Old 10-14-2022, 04:33 PM   #1
cwdodson88
Default Gauging interest Tremec tkx>m40/41 adapter
I know that the there are adapters for the tko to m46/47 bellhousings out there and readily available. But I’ve got a tkx on the way and started designing an adapter for the m40/41 bellhousing to a tkx tcet18086 (ford 10 spline 1-1/16 input shaft). Trans should be here next week and I can throw it on the cmm and get the last few details done on the design. Perfect timing, I’ve gotten into a new shop space and am getting my HAAS vf3 calibrated at the end of the month. But before I pull the trigger on some materials, wanted to see if there was interest in a single pattern, vertical m40/41>tkx tcet18086 trans?
The Build Thread
SVEA - PUSHROD TURBO!
Old 10-17-2022, 12:55 PM   #2
joel142
My heart says yes, my mind says probably.
The cold hard math is that I can start making more power in the 142, break the now M41, break the backup M41, and then pay the money to upgrade the transmission or just sell the M41s and use that money to upgrade now. It seems like those, the cross member, driveshafts, etc... are going for good money these days.
I'm definitely driving it 'softly' and downshifting out of 5th if I'm getting on it.
'71 142E, B230FT, M41, Corbeau GT seats, iPd bars and springs, Nardi wheel, GT gauges, Bilsteins, Canisto wheels, 7" Cibies
'95 T5-R, yellow, M56H swap
'06 R500, Built like a steak house; handles like bistro
joel142 is offline   Reply With Quote
Old 10-18-2022, 01:24 PM   #3
joel142
I can see the motivation on this transmission: M41 ratios and 600ft lbs of torque capacity. I don't see myself needing 600ft lbs any time soon but it could be really nice to not need to worry on the drivetrain front.
M41 (from Wikipedia)
  1. 3.13
  2. 1.99
  3. 1.359
  4. 1.00
  5. 0.77
tkx tcet18086
  1. 3.27
  2. 1.98
  3. 1.34
  4. 1.00
  5. 0.72
I do like my long handled shifter (for the vintage feel) but it makes the pattern really wide. I think the throws are in roughly a 1ft box?
Old 10-18-2022, 04:11 PM   #4
cwdodson88
  1. 3.13
  2. 1.99
  3. 1.359
  4. 1.00
  5. 0.77
tkx tcet18086
  1. 3.27
  2. 1.98
  3. 1.34
  4. 1.00
  5. 0.72
That’s exactly what drove me to this idea. That and I broke my “built” g-force t5, and the response from G-Force was that I was making too much power for their “450” hp main shaft.
Old 10-18-2022, 07:25 PM   #5
joel142
Do you have an idea on cost? The more I think about it the more sense it makes to sell the two M41's (and associated bits) to the "P1800 Purist Society" and upgrade.
If those known-good units fetch anywhere near their prices on eBay this could be the first (and only) time I'll ever make money off that car!
Old 10-18-2022, 09:17 PM   #6
cwdodson88
Gearbox is 2800 from summit. I’d reckon the cost for the adapter to be inline with others. So somewhere around 250-275 with hardware. It’s going to depend a bit on how much interest. If I can pull together enough, cost might drop.
Old 10-19-2022, 09:04 PM   #7
joel142
That sounds completely reasonable - keep me in the loop for the progress.
I think my project plan is to install and check out the spare "works great" M41 this winter. If it lives up to the seller's description sell whichever one is out of the car next spring and start in on this in earnest.
Old 10-23-2022, 11:27 AM   #8
spock345
spock345's Avatar
If the TKX has the same pattern as the T5 then I am game for this. I've got a working M41 but noise has started in 3rd. Thinking a Ford T5 with an S10 tail housing swap.
1998 S70, grandma-mobile
1980 245
1989 240 B230F, V15 cam, chipped EZK, M47 swap (Lost a fight with a Chevy express van), the millennial falcon
spock345 is online now   Reply With Quote
Old 10-23-2022, 02:18 PM   #9
cwdodson88
It’s similar to a Chevy t5 bellhousing pattern. Also fits the tko-500/600.
Does not fit the narrow ford t5 (I could do these)
Not sure if Roger Dee is doing m41>ford t5’s. If he’s not, I will.
Old 11-01-2022, 02:28 AM   #10
Superhans240
What tko adapter for m46/47 is readily available?
Superhans240 is offline   Reply With Quote
Old 11-01-2022, 09:55 AM   #11
spock345
spock345's Avatar
If you are doing an M41->T5 adapter I am interested.
Old 11-01-2022, 04:58 PM   #12
GTJordan
Been here for too long
GTJordan's Avatar
Probably refering to the BNE kit that's been sold out for too long
The TKO and tkx share a pattern? Tkx would be a nice upgrade if I screwed up building this T5.
Jordan
80 242- 2.5L 16V, NIW intake/exhaust, GT3076, MAxxECU Race, KL Stg 2 cams. T5 w/ 2.95 gearset. Porsche brakes, Gaz short coilovers/shocks and Kaplenkhe suspension, Trutrack.
Old 11-02-2022, 02:09 PM   #13
Jordan
Should be able to change that status early December. Wrapping up the current bottleneck now
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 11-04-2022, 10:01 AM   #14
cwdodson88
Ok, I’ll keep that on the list. Send me a pm, I might have something you’d be interested in.
Old 11-04-2022, 10:05 AM   #15
cwdodson88
Jordan
The tko and tkx share the same bellhousing pattern and trans X member placement. It’s just better at handling higher rpm shifts, and case design is more compact, and rigid.
