Old 01-29-2021, 04:53 AM   #1
SkeTchy-MechAniC
SkeTchy-MechAniC's Avatar
Default Solid shifter cage 240
The itb engine is running and we're now starting finishing things to get it tuned. The PO extended the stock shifter on the m47 for looks. Since the stock shifter isn't known for it's crisp shift this didn't improve anything other than giving the idea you're riding a dumptruck on itb's I've grabbed a spare shifter and lengthened it below the pivot bearing, That'll be installed any time soon. When shifting the current setup i noticed the huge amount of movement in the shifter cage itself. So i got thinking about making some solid bushings for it. Tried to find some info about this but couldn't find anything. Would there be any downsides ?
Never have i ever .... Seen a 242 with two motorcycles in the back
SkeTchy-MechAniC is offline   Reply With Quote
Old 01-29-2021, 05:11 AM   #2
Jack
junkman
Jack's Avatar
Vibration
I love you even more Jack.
Old 01-29-2021, 05:59 AM   #3
Swedbrick
Swedbrick's Avatar
Sts has them;)
https://www.stsmachininginc.com/coll...-240-740-volvo
Volvo 745 - Turbo, LH2.4, M90 swap, IPD springs, 25mm/19mm swaybars, 3.54 \w racingdiff lsd, track/daily
Volvo 363 - N/A, Speeduino, GSXR ITB's, half-cage, work in progress
Old 01-29-2021, 06:26 AM   #4
SkeTchy-MechAniC
Originally Posted by Swedbrick View Post
These would also be nice to have, I'll see if i can make some. The bushings i was talking about are the ones that connect the cage to to the transmission
I wonder if vibrations will really become an issue.. It isn't a daily and the 3rd engine mount should stiffen it up quite a bit
Old 01-29-2021, 09:10 AM   #5
Swedbrick
Swedbrick's Avatar
Aah that sloppy bit of rubber in between, I see. It shouldn't be too hard to get some pieces of delrin or nylon machined to replace those, your bones will shake though haha, volvo put it there for a reason, the engine will still move quite a bit.
Old 01-29-2021, 09:46 AM   #6
crogthomas
crogthomas's Avatar
As has already been said, vibration is the downside. Having said that, many RWD transmissions have a gearlever mounted directly IN the gearbox without any sort of isolation, so I wouldn't be too concerned. It sounds like a good idea. Let us know how well it works.
crogthomas is offline   Reply With Quote
Old 02-01-2021, 03:44 AM   #7
SkeTchy-MechAniC
Just finished up the install. Was able to make some bushings at work. If there is any interest i'll share the drawing. Placing them was quick and easy and did the modified shifter at the same time. It's incredible how much more stable the shifts feel, Could actually feel where the gears are. The teflon bushings in the shifter itself are still there but in good shape. Maybe i'll swap them for bronze ones to.
Old 02-01-2021, 10:57 AM   #8
crogthomas
crogthomas's Avatar
Not hard to make, but pictures or a drawing are always interesting.
Next time my car is apart I'll be making up some aluminium bobbins for the same reason.
Old 02-02-2021, 04:41 AM   #9
SkeTchy-MechAniC
Here you go.
Old 02-02-2021, 05:06 PM   #10
spock345
spock345's Avatar
You could probably just get them 3d printed out of ABS or nylon.
1998 S70, grandma-mobile
1980 245
1989 240 B230F, V15 cam, chipped EZK, M47 swap (Lost a fight with a Chevy express van), the millennial falcon
Old 02-03-2021, 04:25 AM   #11
SkeTchy-MechAniC
I don't think that's a good idea, They have to be strong since the bolts also keep the rear end of the transmission together.
Old 02-03-2021, 12:37 PM   #12
spock345
spock345's Avatar
Good point. A delrin bushing would probably be OK in that application. ABS wouldn't.
Old 10-29-2022, 11:59 PM   #13
GeneralBurrito
GeneralBurrito's Avatar
The rubber bushings are quite squishy and degrade pretty badly, yet the rear of the trans still holds together fine. How would 3d printing 100% solid bushings in temp and oil resistant materials like petg or abs be worse than rubber in holding together the rear of the trans as long as the metal sleeves and washers are still used. Plus, 3d prints are insanely strong in compression as you're just squeezing the layers onto each other. It's a different story with tensile forces causing layer separation, but I don't see an issue in using them in this situation where they're just being compressed into place.
GeneralBurrito is online now   Reply With Quote
Old 10-30-2022, 11:46 AM   #14
Radtap
Radtap's Avatar
That shifter is going to rattle loudly if you put in bronze bushings. I used a thin piece of metal between the snap ring and rubber bushing ring to try and get the bushings to fit tight around the ball
Feedback
Radtap is offline   Reply With Quote
Old 10-30-2022, 01:23 PM   #15
esmth
I had the same problem and did the same thing, lol. I used cut up pieces of a soda can to make the shims. It is nice and tight for now minus the internal slop
1991 244 LH3.1 M46 402k miles
esmth is online now   Reply With Quote
Old 10-30-2022, 08:12 PM   #16
Old and boxy but good.
Nice job on the bronze shifter cage bushings. I would use them if you made some. I only use bronze on the shifter clevis bushings. The ball socket bushings I put in new plastic ones. Makes for a nice shifter. The bronze ball socket bushings gave the shifter a clackity, clack feel which
I didn't like.
Old 10-30-2022, 08:27 PM   #17
Radtap
Radtap's Avatar
Sorry I worded it badly, I had new rubber bushings for the cage but new bronze bushings for the linkage ball, it rattled badly when first installed until I shimmed it. I could give bronze cage bushings a shot though, I've got a lathe taking up floor space and a CNC lathe so I could pump them out if there was an interest/improvement
