Old 12-08-2008, 04:01 PM   #126
mAydAy
Fabricatin'
mAydAy's Avatar
I took all of the measurements at least a year ago and posted most of 'em.
What are we actually debating that calls for measurements? Maybe it's me that's missing the point?
If we're trying to get a feel for axle strength, the off-road guys have actually tested most of the major axle sizes to failure, so there is even better info than just dimensions out there, there are actual torque-to-fail test results floating around.
I was merely trying to dissuade the average member from attempting to shorten a rear on their own due to the possibly expensive repercussions.
Definitely look up at the offroad guys for axles, they are probably the toughest on them and put the most time into researching them. There are some offroad axles sold that are guaranteed bulletproof and they will replace them for free if you can break them, not sure how they would take to putting them in street cars but I bet they'd be pretty confident in them.
There should be semi-floaters out there available for drag cars, and most roundy-round and road course cars will have full floaters in them, so there's plenty of strong full floater axle assemblies around too.
Originally Posted by KLowD9x View Post
As long as I can sit in the corner and watch you get it on with an admin while I masturbate with nothing but tears in my hand, I will be happy.
mAydAy is offline   Reply With Quote
Old 12-08-2008, 04:02 PM   #127
John V, outside agitator
Originally Posted by Mueller View Post
standards.....
as the spline count goes up, the diameter HAS to go up due to the diametrical pitch being used as a standard to ensure everyone is on the same page and parts interchange
that being said, someone "could" taper the axle down in diameter too much, but I don't think that is common practice...
I hain't assumin' nuthin.
the ultimate question really is the spline Minor diameter but since there is no one set spline in the world the simplest thing seems to me to measure the OD, and say what the PA is.
Now mark being a real troublemaker did just that.
And he did it in the system invented by those Gallic bastids and the one based on the thumb of a mythological King somewhere..
Now I like the 'Systeme Metrique' so I just measured the Toyota thing and it is
32.65mm.
Now I don't have a Volvo axle laying by the desk here but my memory says it is the same as 99-900 Saabs or about 29mm
So clearly MarkieBBQ is the man, his axles are a massive 1,2mm bigger.
Those Toyota guys are all limpwristed poofs anyway!!!
Once again, regardless of all else BIGGER is STILL BETTER!
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 12-08-2008, 04:07 PM   #128
Mueller
Mueller's Avatar
32.65mm.
again, standards, with the standard 24 pitch used, the minor diameter will be a percentage of the major diamter, just like your nuts and bolts....if a manfucture made a 31 spline count axle have a smaller minor diameter than another manufactures 30 spline count axle, they did not follow the standards and yes is would/could be weaker
Old 12-08-2008, 04:21 PM   #129
Standards? StaaaaaaAAANDARDS????!!!!!
We dun got no standards.
We dun need no stinkin standards!!!
Well ya know since i dun't works on 'Merikanski stuff and i see 30 and 545 and square root standards and different spline counts for You're a peein' and Japonaise shafts and of course neither of those usually work in 'Merikanskij schtuff, I diodn't stink it was useful when talking about US, Swedish and Japanese axles to presume they all used putative US standards.
:n eener:
Old 12-08-2008, 04:29 PM   #130
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
That's my understanding as well. Couple this with the fact that we are talking about torsional strength, and a 1.2mm difference is more than it seems at a glance, like a 25mm swaybar vs a 23mm swaybar - as a percentage there's a much larger difference there than the diameter would suggest because it is not a linear relationship.
True enough that people shouldn't just pull out their harbor freight fluxcore welders and start building diffs- I really hope that's obvious but maybe not. But- the context of this thread (at least initially) is primarily geared towards cars in the 500+hp range, and IMO most folks building cars to that level, either know enough to do it right, or know enough to have someone else do it right. Hopefully none of them are dumb enough to think that welding and aligning suspension compnents correctly is unnecessary.
But maybe they do and if so thanks for the reminder. Hopefully I keep getting lucky when I build mine.
-Kenny
Old 12-08-2008, 04:31 PM   #131
Mueller
Mueller's Avatar
:n eener:
good chance the rear end stuff for Toyotas is "based" on common US stuff so as to not deviate too far away....as for Swedish standards, same as US standard for this stuff
Old 12-08-2008, 04:35 PM   #132
Mueller
Mueller's Avatar
i'm still trying to figure out why if you work at such a place you have not made ready to bolt-in rear end assemblies for us !!!
Old 12-08-2008, 05:11 PM   #133
pwschuh
Rolling...
I suspect he's just waiting for someone to put together the Group Buy...
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe
Old 12-09-2008, 02:20 AM   #134
mAydAy
Fabricatin'
mAydAy's Avatar
Haha I thought about it when I worked there (just returned back to school after 1.5 years of building chassis for them), there was a few problems, namely the biggest one $$ wise I saw was getting hubs made. We stocked them in 5x5 and 5x4.5, but it'd be such a limited run for 5x108 that it wouldn't be cost effective, and a lot of people wouldn't like having mismatched bolt patterns, and making front 5x4.5 hubs would then bump costs up even higher. Its hard to market something thats very all or nothing -- as in you buy this rear and these front suspension parts, or you get all sortsa mismatched parts or nothing. Scalability, if you will, is pretty important in suspension systems, since only a small portion of your customer base will be looking to buy "Everything at once".
If I was to do an extreme 240 (or 740 for that matter) I'd do like Bondo talked about converting the rear to a 4 link (Would be pretty easy really) and throw in a 9", and convert all the running gear to standard roundy-round late model parts because of how cheap and available they are. The standard for brakes are 1.25"x11.75" (there are larger options) which are cheap and fit under 15" wheels (since they all run 15" steel wheels, there has been tons of developments in these systems, most notably are the pad compounds they have for track use. Pad choices are endless and not too pricey, and rotors, hell, you can find them for under $40 per (and they're the two piece style). The hardest part would be likely having to develop some sort of front hubs or somehow adapt some sort of hubs to the front that will work, but I have a few ideas on that too.
If there's enough interest in the future, some more development is a possibility if there's someone who wanted to blaze down that path I'd be more than willing to work on some stuff, it'd be a lot easier than people think to do it all and do it right. The problem is that this is a hard market to enter, and it certainly wouldn't be worth it for me to attempt to compete with Lawrence or Bne, when they barely have any demand for their parts. It'd be worthwhile for a few people wanting something one off thats top notch, reliable and cheap to maintain, but I don't think I'd ever try to market it in any numbers because of the demand in this market for anything over $20.
Old 12-13-2008, 03:49 PM   #135
smokeyfan1000
Guest
C- clip eliminators are required for drag racing after certain ET's are obtained too,besides any mods worth doing are worth doing right,RIGHT? Do you really want to depend on your brake rotor/calipers when the axle breaks, What if it cuts a brake line, and now you have broke axle and dying brakes? Could get HAIRY! Always remember, In Racing, whatever can go wrong, probably will,sooner or later. Also , RACING!! because basketball,golf,football and bowling,only take one ball!! I would definately use the C-clip eliminatators for ANY type of racing!!
Old 12-13-2008, 05:35 PM   #136
BB-Q
BB-Q's Avatar
C clip eliminators are not required at any ET that many on here are going to achieve. Besides, if you have a C clip failure (hardly an every day occurrance) then you'll be relying on a 1/2 inch thick bit of steel to stop the axle falling out whilst being clamped by the now pressurised caliper to keep everything in line.
I'm no expert but as I understand it that rule was brought in in the days of drum braked 8.8"'s, not disc braked. I've seen FWD cars suffer complete bearing collapse so that the disc and caliper are the only things holding that wheel station together. Yet despite having to suffer turning forces in addition to all those a rear axle would have to suffer, they stay in place.
Before you go spouting internet hearsay I suggest you mount up a caliper and disc on an 8.8" axle, then apply as much force as is needed to break the ears off the caliper using a bar that is attached to the centre of the axle and terminates no further than 15" from that centreline (because most people running slicks bigger than 30" will be on a 9"). On second thoughts, fill your boots- go do it with an 18" bar (36" slick).
Be sure to use some reliable equipment to see just how much force is required to break everything off so the axle can roam free, won't you?
I think you'll be surprised.
Originally Posted by foggyjames View Post
The man is a pimp, and a fast one at that...
Originally Posted by frpe82 View Post
He's got that "crazy Mark" look in his eyes...........
1992 245 SE B200F, M47, Low and painfully slow.......
v8volvo240.com
BB-Q is offline   Reply With Quote
Old 12-15-2008, 11:25 PM   #137
Kevin Hawkinson
Better Red than Dead
Kevin Hawkinson's Avatar
Regarding strength increase vs diameter:
tau = 2T/pi*r^3
tau is shear stress, T is torque, r is radius
Assume that tau_max is constant. Allowable tau_max actually depends on materials, so in this case, it's not actually correct, but lacking real data on the materials used in each of these shafts, we'll assume that it is constant.
Solve for T/tau.
T/tau = pi*r^3/2
This gives us a ratio of torque to shear stress.
d...........r............T/tau......factor
29.........14.5........4788.77..1
32.65.....16.33......6834.07..1.43
33.8.......16.9.......7581.93..1.58
So an increase from 29mm to 32.65mm gives a 43% increase is torsional strength, and going from 29mm to 33.8mm give a 58% increase in strength.
Not shown, but going from 32.65 mm to 33.8mm gives an 11% increase in torsional strength.
Again, this is based on identical materials, which is not actually correct.
-Kevvie Hoikansanalainenen
Kevin Hawkinson is offline   Reply With Quote
Old 11-02-2022, 09:44 AM   #138
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Thread resurrection.
Given this thread is 14 years old -
EDIT -for my 740 pickup V8 conversion
I'm trying to figure out what model/year range I would be researching when looking for either a Ford Explorer rear axle , or the Toyota option mentioned by John V.
I have zero access to pick n pulls in my area, so anything I get is coming from online.
Edit- install detail from Nathan
http://www.turbobricks.org/forums/sh...77&postcount=5
Another 8.8 axle discussion thread
My XR July2013 - 446AWHP @ 8K rpm C30 AWD conversion 740 pickup thread Feedback Thread
Old 11-02-2022, 09:54 AM   #139
I.M. Weasel
I like the 8.8 because I already had Mustang wheels. The cobra clutch pack I put in the Ford Traction Lok works great and leaves 2 black stripes, it almost feels like a weldy but it goes around corners.
Living life one day at a time. Stopping to smell the oil slick beneath my Volvos.
Old 11-02-2022, 10:13 AM   #140
lookforjoe
lookforjoe's Avatar
So.... What year Explorer did you get your rear from?
Old 11-02-2022, 11:27 AM   #141
AndrewNance
Amateur hour!
AndrewNance's Avatar
I think 96-01 is what you’d want to find. Prior to that they had drum brakes and after 2001 they went to IRS in the Explorers. I’m pretty sure the one MikeJr did for my car is out of a 2000. Shouldn’t matter if it’s v6 or v8 but there are 28-spline and 31-spline varieties. The ID tag should tell you the gear ratio if it’s still there.
'67 122 - b230, t5, 8.8
Feedback
Old 11-02-2022, 11:35 AM   #142
culberro
culberro's Avatar
Use this site for searching junkyards: https://www.car-part.com/cgi-bin/search.cgi
Plenty of exploder 8.8 in your area with 3.73 gears.
Make sure they come with brakes, those are really expensive to buy aftermarket. The brakes also fit ford 9in, and people use them as the “cheap” disc conversion.
Head work: https://forums.turbobricks.com/showthread.php?t=349975
Temp Sender Adapters: https://forums.turbobricks.com/showthread.php?t=348169
Old 11-02-2022, 11:59 AM   #143
lookforjoe
lookforjoe's Avatar
Thank you! I was searching through 2004/5, which would have been no good at all...
Thank you - yes, I'm using carpart.com - no pics of the ones in NY, so I'll need to email for more info - I did come up with one that say 3L73, so that would be my first choice, based on remarks earlier in this thread
EDIT -I see that the rears have 5x114 bolt pattern, so typically use spacers to convert to 5x108?
Old 11-02-2022, 12:15 PM   #144
culberro
culberro's Avatar
What's the application?
NA, turbo? Cruiser, DD, track car, race car, auto-x?
If you want a higher geared rear end (3.55-4.10), 8.8 makes the most sense. If you want lower gears (4.10-5.xx), Toyota 8in starts to make sense.
You can also do a Ford 9in kit with whatever center section you want for about $2k with all new components. It's very easy (I've seen what you're capable of) to make a fixture to transfer the mounts from a volvo axle over to the swap axle.
Old 11-02-2022, 01:48 PM   #145
lookforjoe
lookforjoe's Avatar
Sorry - this is for the 740 pickup to go with the 4.8L V8 conversion (street, towing)- I'm assuming the stock rear isn't going to like close to 300ft/lb if I push it...
Old 11-02-2022, 02:57 PM   #146
culberro
culberro's Avatar
Honestly it'll probably be fine unless you start doing one wheel burnouts or weld the diff and pretend it's an open diff. There are plenty of LS swapped 240s rolling around with a stock 3.31 geared 1031.
The welded 1031 in the v8 drift car has yet to break an axle, and it's a very healthy 302. It's all about how yo drive it
But if you are going to swap the axle in the 740 ute... I'd grab a 8.8 and whatever gearing works out the best for you. Probably the lowest available since the tires will end up being so small in diameter compared to an explorer.
The 3.73 gears in the drift car are stupid short with a T5, a 3.3 would be a better choice
Old 11-02-2022, 09:49 PM   #147
lookforjoe
lookforjoe's Avatar
Many thanks for the input. I'm not planning on beating the crap out of it. I'm keeping the 4L60E auto trans, if that makes a difference to gearing. Looking up 2001 Explorer, Sport Trac was only available with the 3.73 or 4.10
Old 11-02-2022, 11:34 PM   #148
culberro
culberro's Avatar
The v8 3.73 has a pretty big year range, the 3.55 and lower are harder to find.
The 3.73 will give a ~2k rpm cruising speed at 60mph:
https://apx6u.app.goo.gl/4Txk
Old 11-03-2022, 08:35 AM   #149
I.M. Weasel
My 4.10 came out of a 2 door sportrav, I just grabbed another short axle and shortened the left axle tube, I don't remember the width when done though, I think it was ~1.5" wider than a stock 240 axle. How much wider is the 740 axle than a 240?
Edit, I'm also using 26.5" diameter tires with a Tr-3650 transmission, first is a little short at 3.37 but fifth is 0.62 which is great for cruising 70-80mph tolerable in the coastal plain I live in at 60mph but really needs to be in 4th for 55mph though
Old 11-03-2022, 08:51 AM   #150
lookforjoe
lookforjoe's Avatar
Thanks for the graphic display!
I can live with that, still under 3K in the normal highway cruising speeds
looking through other TB threads - the 8.8 is 59.25" , the 240 rear is approx 54.25", I'm assuming the 740 rear is about 60-6.5", since cpt. Bondo said the 8.8 ends up being about .5" narrower
So, other questions would be what to do about the driveshaft, and bolt pattern.
