Old 10-17-2022, 12:44 PM   #51
redblockpowered
mails files to people
redblockpowered's Avatar
Compare the angle of the throat of the port relative to the mating flange to that of the runners on the manifold. My guess is that there is s sharp turn that does not exist in the other combination.
This is the prevailing theory for sure. We tested the B21F manifold on both heads and the results were much better for the 631. I think it'd work best with a more upswept manifold like on an M50/M52. I have the numbers but I can't find them at the moment. Looked like a pretty even trade off between the ported 530 with B21F intake and stock 631 with the same.
I think there's a decent amount of potential in this thing but it's too rare and strange to really be worth messing with.
I sell chips for LH 2.4!
If you live in the Northeast US, I'll drive to you and tune your LH 2.4 car!
Old 10-17-2022, 01:28 PM   #52
culberro
culberro's Avatar
The flow of a "heron" head is normally ok.... but it's usually a trade off for really heavy pistons and marginal high lift flow due to no diffuser angle in the valve job.
The intake port bias tho
http://www.italian.sakura.ne.jp/bad_...9bb0e91a_b.jpg
Head work: https://forums.turbobricks.com/showthread.php?t=349975
Temp Sender Adapters: https://forums.turbobricks.com/showthread.php?t=348169
Old 10-17-2022, 02:13 PM   #53
shoestring
shoestring's Avatar
I go away for a weekend and some weird stuff happens.
Old 10-17-2022, 02:30 PM   #54
culberro
culberro's Avatar
Are you guys calculating CFM now over a plate or with an electronic pitot/orifice setup yet?
Old 10-17-2022, 02:55 PM   #55
redblockpowered
Nope, still rocking the water column. Accurate but unpleasant.
Old 10-17-2022, 02:56 PM   #56
Smorgesborg
"Unpleasant" is certainly one way to put it, though I'd considered it an understatement.
Smorgesborg is offline   Reply With Quote
Old 10-17-2022, 03:34 PM   #57
redblockpowered
For the record it's Smorgesborg's 631.
Old 10-17-2022, 04:06 PM   #58
Smorgesborg
I'd also like to say, for the record, that it took about 90 minutes to get the water back in at the appropriate level. For anybody wanting to recreate this I recommend using a MAP sensor and an arduino with an LED screen instead to avoid water evaporation.
Edit; referring to flow bench.
Old 10-17-2022, 05:32 PM   #59
Quin
ಠ_ಠ
Originally Posted by Smorgesborg View Post
For anybody wanting to recreate this...
i don't think that will be a common issue.
Old 10-17-2022, 08:06 PM   #60
Smorgesborg
Probably not, but just a mild warning to those that see this thread in the future that want to frequently flow cylinder heads on the smallest of budgets.
Old 10-18-2022, 11:40 AM   #61
culberro
culberro's Avatar
If only there were cheap differential pressure sensors that could read in-h2o....
https://www.amazon.com/Professional-...45&sr=8-4&th=1
https://www.amazon.com/Handheld-Mano...%2C145&sr=8-20
Old 10-18-2022, 12:24 PM   #62
redblockpowered
Really this would be nice for accuracy alone. Dealing with ruler parallax will only work for so long.
Old 10-18-2022, 06:43 PM   #63
shoestring
shoestring's Avatar
https://www.kleintools.com/catalog/e...tial-manometer
Modern-era measurement entered.
Old 10-18-2022, 06:47 PM   #64
threewagons
i am the liquor
threewagons's Avatar
or don't use water
the 945
threewagons is offline   Reply With Quote
Old 10-18-2022, 07:18 PM   #65
joel142
I've actually used this one - works really well.
'71 142E, B230FT, M41, Corbeau GT seats, iPd bars and springs, Nardi wheel, GT gauges, Bilsteins, Canisto wheels, 7" Cibies
'95 T5-R, yellow, M56H swap
'06 R500, Built like a steak house; handles like bistro
joel142 is offline   Reply With Quote
Old 11-22-2022, 08:08 PM   #66
redblockpowered
We've digitized it:
Just a baseline has been done so far. It needs a little orifice to slow down the changes in reading but other than that works pretty well.
Old 11-22-2022, 10:01 PM   #67
oooooooo!
I hate the car and also cannot be free of it. I dream of having a different project but cannot separate myself emotionally from this one and so remain bonded to it like Sisyphus to his great stone.
Old 11-22-2022, 11:29 PM   #68
redblockpowered
I'd love to try and test exhaust manifolds and turbine housings on this thing. Unfortunately my only 90+ is installed and I need it to get to work.
Old 11-23-2022, 09:45 AM   #69
widewagon92
now with more caffeine!
widewagon92's Avatar
I've got a 90+ and one of the old garrett manifolds sitting on a shelf that I'd donate to the cause, but I'm down in Maryland. I'm game to meet somewhere along the way for a baton pass if you're making a trip south anytime soon. I imagine shipping would be pricey.
widewagon92 is offline   Reply With Quote
