03-15-2021, 06:28 AM   #128
JerryJS8
der Junge
JerryJS8's Avatar
Nice, I like the hidden and minimalistic radio install!
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
JerryJS8 is online now   Reply With Quote
Old 03-18-2021, 09:57 AM   #129
jstblz
jstblz's Avatar
Same here! I use my phone for GPS and music so no need for a disc or heavier screened unit.
Old 03-18-2021, 01:01 PM   #130
DET17
Reformed SAABaholic
Regarding the quality of your grounds...... simply measure resistance from those junction points back to the battery NEG terminal. If you've got marginal grounds, you will see it on your Ohmmeter.
Old 03-18-2021, 01:33 PM   #131
jstblz
jstblz's Avatar
Ok, makes sense. I'll verify and update.
All good! Thanks
Old 04-15-2021, 01:35 PM   #132
jstblz
jstblz's Avatar
So work/non-car life has been kicking my butt lately, but progress has been made.
I'm putting some things back together
Doubled up some black speaker felt to cover where the old reels went.
Looks like it'll do
Made some thumb nuts for my VDO external temp gauge.
GPS antenna for the RaceCapture/digital dash integration. It comes with one, but it sits on your dash or magnetized to the top of the car. Seeing as though this will be an important system, I decided for something permanent and nice.
The wire from which will run down the roof and to the dash behind the filler panel to the RaceCapture module.
Getting dangerously close to the final design of the touchscreen panel. That'll be the next big update. Looking like I may be good for inspection and tuning by mid May.
Old 04-19-2021, 05:01 PM   #133
jstblz
jstblz's Avatar
Default Instrument cluster
It's all based arounnd this Raspberry Pi 3 in an aluminum case with built-in fans.
This board from Mausberry that safely power on and shutdown when the car is turned on and off.
I also mounted the entire case to the screen.
I made a quick and dirty surround for some earlier testing, but I ended up scrapping that
So I designed something better...
This will eventually get printed in the black heat resistant filament.
Old 04-21-2021, 10:43 AM   #134
aidanahunter
aidanahunter's Avatar
Very nice
aidanahunter is offline   Reply With Quote
Old 04-23-2021, 01:22 PM   #135
Jerd
Jerd's Avatar
Such cool stuff, work faster!
Old 04-24-2021, 12:08 PM   #136
jstblz
jstblz's Avatar
Work keeps getting in the way haha
Old 05-02-2021, 05:00 PM   #137
Fast740fromSC
Fast740fromSC's Avatar
Awesome build!!
Fast740fromSC is offline   Reply With Quote
Old 05-02-2021, 05:03 PM   #138
Project
Project's Avatar
Iím so glad someone is doing this. I had thought about ordering a crate 2.3 exoboost but was really expensive.
learning lessons the hard way since 1986.
Project is offline   Reply With Quote
Old 05-02-2021, 09:10 PM   #139
jstblz
jstblz's Avatar
Originally Posted by Fast740fromSC View Post
Awesome build!!
Thank you!
yeah, but thankfully junkyard motors work with the kit.
Old 05-12-2021, 11:18 AM   #140
jstblz
jstblz's Avatar
Instrument cluster is done!
Dropped of the wheels to get refinished. Sticking with the stock color.
These just arrived too...
Where we are:
-Wiring is done!
-Dash reassembly up next
-Carpet, seats, and harnesses this weekend
Hope to be getting my windshield next week and the inspection soon after.
Old 05-12-2021, 05:50 PM   #141
RvolvoR
I would return those and buy proper sized tires. Something with at least a 24.5" rolling diameter. This isn't a miata you're driving. Its a big car. It's going to look like roller skate wheels in the wheel wells.
Old 05-12-2021, 06:12 PM   #142
patrickstar
patrickstar's Avatar
I'm running the same size tire on 15x8 ET20 Epsilons and love them! 225/45R15 Federal 595RS-RR. Need to lower the rear a little bit more as well as 5-10mm spacers but otherwise am happy with fitment
1983 242 - 4.8/AR5
1980 242 - Shell
@beige242 on instagram
patrickstar is offline   Reply With Quote
Old 05-12-2021, 08:49 PM   #143
Carnage
Those Ecoboost Mustangs go pretty well, so this 240 should rip once you get it going.
Carnage is offline   Reply With Quote
Old 05-12-2021, 09:40 PM   #144
jstblz
jstblz's Avatar
This is me on 215/50r15. The new size will be .5" smaller in diameter.
Old 05-12-2021, 09:41 PM   #145
jstblz
jstblz's Avatar
I hoping so!!
Old 05-13-2021, 10:56 AM   #146
RvolvoR
yeah and a that looks like the tires are swimming in the wheel wells. .5" is a lot to take off of the diameter. I know options are kind of limited in that size, but the A052s are at least available in a 225/50-15.
Old 05-17-2021, 10:20 AM   #147
jstblz
jstblz's Avatar
Crazy how a little carpet really makes a huge difference.
Old 06-10-2021, 10:43 AM   #148
jstblz
jstblz's Avatar
Picking up the car from the body shop today. Rust repaired and a new windshield.
Before
During
After
Old 06-10-2021, 10:50 AM   #149
jstblz
jstblz's Avatar
And got the wheel back from being restored and the tires mounted and balanced.
Before
After
Old 06-22-2021, 08:17 PM   #150
jstblz
jstblz's Avatar
Got the car inspected this past Friday! Here are the lead up rush pics. A lot of finishing and fitment things weren't pictured, but there was some decent head banging fitting everything back in.
Stripped and repainted the arms and hit the stainless with a little scotch-brite.
The pilot's view...
Wheels on and I'm in love all over again.
Even made it to the Cars and Coffee on Sunday
Me towering over the car....
