Old 11-10-2022, 11:15 PM   #76
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
Does the "extreme" flow better than the style I have?
Doesn't seem worth the struggle for the fitment issues if it doesn't
Deb the 944T Tina XC90 T5
Old 11-10-2022, 11:17 PM   #77
stev
stev's Avatar
Originally Posted by Dvroofer View Post
It might be just the way I have things. It may work with a alternator rather than the ps pump I have next to it. But I don’t want an alternator there due to not wanting any heat anywhere near it. I was hoping someone had pics of it actually mounted up to see what they are running for accessory configuration. Worst case I’m never going to have ac with it and put all accessories on the driverside. For me that not a big deal but it isn’t just plopping in as I thought it would definitely getting caught up on the power steering pump pulley and not allowing to seat. If it was too easy I’d probably be suspicious. I also tend to do things the hardest way possible
Yeah I can't run it then, the whole point of me putting my alternator on the driver side was to escape the heat.
stev is offline   Reply With Quote
Old 11-11-2022, 01:30 AM   #78
Dvroofer
Dvroofer's Avatar
I’m swapping it on in the morning. I’ll take measurements and pics so you can see exactly where it sits
Dvroofer is offline   Reply With Quote
Old 11-11-2022, 06:08 PM   #79
CAPT_BLOTTO
#Crush It
CAPT_BLOTTO's Avatar
Do you have the non extreme KL manifold? I think the differences are it can hold twice the weight and has an external wastegate.
Hello My Glorious!
Old 11-11-2022, 08:04 PM   #80
Wilford Brimley
I have an older obx mild steel one with a wg pipe added to it...guess I'm more curious if it changes spool up and if it's worth the hassle of relocating things vs the style i have
Old 11-19-2022, 01:18 PM   #81
Dvroofer
Dvroofer's Avatar
Well it’s hard to gauge since I changed to a totally different turbo setup. I’m happy with the performance so far, and slight change in tone a little more rumble. But install and switching everything around was a pain. But that’s on me for having to keep my alternator on driver side. I ended up without accessories on the passenger side totally.
Old 11-19-2022, 01:19 PM   #82
Dvroofer
Dvroofer's Avatar
I’ll post pics sometime this weekend for reference
