Old 07-20-2022, 06:51 PM   #1
Broke4speed
Broke4speed's Avatar
Default Cheapskate LS manifold options
I'm getting closer to having all the parts I need for a 'one-day' install and I've begun to think about manifolds. Given that I'm using a 4.8 and a T5, I don't particularly expect to have more than 250whp/260tq, would I run into any issues with doing a crossover pipe for the driver's side and blending that into the piping on the passenger side? I can't really find much info on using an unequal length pipe setup on a V8. I know some old Fords from the 60s did it, but would I be leaving much on the table, power-wise?
Could I even use the factory exhaust manifold on the pass side? I'd really like to not have to purchase something if there's a way around needing it...even if it's not a great solution.
1984 244/ LR4 4.8 / T5
Old 07-20-2022, 09:37 PM   #2
oldschoolvolvo
oldschoolvolvo's Avatar
I haven't researched it at all, but this for sale ad lists using one Camaro manifold and one CTS-V manifold. Might be a lower cost option for you.
Also, the STS guys did an exhaust setup similar to what you are describing:
Build thread: https://forums.turbobricks.com/showthread.php?t=354287
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 07-20-2022, 10:22 PM   #3
Broke4speed
The camaro ss manifold is something I'm definitely going to look into now .
I mean...I COULD pay for stuff, I just don't want to, lol.
Thanks for the info and pic! It's good to know the unequal length idea isn't uncommon. Mine would just be in front of the engine, like a single-turbo setup.
Old 07-21-2022, 01:16 PM   #4
patrickstar
patrickstar's Avatar
I believe these are unbranded versions of the Hooker 8501 which is the usual suggested exhaust manifolds for 240 LS swaps (I'm running them and have plenty of clearance)
1983 242 - 4.8/AR5
1980 242 - Shell
@beige242 on instagram
patrickstar is offline   Reply With Quote
Old 07-21-2022, 01:41 PM   #5
Broke4speed
Dangit! The seller may not ship to Canada (ebay.com) and any of the clone manifolds I can find on ebay.ca are $300+ CAD plus $50-150 shipping from the USA :(.
I know Summit sells a version of those too, maybe I'll look into that too.
Being in Canada really bites for options. Even the F-body manifolds on ebay are expensive, ugh.
Old 07-21-2022, 02:02 PM   #6
J_pelchy
Turd Blow Bricks
J_pelchy's Avatar
Idk how budget friendly you're looking for, but Scott does offer the Hooker reps on his site
https://www.stsmachininginc.com/coll...aust-manifolds
Flint, Mi
*Volvo Enthusiasts of Michigan*
Instagram // 810_volvos
Feedback
J_pelchy is offline   Reply With Quote
Old 08-04-2022, 08:36 AM   #7
Broke4speed
I ended up going with the usual clone cast manifolds, purchased from Summit Racing for under $200 USD. They arrived yesterday and come complete with flanges for downpipes and all the hardware .
Old 08-04-2022, 06:57 PM   #8
GTJordan
Been here for too long
GTJordan's Avatar
Thanks for doing this cheap LS swap. I'm probably going to swap this clean 242 shell I've got with an LS to re sell. So I'm following along!
80 242- 2.5L 16V, NIW intake/exhaust, GT3076, MAxxECU Race, KL Stg 2 cams. T5 w/ 2.95 gearset. Porsche brakes, Gaz short coilovers/shocks and Kaplenkhe suspension, Trutrack.
Old 08-05-2022, 08:54 AM   #9
Broke4speed
Glad to help, lol.
I'm gonna say though...the sheer amount of nickel and dime parts is killing my budget, ugh. If I was going automatic, it would be a LOT cheaper.
Old 08-05-2022, 05:49 PM   #10
GTJordan
GTJordan's Avatar
Originally Posted by Broke4speed View Post
Glad to help, lol.
Noted. Going auto. Lol. This will be a purely build to sell to a farmer type of project.
Jordan
Old 11-02-2022, 07:58 PM   #11
Broke4speed
UPDATE:
The Summit clone manifolds fit great, but for those of us with a ZF rack...that steering shaft is going to be reaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaally close. I flap-wheeled a bit of clearance, but I may have some of the flange milled down to increase space. I'll wait to see if it hits while moving.
Old 11-02-2022, 08:02 PM   #12
JohnMc
JohnMc's Avatar
Are you using a solid steering shaft, or still the rubber-isolated stock shaft?
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 11-02-2022, 08:13 PM   #13
Broke4speed
I've got the STS solid shaft. I'm currently not using the spacers in the crossmember, so it might get a wee bit closer if I have to put them in. I think I could tweak the engine position a bit more if I have to, but I'm not up to 100% snuff yet, so I left it at 'close, but not touching'.
Old 11-02-2022, 09:30 PM   #14
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Any pics of your build? I'm planning on putting a 4.8l LR4 into my 740. One of the things I'm pondering are ancillary layouts - curious to see what others have done in this regard.
My XR July2013 - 446AWHP @ 8K rpm C30 AWD conversion 740 pickup thread Feedback Thread
Old 11-02-2022, 09:41 PM   #15
Broke4speed
This is the best I can do for now: http://forums.turbobricks.com/showth...323599&page=34
I have been pretty sick since Aug 30, so I've only recently started working on it again. Any pics will be from page 34 and onward.
Old 11-02-2022, 09:43 PM   #16
JohnMc
JohnMc's Avatar
Yeah, you'd probably want to avoid having it hit the shaft.
My manifolds go forward for turbo purposes, so I never had to try to fit an exhaust in on the steering side.
Old 11-03-2022, 09:39 AM   #17
Broke4speed
If it hits, I'm definitely getting a bit shaved off the flange and flap-wheeling a bit more clearance. If i have at least 1/8 of an inch I should be good. The STS mounts are a soft poly, so there's not much deflection.
Old 11-03-2022, 10:14 AM   #18
JohnMc
JohnMc's Avatar
Jared was having the engine/manifold lean over in corners and sort of mildly bind up the steering shaft. Which is not a good sensation, I'd imagine.
I did have fun fitting a decently sized downpipe on the passenger side, where it's right next to the starter. I ended up using 3.5" oval pipe and bends, transitioning back to 3" by the trans. After the first decent length drive the starter wouldn't work until it cooled down, I had to make a metal heat shield for it (the DP was heat wrapped, FWIW).
Old 11-03-2022, 02:16 PM   #19
Broke4speed
Dangit, I was using his swap as a reference! Guess I'll get that manifold off and shaved sooner before later. Maybe I'll even cut a small channel in it.
