Old 09-13-2022, 02:00 PM   #1
jbirdyurd
Question Converting 1984 240 to Carb
This is my first post so I don't know if I will get shunned for asking about n/a cars but ya'll know the motor harnesses and ignition systems on these cars pretty well. I have two 1984 Volvo 242 DLs both n/a lh 2.1/2.0 cars. I do not want to boost one of them because the B23F in it is quite healthy and I want to do something a little less common. I want to get two Weber DCOE 45 carbs and run it like that. My current plan is to get a new motor harness for the EFI motor and close the circuits to the EFI stuff. Firstly, I do not know if I could just get a motor harness for a carved B23A car, or just close the circuitry on the EFI harness. If I was to do the carb harness, how would I control the fuel pump relay since, I do not want to do switches and what not. The ignition system I plan on just getting a MSD box and doing it that way. But I am really stumped on what to do with the motor harness.
jbirdyurd is offline   Reply With Quote
Old 09-13-2022, 02:52 PM   #2
JohnMc
JohnMc's Avatar
I'd just unloom the harness and take out all the fuel injections stuff. It will be a large percentage of it.
You'll need a different fuel pump, the fuel injection pump puts out way too much pressure, you wouldn't want a pressure regulator to try to knock that ~50 psi down to 2 or 3 psi (DCOE's like very low pressures).
The current relay is triggered by the ECU, so you'd need something else. Could just hook it (the relay) trigger up to switched 12V+. Since the carbs have fuel bowls, doesn't even matter if the pump shuts off while cranking (many switched 12V+ circuits do that).
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 09-13-2022, 03:07 PM   #3
Old and boxy but good.
I would suggest some reading up on how to tune and adjust carbs. They require some understanding of balancing the airflow and adjusting the idle and overall mixture. The Haynes manual for Webers is a good start. A wideband O2 sensor can help with this. Air flow synchro tool from Germany is the one to use.
Another suggestion I have is to use a kjet fuel pump relay. That way you can have the safety of the engine shutting off the fuel flow if the engine isn't running. An electric fuel pump rated for carbs would work well with that relay.
Lastly going carbs is way more expensive than it seems. You'll have to have a decent budget for this as you'll need most of a thousand just for the carb setup. Good luck with the project.
Old 11-21-2022, 11:40 PM   #4
CarlosGato
I would like to do this too, my mechanic says the jetronik-k is impossible to fix when it breaks and he cant get parts anymore. In our state we dont have to keep the car the factory same onec it gets old like mine a 978 242 but she runs good.
Do we have some insruction for guys like me who are learning but want to put carb on? Why do you choose Weber, isnt that from Italy and expensive? Why not Holly carb like on V8 motors?
You say up there it costs $1000 for Weber?
CarlosGato is offline   Reply With Quote
Old 11-21-2022, 11:58 PM   #5
fatcatbestcat
Professional Hack
fatcatbestcat's Avatar
I can't think of any way to use a 4-barrel carburetor (like on a V8) with a redblock without a custom manifold or a lot of really sketchy adapters - they just aren't available, and I'm not sure why you'd want one. It's a lot of carb for a relatively small displacement motor.
Webers are usually the carb of choice because they're available (and widely supported) and dependable. There's a lot of cheap Asian-made carbs out there on eBay or AliExpress, but they're almost always junk. Usually good to stick with name brands.
2-barrel DGV and DGEV (and DGS and DGES) carbs are a pretty common swap or upgrade for a lot of European cars - you can get kits for Volvo engines fairly easily as well. They're more of a budget/economy-minded carb versus the more performance-oriented (and pricy) DCOEs.
Doing the wrong thing the right way.
Get f*cked and please have a nice day.
Originally Posted by IansPlatinum View Post
please no more prying things with screwdrivers and bashing things with hammers!
Originally Posted by Cwazywazy View Post
my balls have more wrinkles than my brain
Originally Posted by leecatd8209 View Post
Against all odds I have overcome the 4
-1967 144S
-1983 245 Diesel (Current Project) - passively for sale (interested in trades!)
fatcatbestcat is offline   Reply With Quote
Old 11-22-2022, 12:18 AM   #6
James M
Bored member
James M's Avatar
You're mechanic is a boomer, Kjet isn't hard to fix if you know how to read a few manuals and have the right pressure gauge
Old 11-22-2022, 10:00 AM   #7
CarlosGato
Is that bad to be a boomer, I dont know what it means. He said its a parts problem mostly, I think he is a good guy but he is still young and his shop is at homer.
Old 11-22-2022, 10:23 AM   #8
OVERDRIVE
OVERDRIVE's Avatar
Boomer = Baby Boomer. I don't think NA K-jet parts are hard to find. Everything that can't easily be rebuilt is available, at least when I had my '80 242 a few years ago. When things start acting weird you just need to smoke the system to check for any vaccum leaks, and then start checking and adjusting fuel pressure down the line. The mechanic just doesn't know K-jet and sounds unwilling to rebuild warm up regulators and fuel distributors. You'll spend thousands to get a car that runs worse.
1990 244 DL AW70 189 white.
OVERDRIVE is offline   Reply With Quote
Old 11-22-2022, 10:34 AM   #9
CarlosGato
Ok well he it too young for that. But yes may be you are right he desnt want to learn about it now. He keeps talking about micro spurt too but all that custom electronic stuff scares me, I am old and dont even have a loptop computer he says you need to ajust it.
I saw a guy on youtube who said the Jetronik parts are not there any more but another guy who is scotish and he has lots of videos about fixing the injectionK system, his works great is seems. Iwill try to find his channel for you guys, maybe it can help, he seems to know alot.
Old 11-22-2022, 10:36 AM   #10
CarlosGato
Here is hihs channel https://www.youtube.com/@GreyGooseRestorations
Old 11-22-2022, 10:38 AM   #11
white855T
If someone doesnt rebuild the kjet parts, they'll have to pay a lot of money. 300-400 for rebuilt wur, $700 for fuel distributor, add engine harness/ignition harness, and fuel injectors. Not including fuel pumps which he'll more than likely need. You're getting close to 2k. Not everyone is interested learning to rebuild/repair parts.
Old 11-22-2022, 10:57 AM   #12
CarlosGato
No yes you are right, $2k is more than the 242 cost and its for my sister not me but I did buy a 1980 GL too for parts but now maybe Iwill keep both and fix up the 1980 after yiou guys told me the wiring advice that after 1980 the wires all go bad by themself!
So what you say is may be double costs to fix the Jectronik or get a Weber carb for less than $1k well that choice is easy, I know carbs from when I was a kid, they are not hard to work on if your ears still work to here it running and tune it. I dont need a meter if there are adjustment screws on there. Speaking of Holly carbs they come in 2 barrel 500 cfm too, I had one on a Ford 351 and got a rebuilt kit from Summit before the virus stuff hit. My mechanic was scared to do it, he is too young
Old 11-22-2022, 11:07 AM   #13
OVERDRIVE
OVERDRIVE's Avatar
The poster said his car runs good. It's very unlikely he will have to do any of that. When I revived my '80 242, I just needed a new main fuel pump, filters, and to clean and adjust the WUR. K-jet doesn't like sitting, if the poster's car runs currently and only needs occasional fiddling then going carbs is going to net him the exact place he is now but with a lighter wallet and a car that runs worse.
Old 11-22-2022, 11:08 AM   #14
spock345
spock345's Avatar
K-jet is only a big problem if it has sat and won't fire up. Setting it right is a big effort. But so can carburetors.
I know you can get carburetor manifolds for the B21/23/230 family of motors, both for the two barrel downdraft and the DCOE sidedraft carbs. The tricky part will be jetting them so that they run nicely. You'll want a book to help you through that process.
You can also source parts for an OEM volvo carburetor, which I think is a zenith stromberg. Those operate differently than the standard holly that all the American mechanics love. I think that constant velocity carbs like the ZS or SU are simpler to understand.
1998 S70, grandma-mobile
1980 245
1989 240 B230F, V15 cam, chipped EZK, M47 swap (Lost a fight with a Chevy express van), the millennial falcon
Old 11-22-2022, 11:40 AM   #15
Broke4speed
Broke4speed's Avatar
It's unfair to give a young mechanic a hard time about not wanting learn outdated technologies for the one car he'll work on in a couple years that uses them. Unless he plans to lose money as a specialist mechanic, it's far easier to work on more modern cars that are in line with his training. Makes more money that way too, because the hours spent rebuilding Kjet stuff are hours he can't charge for.
Like it or not, K-jet is the area of an old-school mechanic, a specialist volvo shop (provided they still know how), or self maintained.
1984 244/ LR4 4.8 / T5
Old 11-22-2022, 11:43 AM   #16
Broke4speed
Truth. The OE B21A single zenith stromberg setup would be the way to go for anyone new to them. They just run. No fuss, no muss. I've done most carb setups on a redblock that someone can think of, and the best one was the dual ZS one I made.
Old 11-22-2022, 11:44 AM   #17
James M
Bored member
James M's Avatar
Learning isn't age dependent
If the car runs well the Kjet system may never need touched.
A penta Webber downdraft kit might be the cheapest and simplest solution if you are set on running a carb.
Old 11-22-2022, 11:49 AM   #18
white855T
I don't see where he said the car is running good. It seems he won't be doing the work on car. If you leave this to a mechanic, all he's going to want to do is swap parts(more billable hours). I don't recommend a carbed setup unless you're willing to spend the money and learn how to do it. He's looking for an instructional which you won't find here. At best, we can recommend parts vendors. Either way, if he's not doing the work, it won't be cheap. If you like kjet, great. But it's not for most. There's a reason Volvo went to efi.
Old 11-22-2022, 11:49 AM   #19
Broke4speed
Can't charge the customer for time spent learning. Being a mechanic is a business, unfortunately
Old 11-22-2022, 11:58 AM   #20
James M
Bored member
James M's Avatar
You can roll that knowledge into the next job, younger you are the longer you have to use that knowledge too. I don't blame the guy, if he'll never see another Kjet car it may not make sense to invest the time and money into learning and a pressure tester. But "I can't get parts, you can't fix it" is a cop-out excuse.
$20 says I'm younger than his mechanic anyways
Old 11-22-2022, 01:59 PM   #21
OVERDRIVE
OVERDRIVE's Avatar
If it ain't broke...
Old 11-22-2022, 02:11 PM   #22
white855T
+1 if it's running, not even well. I'd rather invest in maintenance. If it needs to be auto, swap an aw70/71. If manual is desired, he can do that too. I've never bought a kjet car running but would definitely learn if I needed to. We just swap over to efi as there is always an abundance of parts available.
Old 11-22-2022, 04:33 PM   #23
CarlosGato
Yes guys she runs good but the 1980 does not and we put a new cylinder head on it. so will the Kjetronic work, well that is a question, the car sat for years. So if it wont I would like a carb because I can do that msyelf. My brother looked at IPD and they have injectors kits not too bad but mechanic Manuel says if the fuel distributro is bad we are up a creek
Old 11-22-2022, 04:51 PM   #24
OVERDRIVE
OVERDRIVE's Avatar
Fuel distributors are rebuildable, just like a carburetor. Bosch CIS is a mechanical system, like a carburetor. There's a reason Mercedes-Benz continued using CIS on their cars until 1994. What head did you put on it? If it isn't a 160 or 405 than the debate of keeping it K-jet is pretty much over. You just need to find someone who actually knows the car they're working on, sorry.
Old 11-22-2022, 08:20 PM   #25
James M
Bored member
James M's Avatar
Mmm mmm I smell parts cannon for dinner
If you are not going to take the time to learn how it works and properly test/diag than yes, a carb is definitely the way to go
