Old 11-14-2008, 01:28 PM   #26
qwkswede
Old and Slow
Nice work on the failtastic post. The 8.8 axle tubes on the late explorer diffs are 3.25"x0.25" -that would eat a dana 30 axle tube as a light snack in the mid afternoon.
I'll take 31 splines, clutch type posi, good aftermarket, 4x4.5 bolt pattern for the price of a junkyard pull.
So how do you identify the lsd types? Is there a mark on the outside of the axle somewhere? What year explorers roughly?
Old 11-14-2008, 01:43 PM   #27
Mark
sex lights
Mark's Avatar
I was one of the guys Bondo talked to about the c-clips
2007 NHRA rules on C-clips-
All cars, except some ET cars as noted in Class Requirements, must be equipped with a satisfactory means of rear-axle retention; minimum .120-inch (3 mm) aluminum retainer, or .090-inch (2.3 mm) steel bearing retainer is mandatory. Stock ’C’ clip axle retention prohibited as outlined in Class Requirements.
Doesn't mention disc brakes. I was skimming through a couple of things that were saying it's a grey area in the rules. Apparently sometimes eliminators are required with disc brake cars despite the fact that it's exceedingly redundant. I agree with Bondo, but if you're looking build one for a track car it might be worth contacting the sanctioning body to ensure you're complying with the rules.
It's something to think about anyways.
M.
Originally Posted by Double02 View Post
Classic TBricks - pages of discussion debating whether or not to spend $20. On a tractor.
Incorrect, the Frigidaire is Mark's 86 745. It's in appliance white and it is Best Car.
The Fridge; '86 745 DD-with full '94 LH2.4 swap. Now with M90!
2000 AMG E55 wagon.
'78 Honda GL1000- naked Goldwing. Sold
'76 265 wagon with Megasquirted 350 chevy and T56. Scrapped
Mark is offline   Reply With Quote
Old 11-14-2008, 01:50 PM   #28
Mueller
Mueller's Avatar
M.
some of the c-clip eliminator kits come with new bearings and new plates....you just cannot remove the clips and install disc brakes and be done with it...at least that is how I see it...
Old 11-14-2008, 01:52 PM   #29
qwkswede
Old and Slow
Some interesting reading about the 9" design with regard to strength and parasitic loses. I just lifted this from another forum. So I can't vouch for the source, but it seems legit.
------snip------
I have a Moser 12 bolt, and have always owned 12 bolts, or 8.5 inch 10 bolt rear ends (except for the Dana’s in my trucks). If a 12 bolt would not meet my needs, and so far it has held up to a lot of abuse; then I would replace it with a Dana 60, never a FORD nine inch.
A FORD nine inch takes too much power to turn. I am Scotch. I like my horse power going to the ground, not heating the rear grease in my differential. The strength of a Ford nine inch comes from the fact that two teeth at a time are engaged by lowering the pinion to the bottom of the ring gear. Buy rubbing the pinion past two teeth at a time you double the friction. That is called parasitic loss. A Ford 9" usually has a parasitic rate of about 7% compared to 3% for the Spicer 12 bolt. That is 7% of your flywheel horse power (or what part of it that gets through the tranny which also has parasitic losses of their own) that never sees the tire.
To reduce the parasitic drag of the Hotchkiss nine inch design Strange offers a special aluminum Salisbury bolt in pumpkin that goes into a Ford nine inch housing that uses a Spicer 12 bolt Chevy ring gear and pinion (but it still looks like a Ford rear end).
---- snip------
Old 11-14-2008, 02:01 PM   #30
qwkswede
Old and Slow
if im cutting a rear end down, im putting the 9" ends on the tube.
I personally don't like the c-clip design for a couple reasons.
1. you can't pull the axles out without removing the center cover to pop the clips off.
2. I always ran the c-clips in my old mustang. And it always bothered me that there was .050-.100" play in the axles if you pushed them in and pulled them out. The cross shaft and C-clips were all fairly loose in all the axles I worked on. Especially with disk brakes, the moving axle can push the pads back into the caliper when you corner and the rotor and axle slide around. They also clunk sometimes. My car was a drum brake rear mustang. So, the brake problem wasn't a problem at all. But the axial play still bothered me.
-- I'll add to that a little after thinking about it --
That is probably one of the reasons for floating calipers. So they can move with the axle. But who wants that crap!
Old 11-14-2008, 02:03 PM   #31
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
Originally Posted by Mueller View Post
that does not make them better, just heavier...of course it is dependant on the application...
It must be friday and everyone is coasting into the weekend. Everyone's IQ seems to be at least 30 points lower than usual. Please tell me you don't actually need me to explain what's better about thicker tubes...
The jury is out on if NHRA will consider discs "a satisfactory means of axle retention". I've never heard of a tech guy ever even asking about c-clips though personally...
Ken,
The is a metal tag on the rear ends attached to the diff cover, there is a number that gives the ratio with a letter in the middle, like a 3.73 is a 3x73 If there is and "L" ther is is a limited slip. Like an 3L73 is a 3.73 with a posi. SOmehting like that. Look for an "L" anyways.
Kepe in mind most c-clip eliminator kits are OUTLAWED for roadracing- they don't like side loads and tend to want to leka diff oil onto your brakes., I would avoid them at all costs.
-Kenny
Old 11-14-2008, 02:12 PM   #32
qwkswede
Old and Slow
Thanks for the info Bondo,
I have personally been quizzed about C-clips with my old mustang. I guess they had a reputation for the broken axle problem. And my local track in Colorado seems to be pretty strict on the rules. There isn't any reason not to comply considering the work I'll be doing to the axle anyway.
The 9" bearing retainers are fine for road racing right?
Old 11-14-2008, 02:19 PM   #33
Mueller
Mueller's Avatar
Ken,
I'm a believer that over-kill is over-kill, why not use 4"x .375" wall tubing by your thinking??
axle tube diameter is based on overall vehicle weight and capacity, I'd almost be willing to be that the tubes are smaller or thinner for the Mustang applications....
I'm all for having strong parts, and for the OP, he might be pushing the limits, we all know the weak link to the factory 1031s or whatever are the center diff and axles, if we replace the center diff with an alloy steel spool and replace the axles with new alloy axles, then possibly the next weak link "might" be the housing..then again, it might not for most all applications
Old 11-14-2008, 02:47 PM   #34
BB-Q
BB-Q's Avatar
Ken,
The is a metal tag on the rear ends attached to the diff cover, there is a number that gives the ratio with a letter in the middle, like a 3.73 is a 3x73 If there is and "L" there is is a limited slip. Like an 3L73 is a 3.73 with a posi. Something like that. Look for an "L" anyways.
Keep in mind most c-clip eliminator kits are OUTLAWED for roadracing- they don't like side loads and tend to want to leka diff oil onto your brakes., I would avoid them at all costs.
Tag image for you. See where it says 3L73? that'll be a 3.73 diff ratio with an LSD. Just to clarify for the hard of understanding, the important part is the "L"
Thanks- I didn't know that.
Originally Posted by foggyjames View Post
The man is a pimp, and a fast one at that...
Originally Posted by frpe82 View Post
He's got that "crazy Mark" look in his eyes...........
1992 245 SE B200F, M47, Low and painfully slow.......
v8volvo240.com
BB-Q is offline   Reply With Quote
Old 11-14-2008, 02:50 PM   #35
Captain Bondo
Care to share what calculations you used to determine that the material cross section in question is overkill? Or are you saying it is overkill arbitrarily?
Axle tubes for "real" axles come in 2 sizes- 3" and 3.25". This is a very standard tube size - and not typically called "overkill" by anyone. 3.25" is the "9 inch style" axle tube and most everything else built to hold power is 3".
The more desireable GM housings have axle tubes this size as well.
So we have a whole raft of proven, solid axle configurations that use 3" or 3.25" axle tubes. And a dana 30 that is just a carry over of the dana 27 as used in 80hp, 2300lb PV544's. And you're saying the Dana is the "right" size and all of the proven durable axles are overkill? Good luck with that.
The axle tubes "see" all of the engine torque as transmitted via the suspension links.
One of the weak links of the 8.8 is actually that the axle tubes are held in the housing via welded plugs and the tubes actually turn inside the diff (easily fixed by welding the tubes to the housing).
Part of what is hard on axle splines is that when you torque on the pinion the whole housing and axle tube assembly tends to flex and misalign the axles relative to the carrier.
Increasing diameter improves torsional stength exponentially.
Ken, Don't know much about the 9" bearing retainers, but I like your reasoning in modifying the length and then welding on whatever bearing housings are appropriate- I am guessing what you're talking about is more like converting to a semi floater with a tapered roller bearing as opposed to just a press-on ballbearing with a seal in the housing. That would be the best way to go.
Old 11-14-2008, 02:54 PM   #36
ElPiloto
I would go with a 9" Ford. It would probably cost less than a 8.8", but if you can get a good deal on a 8.8", go for it. These are both very easy to work on and set up correctly. So get the rear axle and customize it for your needs, limited slip or locker, stronger axle if you are going to be using big slicks, ring and pinion ratio. One thing nice about the Ford axle is that you can take several pumkins already setup with different ratios. A change takes about 15 minutes.
If you are shopping the junkyards, look at the axles in station wagons and pickups and find a pumkin with a "N" cast on it. The N stands for nodular and is a stronger housing.
"Four in a row makes it go"
ElPiloto is offline   Reply With Quote
Old 11-14-2008, 03:01 PM   #37
Forg
Forg's Avatar
The one thing that gets me, with all this talk of 8.8" and 9", is the target 1/4 mile time of sub 11 seconds.
That's quite a lot of torque to be pushing through a diff, considering the car's going to be 1300kg+ ... I just have a suspicion that the 9" from the get-go would save on wasting an 8.8" first.
And as far as the weight difference; if we're talking about the sort of power that pushes a 1300kg+ car to a sub-11s quarter, I don't think it's all that relevant.
Officially more homely than Paul Buck.
When I'm cruisin' in overdrive ...
Don't have to listen to no run-of-the-mill talk jive.
Shatner: The Colonel is breakdancing ... gimme a break!!
Rollins: Credit terms raised!
Shatner: I can't get behind any of that!
Shatner: I can't get behind so-called singers that can't carry a tune, get paid for talking, how easy is that? Well, maybe I could get behind that ...
Rollins: Well, I can't!!
Forg is offline   Reply With Quote
Old 11-14-2008, 03:13 PM   #38
Mueller
Mueller's Avatar
I guess I was looking at this from my 242's needs as well as those that don't plan on putting down 400hp to the rear wheels with slicks
I'm all for having parts that won't break and I've had my fair share of Ford 9" rear ends on my Mach I's in the past (i've also had the "pleasure" of having a few drum braked axles decide to part ways with the rear end assembly, luckly I was able to jack the car up, kick the axle back in and make it home to repair with a new bearing )
Old 11-14-2008, 03:24 PM   #39
BB-Q
BB-Q's Avatar
There's plenty of nine second cars on 8.8" rears. There's none of us here that'll break one. I think you'll see the 8.8" becoming more popular over the years as the 9" is getting older and rarer (unless you have the funds to buy a brand new axle, of course) in the junkyards.
Old 11-14-2008, 03:25 PM   #40
Captain Bondo
Forg, What are you referencing that suggests a 31 spline 8.8 is no good for 11's in a 3200lb car? You think he will "waste" and 8.8? How come?
Go to a mustang forum and tell them you plan on upgrading your 8.8" to a 9".
They will tell you to convert to 31 spline and leave it unless you plan to exceed 600hp.
600hp in a 3200lb car should be good for high 9's.
edit: BBQ beat me...
Old 11-14-2008, 03:42 PM   #41
Poik
Backwards Turbo
Poik's Avatar
600hp in a 3200lb car should be good for high 10's..
Fixed
Eric Olsson's 242 Turbo | 245 DL | 744 Turbo
Poik is offline   Reply With Quote
Old 11-14-2008, 04:27 PM   #42
thelostartof
unbalanced chemical
thelostartof's Avatar
Originally Posted by qwkswede View Post
I don't know where you guys have been. But here is the rule straight from the nhra rulebook.
http://www.geocities.com/boosted_eine/nhrarulebook.html
2.3 REAREND
After market axles and axle-retention device mandatory on any car running 10.99 (*6.99) or quicker and any car with locked differential. Cars running 10.99 (*6.99) or quicker that weigh more than 2,000 pounds (907 kg) with independent rear suspension must have swing axle differential replaced with conventional differential housing assembly.
Odd, I do know of more than a few sub 11 sec cars on factory IRS
Old 11-14-2008, 04:28 PM   #43
BB-Q
BB-Q's Avatar
Is that a request? I don't normally do kinky stuff, but as you're a mate...............
Old 11-14-2008, 04:39 PM   #44
Poik
Backwards Turbo
Poik's Avatar
I know of a couple sub 11 second factory cars on factory IRS
Old 11-14-2008, 04:40 PM   #45
D123GT
i would go with the 9 in just because you can get parts for them anywere and if you ever plan on going faster you wont have to worry about replacing the axle.
1987 760 turbo sold
R.I.P 1996 960 saved three lives
sold 1967 123 GT sold
sold 1998 C1500 sold
sold 1998 S70 sold
sold 1991 740 SE Project car
1978 Trans Am Project
1997 960 sold
2002 s80
D123GT is offline   Reply With Quote
Old 11-14-2008, 05:13 PM   #46
Alex Buchka
8 cylinders
Alex Buchka's Avatar
The IRS rule was meant for Jaguar type IRS's that used the axle shaft as a means of holding the wheels attached to the car. If an axle snapped the wheel could go flying. The rule does NOT apply to an irs where the axle shaft is only used to transfer torque to the wheels.
Old 11-14-2008, 05:22 PM   #47
impulse922
even guys with 03 cobras that have the stock 8.8" IRS setup tend to swap out for the solid rears if they are big on drag racing because the IRS loves to wheel hop.
buddy had his 11.8 sec cobra break a half axle at the track the last time he went..
-Matt
'03 s60 T5M
impulse922 is offline   Reply With Quote
Old 11-14-2008, 05:39 PM   #48
narancs
narancs's Avatar
noob Q:
whats wrong with the IRS? Why it isn't good for dragging?
'97 945 T5, mk1 IRS, NA cams, m90, 18T. COP converted Motronic 4.4 + Ostrich not gone.... but "changing"
'95 960 m90, 2.3 T5, VEMS, custom intake manifold... GONE
'97 850 T5m gone :(
narancs is offline   Reply With Quote
Old 11-14-2008, 06:13 PM   #49
Forg
Forg's Avatar
Because I don't really know what I'm talking about, Ford fitted 9" diffs to cars that had 260hp from the factory (when the 200hp versions had 8.8" ones) ... and fitting the 8.8" smells a bit like a shortcut & every shortcut I've taken in Big Red Car has cost me 2x as much as just doing it properly in the first place.
Originally Posted by narancs
noob Q:
Because the over-shoulder straps get all tangled-up in the extra links.
Well actually, it's because there's more room for movement & angles that can allow things to bend & break. You could definitely set something up to work, but the regulations are to stop the cheapskates from killing themselves.
Old 11-14-2008, 06:32 PM   #50
qwkswede
Old and Slow
Which also includes Corvettes, and some of the other designs as well. Many use the halfshaft as a suspension member.
